pimpleFoam error
Like Tree2Likes
  • 1 Post By akidess
  • 1 Post By clktp
Old   February 8, 2016, 04:54
Question pimpleFoam error
Mohsen
mohsen.boojari is on a distinguished road
Hi everyone,
I tried to run a test case with pimpleFoam but I got this error in my terminal. any idea to resolve the problem???
here is my error :
Starting time loop
Courant Number mean: 6.40406250002 max: 11.0400000016
Time = 0.025
PIMPLE: iteration 1
Force (per unit density) on foil:
(155.747394113 -1835.07680434 0)
--> FOAM FATAL IO ERROR:
keyword div((nuEff*dev2(T(grad(U))))) is undefined in dictionary "/home/top/OpenFOAM/top-3.0.0/turbinesFoam-master/tutorials/actuatorLine/pimpleFoam/system/fvSchemes.divSchemes"
file: /home/top/OpenFOAM/top-3.0.0/turbinesFoam-master/tutorials/actuatorLine/pimpleFoam/system/fvSchemes.divSchemes from line 29 to line 33.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 442.
FOAM exiting
and here is my fvSchemes file :
divSchemes
    default             none;
    div(phi,U)          bounded Gauss upwind;
    div((nuEff*dev(T(grad(U)))))    Gauss linear;
    div(phi,epsilon)    bounded Gauss upwind;
    div(phi,k)          bounded Gauss upwind;
mohsen.boojari is offline   Reply With Quote
Old   February 8, 2016, 06:04
akidess's Avatar
Anton Kidess
Carefully read the error message and compare it to the contents of your fvSchemes. Hint - you are missing a single character.
MBttR likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   February 8, 2016, 06:15
Mohsen
I've just begin learning OpenFOAM, so I'm still not familiar with it's stuffs. by the way I'm running a tutorial example and it has been developed by someone else.
could you please tell me what single character i missed?
thanks
Old   February 9, 2016, 09:16
gereksiz
clktp is on a distinguished road
--> FOAM FATAL IO ERROR: keyword div((nuEff*dev2(T(grad(U))))) is undefined in dictionary "/home/top/OpenFOAM/top-3.0.0/turbinesFoam-master/tutorials/actuatorLine/pimpleFoam/system/fvSchemes.divSchemes"
It says div((nuEff*dev2(T(grad(U))))) is missing.
According to your scheme table, it is really missing, because you only have the first one, you need the second one as well.
mohsen.boojari likes this.
clktp is offline   Reply With Quote
Old   February 9, 2016, 10:47
Mohsen
thanks Dear taygun
divergence, fvschemes, pimplefoam
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
