Cahn Hilliard implementation (Biharmonic operator) |
February 15, 2016, 03:36 |
Joe Peterson
I'm interested in modeling viscoelastic phase separations in simple flows. As a first step in the process, I want to implement a simple diffusive phase separation such as the Cahn Hilliard equation using OpenFOAM. There are at least several threads with people asking for advice for solving the Cahn Hilliard equation, and as of last active discourse (~2012) there was no publicly distributed resolution to the main problem (an implicit treatment of the fourth order derivative in the problem) A link to one of the prior threads on this topic: http://www.cfd-online.com/Forums/ope...-openfoam.html The grand challenge is that, for a stable implementation, a fourth order spatial derivative (the biharmonic operator) must be calculated implicitly at some stage. One common way to accomplish this is to solve simultaneously for two variables such that the model assumes the following structure: x = laplacian(y) dx/dt = laplacian(x + y) I'm new to the environment, but so far it seems that in OpenFOAM the solver only solves a single field at a time; can I trick it into solving for these two variables simultaneously? Is there another way that I should be thinking about the problem? Any help or insight into this challenge would be greatly appreciated! |
biharmonic, cahn hilliard, phase field, phase separations |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 10:23 |
FLUENT installation on UBUNTU 12.04 (LTS) | teymourj | FLUENT | 2 | March 1, 2017 23:24 |
Create a biharmonic operator | Pascal_doran | OpenFOAM Programming & Development | 12 | May 22, 2016 07:02 |
cahn hilliard equation finite volume method | dvdromnu | OpenFOAM Programming & Development | 0 | December 14, 2009 03:09 |
Cahn Hilliard couple with Navier Stokes | Khan | Main CFD Forum | 0 | September 2, 2006 03:19 |
