rhoSimpleFoam searches for RAS model
Like Tree1Likes
  • 1 Post By hamsteri15
Old   February 1, 2016, 08:46
Default rhoSimpleFoam searches for RAS model
Petteri
hamsteri15 is on a distinguished road
I'm trying to use the rhoSimpleFoam to solve flat plate flow for a laminar case just to demonstrate the differences in setting up compressible and incompressible cases. I was able to do this quite easily with version 1.7 just by switching off the turbulence model but the version 3.0.1 searches for the 'RAS' section from 'turbulenceProperties' although 'simulationType' is set to laminar.
I assume I can overcome this problem just by setting turbulence off under 'RAS' but this is quite annoying since I still have to specify initial values, solvers etc. for some turbulence model. Am I doing something wrong or is this a bug in the code?
Here's some files for you:
working 'turbulenceProperties' file
simulationType laminar;
RAS
//the solver looks for these values even though it shouldn't
RASModel kEpsilon;
turbulence off;
printCoeffs on;
'turbulenceProperties' file that doesn't work
hamsteri15 is offline   Reply With Quote
Old   February 10, 2016, 11:54
martel is on a distinguished road
I am having the same problem with laminar simulation with rhoSimpleFoam. Have you had any progress on this?
Thanks in advance for your help
--Carlos
martel is offline   Reply With Quote
Old   February 10, 2016, 11:58
Petteri
--Carlos
I ended up running the simulation using a k-epsilon model with small initial values for the turbulence and specifying turbulence 'off' under RAS. The results were exactly the same as the 'laminar' model in version 1.7 for a flat plate flow.
peterf likes this.
Old   February 10, 2016, 12:00
Thanks hamsteri15!
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
problem with solving lagrange reaction cloud Polli OpenFOAM Running, Solving & CFD 0 April 30, 2014 08:53
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 10:29
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
