2 inlets with a different gas in each = a multiphase flow solver ? |
April 4, 2016, 10:13 |
AdOo
Rep Power: 10 |
Hi foamers,
I was wondering if I had to use a multiphase flow solver like multiphaseEulerFoam in order to handle two different inlets with two gases although two gases are just making one single physical phase ? To be more precise : In fact I have two inlets on something which looks like a pipe. One gas for each inlet. The two gases have their own properties (pressure, temperature...). I would like to simulate a compressible and turbulent flow (with a RASmodel) but I don't know which solver is able to handle that. A "simple" compressible flow solver (like rhoPimpleFoam) or a multiphase flow solver (like multiphaseEulerFoam) ? |
April 5, 2016, 05:02 |
AdOo
Rep Power: 10 |
No idea ? Because I really don't know which OpenFOAM example to follow in order to start my case... It seems that there isn't any case like that...
April 5, 2016, 06:00 |
AdOo
Rep Power: 10 |
Apparently I was completely on the wrong way.
I've found hints there: http://www.cfd-online.com/Forums/ope...g-gas-gas.html reactingFoam should do the job for mixing gases even if there is no reaction. Have a nice project, Adrien |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
The problem of Stiff Chemistry Solver in Multiphase model | shenzhou1987 | FLUENT | 1 | January 11, 2016 03:52 |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 19:11 |
Difference in flow distribution of single phase and multiphase analysis | shivasluzz | CFX | 0 | April 22, 2015 23:54 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 13:14 |
