Dummy turbulence model for OpenFoam 3 Simple FOAM |
January 7, 2016, 12:27 |
#1 | |
Rep Power: 11 |
Hi all,
So, I have upgraded my OpenFOAM to 3.0.0 and I cannot find any way how to set the dummy turbulent model whilst using the simple loop (using one of the heat transfer apps). Any ideas how to do it? Current turbulenceProperties file is as: Quote:
January 28, 2016, 13:39 |
This is what I'm searching, too.
Why there is no laminar dummy model!? It doesn't even react to elimination of the "simulationType" keyword.
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
January 29, 2016, 10:02 |
VA
Rep Power: 11 |
I believe it was a bug in the code that was causing this issue. I had reported it, and it was fixed in OpenFOAM-3.0.x. You may have to download 3.0.x version or fix the bug in the current 3.0.0 version. It is a simple fix anyway.
http://www.openfoam.org/mantisbt/view.php?id=1951 |
March 10, 2016, 23:28 |
Lavanya
Rep Power: 11 |
In the new version openfoam3.0.1, I tried,
simulationType RAS; RAS { RASModel laminar; turbulence on; printCoeffs on; } but its not working. Instead, " simulationType laminar; " is working !!!! Thank you |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
SIMPLE algorithm and k-eps turbulence model | zqnwpu | Main CFD Forum | 11 | May 28, 2012 05:08 |
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 05:41 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
