Freestream BC, HELP PLEASE!
Like Tree2Likes
  • 1 Post By TypeR
  • 1 Post By TypeR
Old   March 28, 2016, 12:47
Default Freestream BC, HELP PLEASE!
Mike_star is on a distinguished road
Hello everyone,
I am pretty new to Openfoam and I am trying to model a 2d airfoil in a time varying free stream velocity. From the airfFoil2D tutorial I got I need to set the type of the boundaries to "freestream" for all inlet,outlet, top and bottom patches and the wind velocity in the tutorial has been set as follows:
type freestream;
freestreamValue uniform (25.75 3.62 0);
is there any way that I can change the freestreamValue to a time varying value using the same boundary type (freestream)?
(I should mention that for some reason I prefer to keep the type of the boundaries as freestream)
Thank you.
Mike_star is offline   Reply With Quote
Old   March 28, 2016, 16:16
soichiro
TypeR is on a distinguished road
Example from groovyBC instruction page(mimics inletOutlet):
outlet
type groovyBC;
valueExpression "vector(0,0,0)";
gradientExpression "vector(0,0,0)";
fractionExpression "(phi > 0) ? 0 : 1";
value uniform (0 0 0);
fractionExpression: Direchlet(1) or Neumann(0) BC
gradientExpression: for Neumann BC
valueExpression: for Direchlet BC
You can change the expressions to be time varying
Mike_star likes this.
TypeR is offline   Reply With Quote
Old   March 28, 2016, 16:29
Thank you for your reply. Could you please send me the link of the page?
what does "phi" stand for?
outlet
type groovyBC;
Old   March 28, 2016, 16:31
soichiro
https://openfoamwiki.net/index.php/Contrib/groovyBC
phi is the flux
Old   March 28, 2016, 16:40
Awesome. Actually the good thing about the "freestream" is that it treats each cell as a single patch, therefore instead of having inlet/outlet/bottom/top a circular boundary can be considered and the freestream can be applied. However for groovyBC it is necessary to have inlet and outlet.( please correct me if I am wrong)
Thank you for your help.
Old   July 19, 2017, 05:42
hfs
hfs is on a distinguished road
Hi
I want to use freestreampressure but combined with having the pressure prescribed as a value:
"Prescribed pressure; with allowed in/outflow reversal"
Is this possible in OpenFoam? Thanks,
PS: more details:
It is a wind engineering in-compressible flow simulation.
I have a prescribed inlet velocity BC (Fluctuating Inlet). We usually combine this with a zeroGradient Pressure BC on the inlet.
I want to have Inlet/Outlet condition on the Top, Sides and Outlet. However, a pressure value should be described on some boundary. Usually we use a fixedValue 0 for pressure. Is there a way to combine this with freestreampressure?
hfs is offline   Reply With Quote
airfoil, freestream, time varying, unsteady
Freestream Setup in an External Flow Simulation phathomie27 STAR-CCM+ 1 January 6, 2017 08:00
multi-species plasma test case jentink SU2 6 August 5, 2016 03:04
SU2 cfg file and runtime problems hedley SU2 19 January 26, 2016 05:17
parallel code samiam1000 SU2 3 March 25, 2013 05:55
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 18:18
