Using functionObjects with chtMultiRegionSimpleFoam |
December 15, 2015, 11:15 |
Rep Power: 11 |
I am trying to use the packed function object flowRate with chtMultiRegionSimpleFoam and it fails with Code:
--> FOAM FATAL ERROR: request for objectRegistry region0 from objectRegistry heatExchanger failed available objects of type objectRegistry are 2 ( air porous ) From function objectRegistry::lookupObject<Type>(const word&) const in file /home/openfoam/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::objectRegistry const& Foam::objectRegistry::lookupObject<Foam::objectRegistry>(Foam::word const&) const at ??:? #3 Foam::OutputFilterFunctionObject<Foam::fieldValues::faceSource>::allocateFilter() at ??:? #4 Foam::OutputFilterFunctionObject<Foam::fieldValues::faceSource>::start() at ??:? #5 Foam::functionObjectList::read() at ??:? #6 Foam::Time::run() const at ??:? #7 Foam::Time::loop() at ??:? #8 ? at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? at ??:? I followed the guidlines given in http://cfd.direct/openfoam/user-guide/function-objects/ under 6.2.2 using heatExchanger tutorial-file It seems that there are problems because of the multi-domain characteristics of this case. Does anybody know a solution for this? My testcase can be downloaded here https://owncloud.tu-berlin.de/public...0ef4484fb590cd |
December 19, 2015, 14:48 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer:
chtmultiregionsimplefoam, flow, functionobjects, rate |
Reading in foamFiles from functionObjects | Adam_Lavely | OpenFOAM Post-Processing | 0 | July 17, 2013 14:37 |
Problem with functionObjects in parallel | anishtain4 | OpenFOAM | 4 | February 12, 2013 06:27 |
OpenFOAM v1.6 & OpenMPI & functionObjects | bruce | OpenFOAM Bugs | 7 | December 16, 2011 15:37 |
How can I write selective additional fields using functionObjects? | fpmhadi | OpenFOAM | 3 | July 14, 2011 18:41 |
OpenFOAM v1.6 & OpenMPI & functionObjects | bruce | OpenFOAM Running, Solving & CFD | 1 | August 7, 2009 14:15 |
