Velocity Profile at inlet if Mass flow rate BC is given |
January 28, 2016, 02:28 |
Sing
Rep Power: 10 |
Hello Foamers and Researchers!!
Greetings! I am quite new to OpenFoam, has been practicing it from last 1 month. I have a doubt and I would be very grateful if anyone can help me with this. In a problem I have given flowRateInletVelocity boundary condition at my inlet, specifying mass flow rate. fixedFluxPressure BC is given for pressure at the inlet. I want to know that if we give mass flow rate (or volumetric) BC then how the velocity profile at inlet will be decided? (Parabolic, uniform etc) Regards, Prateek. |
January 28, 2016, 10:31 |
Daniel P. Combest
Prateek,
Seems you have double posted, so I'll answer both quickly to let the admin delete one if they like. Have a look at the code in Code:
/src/finiteVolume/fields/fvPatchFields/derived/flowRateInletVelocity/flowRateInletVelocityFvPatchVectorField.C Code:
// mass flow-rate operator==(n*avgU/uniformRho); |
January 29, 2016, 03:52 |
Sing
Rep Power: 10 |
Hello Daniel,
Thanks a lot for the quick reply. I noticed afterwards that I posted this twice. Sorry for the same. Yes I have seen the code as you mentioned and got what you said. My deepest gratitude for sorting out my confusion. Regards, Prateek. |
April 14, 2019, 22:03 |
Brett
Rep Power: 14 |
Hey guys,
Do you know how to set the mass flow rate NOT normal to the boundary? B |
flowrateinletvelocity, mass flow rate bc, velocity profile |
Using a Mass Flow Rate profile with a Temporal field as a Boundary Condition | Jotheman | Main CFD Forum | 0 | October 18, 2015 10:25 |
Please help me ( udf for regulation the mass flow rate at the inlet ) | swidi | Fluent UDF and Scheme Programming | 0 | July 7, 2015 10:17 |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 18:24 |
velocity or mass flow inlet? | Silvia | FLUENT | 1 | August 12, 2005 14:55 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 19, 2003 15:03 |
