Pipe in pipe heat exchanger
Like Tree1Likes
  • 1 Post By Bloerb
Old   February 1, 2016, 04:59
Question Pipe in pipe heat exchanger
Zoli is on a distinguished road
Hello people
I am a PhD. student at the department of hydraulic machines in Slovakia. Till now a made all of my simulations in ANSYS Fluent, but want to know the basics of OpenFOAM simulations. As my first case i choosed a pipe in pipe heat exchanger, following the tutorials on site:
https://openfoamwiki.net/index.php/G..._-_planeWall2D
Everything looks fine, but this case deals with a co-current heat exchanger, so the both mediums are flowing in the same direction (1,0,0).
I want to change the direction of the bottom fluid to (-1,0,0) however when i change the vector in the \system\bottomAir\changeDictionaryDict file to
U
internalField uniform (0 0 0);
boundaryField
leftLet
type fixedValue;
value uniform ( -0.1 0 0 );
rightLet
type inletOutlet;
inletValue uniform ( 0 0 0 );
bottomAir_bottom
type symmetryPlane;
"bottomAir_to_.*"
type fixedValue;
value uniform (0 0 0);
the direction does not change. I would appriciate You help.
Thank You.
Zoli
Zoli is offline   Reply With Quote
Old   February 1, 2016, 14:18
Bloerb will become famous soon enough
I have not opened the original files, but if you only changed the values this will not work. You want to change inlet and outlet. You therefore need to switch the boundary conditions for those and in addition the velocity at the inlet since it will enter the domain from the opposite direction. Maybe something like this:
U
        boundaryField
            leftLet
                type            inletOutlet;
                value           uniform ( 0 0 0 );
            rightLet
                type            fixedValue;
What i suppose you have done however is fix the velocity on the outlet side and put a inletOutlet on the inlet. But since inletOutlet switches to fixedValue if the flow is into the domain you have one side with fixed Velocity of zero and one with -0.1
Zoli likes this.
Bloerb is offline   Reply With Quote
Old   February 2, 2016, 04:12
Wink
Hello Dear Bloerb!
I changed the BC as YOu written, and the simulation worked like a charm
Thank You very much for the help.
I think we can close this thread
Best regards:
Zoli
Ansys Fluent analysis of heat exchanger MStudent FLUENT 2 April 20, 2015 09:40
[ANSYS Meshing] how to apply interior boundary condition in double pipe heat exchanger m7566 ANSYS Meshing & Geometry 7 April 10, 2015 09:21
[GAMBIT] double pipe heat exchanger with helical fin around inner tube mozafarie ANSYS Meshing & Geometry 5 November 7, 2012 06:02
Need Help on Heat Flux Profile within Pipe Wall mep10jl FLUENT 3 June 6, 2011 18:08
Concentric Tube Heat exchanger (pipe in pipe) in 2D ckliew ANSYS 0 February 24, 2011 08:48
