EOS and phase change on reactingTwoPhaseEulerFoam |
January 26, 2016, 14:11 |
Farhad N.
Rep Power: 16 |
I am struggling with adding a new equation of state to be used with reactingTwoPhaseEulerFoam, since I am dealing with a cryogenic liquid, which is not an ideal liquid, and Peng Robinson is only available for gas. My idea was to replace the Thermo class and write my own class (myThermo) and get rid any possible complications.
I am dealing with phase-change defined in constant/phaseProperties and I chose Antoine equations to consider phase-change at the boiling point according to pressure fluctuations. I don't find, in the code, where phase-change is programmed. Any idea???? Thanks |
May 16, 2016, 13:16 |
#2 | |
Simone Colucci
Rep Power: 10 |
I'm also struggling with the phase-change in reactingTwoPhaseEulerFoam. Few things I have understood now: - the mass transfer term is somehow similar to the term used in Fluent (Eqn. 17-522) - the mass transfer coefficient is defined in reactingEulerFoam/interfacialCompositionModels/massTransferModels/Frossling or .../SphericalMassTransfer. - The equilibrium concentration is in reactingEulerFoam/interfacialCompositionModels/interfaceCompositionModels/Henry or .../Raoult. Anyway, I still do not understand 1) where is the mass transfer term written in the code ? 2) where is the Lewis number used ? 2) why in the Henry law I do notsee any pressure? Any idea?Thanks Simone |
May 24, 2016, 08:24 |
#3 | |
Simone Colucci
Rep Power: 10 |
- the mass transfer coefficient is calculated by the member function massTransfer in reactingEulerFoam/phaseSystems/phaseSystems/InterfaceCompositionPhaseChangePhaseSystem /InterfaceCompositionPhaseChangePhaseSystem.C This function is called twice from YEqns.H, first before solving the transport equations for components in each phase, Y1iEqn and Y2iEqn, and then at the end to update the mass transfer term. // call function massTransfer autoPtr<phaseSystem::massTransferTable> massTransferPtr(fluid.massTransfer()); ... // call function massTransfer fluid.massTransfer(); // updates interfacial mass flow rates During the first call, the mass transfer term is added to the Y matrix equation as fvm, // Implicit transport through the phase *eqns[name] += phase.rho()*KD*Yf - fvm::Sp(phase.rho()*KD, eqns[name]->psi()); The second call updates the value stored in dmdt adding to dmdtExplicit the part depending on the solution of the Y equation, already solved, dmdt -= dmdtSign*phase.rho()*KD*eqns[name]->psi(); Note that dmdt, before entering into the loop, is initialized with the value of dmdtExplicit *this->dmdt_[pair] = *this->dmdtExplicit_[pair]; in this way the explicit part used for calculating dmdt corresponds to the explicit part used in the YEqn. - KD in the phase change term is given by K*D, where K is the mass transfer coefficient calculated in reactingEulerFoam/InterfacialCompositionModels/massTransferModels/SphericalMassTransfer/spericalMassTransfer.C or ../Frossling/Frossling.C and D the mass diffusivity calculated in in reactingEulerFoam/InterfacialCompositionModels/InterfaceCompositionModels/InterfaceCompositionModel.C. Any reference, idea ... about the interface Composition Model? I don't know exactly what is that. Simone |
May 1, 2017, 19:03 |
Rep Power: 14 |
Dear Simone,
I think the interface Composition Model is used to estimate the species mass fraction under saturation at the phase interface which will be used for the mass transfer model. What kind of problems are you solving? gas-liquid and gas-particles? |
May 10, 2017, 08:29 |
Simone Colucci
Rep Power: 10 |
I'm solving for gas-liquid only... |
January 2, 2020, 09:13 |
Henry's law constant
Rosario Arnau
Rep Power: 9 |
Hi Foamers,
I would like to ask you two things about the interface Composition models in this solver: 1. In some tutorials, the interfaceComposition model is just specified for one phase. Example: tutorials\multiphase\reactingTwoPhaseEulerFoam\RAS \bubbleColumnEvaporatingReacting\constant Code:
interfaceComposition ( (gas in liquid) { type Saturated; species ( H2O ); Le 1.0; saturationPressure { type ArdenBuck; } } ); Code:
interfaceComposition ( (gas in liquid) { type Saturated; species ( water ); Le 1.0; saturationPressure { type ArdenBuck; } } (liquid in gas) { type Henry; species (air ); k ( 1.492e-2 ); Le 1.0; } ); Code:
(liquid in gas) { type Henry; species (air ); k ( 1.492e-2 ); Le 1.0; } Thanks in advance! |
January 27, 2022, 03:00 |
Sk Hossen Ali
Rep Power: 5 |
Dear Simone,
You seem to understood quite a bit about the mass transfer in interfaceCompositionPhaseChangeTwoPhaseSystem (ICPCTPS) and I also do agree with your points. I am struggling for the same questions in case of the thermalPhaseChangeTwoPhaseSystem (TPCTPS). As the description of the solver TPCTPS suggest depending upon the heat transfer between the phases the amount of mass evaporation/condensation happens. When I ran few cases to simulate evaporation due to heat transfer from hot gases to the liquid (at saturation condition), it never happens. After few times steps the temperature of gases near the interface seems to go below saturation temperature and opposite happens (i.e., condensation from hot gases to liquid). I have found no matter how much is the temperature of liquid or gases near the interface always the condensation happens. The phases as liquid (occupied in the lower half of domain)- saturated water, gas (occupied in the upper half of domain)- mixture of air and water vapor(initially zero amount) I am attaching my whole case which I am running in openFoam-2106 version. 1. How is the mass transfer term calculated based on the thermal exchange between the phases? Where are those terms in code like you have shown for the case of ICPCTPS. https://drive.google.com/file/d/1DhB...ew?usp=sharing My main goal is to - simulate evaporation to happen due to heat transfer from hot gases to the liquid interface. Any help would greatly appreciated. Thanks in advance. |
July 18, 2024, 19:29 |
Ram
Rep Power: 10 |
Hi Rosario,
did you find your answers? I am struggling with the same problem... Last edited by cfdGeek; August 8, 2024 at 16:15. |
equation of state, evaporation, openfoam, phase change, reactingtwophaseeulerfoam |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Solid EOS | adam | Main CFD Forum | 5 | March 18, 2008 14:12 |
