why interDyMFoam does not support backward ddt scheme?
Like Tree6Likes
  • 5 Post By olivierG
  • 1 Post By olivierG
Old   March 3, 2016, 05:02
Default why interDyMFoam does not support backward ddt scheme?
Yage
Yage is on a distinguished road
Dear Foamer,
I would like to use backward second order time discretization in interDyMFoam, but the solver doest not support this time scheme.
Could someone explain the reason for that?
Many Thanks,
Yage
Yage is offline   Reply With Quote
Old   March 3, 2016, 05:31
Yage
I found that the interDyMFoam support Crank-Nicolson (CN) scheme and I set the weighing factor to 1 for fully second order accuracy.
But the alphasubcycle must be 1 in this case.
Any idea about the reason?
Old   March 3, 2016, 06:53
Olivier
olivierG is on a distinguished road
hello,
This may come from the fact the backward are not a bounded scheme, and MULES need it, or that MULES aren't coded to use backward.
CN just need current and old time, so sub-cycling used in MULES may not be usable. Same for backward.
regards,
olivier
Yage, aow, Turin Turambar and 2 others like this.
olivierG is offline   Reply With Quote
Old   March 3, 2016, 08:16
Yage
Originally Posted by olivierG View Post
hello,
regards,
olivier
Thanks for your answear
Old   March 3, 2016, 08:18
Yage
hello,
regards,
olivier
and any suggestion for which one to use, 1st order ddt + sub-cycling or 2nd order ddt without sub-cycling?
Regards,
Yage
Old   March 3, 2016, 09:26
Olivier
hello,
I would say first order for a RANS may be enough, and 2nd order with lower time step for more fine RANS/ LES case.
regards,
olivier
Richal Sun likes this.
Old   March 3, 2016, 13:47
Yage
hello,
regards,
olivier
Thanks for the suggestion
Building from Source on Windows using Cygwin64 ericthefatguy SU2 2 May 12, 2015 19:23
ANSYS Compression only/Elastic support yavuz.hspc Structural Mechanics 0 June 6, 2014 10:23
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
