December 15, 2015, 12:09 |
choose the right multiphase solver
hossein hadi
Rep Power: 11 |
Hi dear foamers,
I want to use mixture multiphase model for my case which is solid particles in liquid. As I noticed there is no mixture solver in openfoam. But there are other multiphase solvers such as interFoam or twoPhaseEulerFoam. Which one do you suggest me to start with? And what modifications are needed? Any help would be appreciated. Thanks in advance hoseinhd |
December 15, 2015, 14:32 |
Hesam
Rep Power: 11 |
Hello Hossein,
You can find a specific type of mixture model in settlingFoam solver,But in settlingFoam solver instead of using drag models for drift velocity use from experimental curves.for your case my suggestion is two phaseEulerFoam and Mixture model. |
January 2, 2017, 07:47 |
mixtire model
farzad khallaghi
Rep Power: 10 |
what about one phase mixture model.in my case there is bubble plume in the quiescent water that rising with their buoyancy force. so which solver is the best for this situation?
January 2, 2017, 08:25 |
Juho Peltola
Rep Power: 17 |
https://github.com/OpenFOAM/OpenFOAM...riftFluxFoam.C
Application driftFluxFoam Description Solver for 2 incompressible fluids using the mixture approach with the drift-flux approximation for relative motion of the phases. Used for simulating the settling of the dispersed phase and other similar separation problems. |
interfoam, mixture model, multiphase, solver, twophaseeulerfoam |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 13:31 |
Choose of the good multiphase flows model | Miki12 | Main CFD Forum | 1 | June 4, 2014 03:33 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 07:58 |
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon | qinmaple | OpenFOAM Announcements from Other Sources | 4 | August 10, 2012 12:00 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
