incompressible twoPhaseEulerFoam
Like Tree1Likes
  • 1 Post By BlnPhoenix
Old   January 11, 2016, 09:53
Default incompressible twoPhaseEulerFoam
hoseinhd's Avatar
hossein hadi
hoseinhd is on a distinguished road
Hi dear Foamers,
As you know the description of twoPhaseEulerFoam says that "Solver for a system of 2 compressible fluid phases with one phase dispersed, e.g. gas bubbles in a liquid including heat-transfer."
How can I use this solver for incompressible fluid?
Thanks a lot
hoseinhd
hoseinhd is offline   Reply With Quote
Old   January 11, 2016, 10:35
BlnPhoenix is on a distinguished road
You can set the diameterModel in /constant/phaseProperties to "constant" with "constantCoeffs" and give a diameter for the resp. phases. I think this should give you incompressible phases.
BlnPhoenix is offline   Reply With Quote
Old   January 12, 2016, 02:07
hoseinhd's Avatar
hossein hadi
Thanks BlnPhoenix for your reply.
What does diameterModel exactly mean for a continuous phase?
I guess if its magnitude is large enough then it will be continuous phase (like fluidisedBed tutorial).
I think putting equationOfState rhoConst; in constant/thermophysicalProperties.incompressiblePhase would solve the problem. Am I right?
Old   January 12, 2016, 03:40
Yes, in areas where the dispersed phase gets larger than the continous phase these two get blended, so e.g. water is now dispersed in air and these water droplets have the prescribed diameter.
Yes, i think your correct.
meshman likes this.
incompressible, twophaseeulerfoam
Physics of an incompressible fluid Jonas Holdeman Main CFD Forum 87 April 22, 2019 11:40
Incompressible turbulence models: strange implementations? AleDR OpenFOAM 3 November 18, 2014 12:23
Incompressible simulation brugiere_olivier SU2 2 April 15, 2014 11:12
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? ThomasV OpenFOAM 0 November 11, 2013 09:10
Compressible vs. Incompressible formulations Fernando Velasco Hurtado Main CFD Forum 3 January 7, 2000 17:51
