Can OpenFOAM auto-delete out of date time steps? |
Nicole Andrew
Rep Power: 11 ![]() |
Hi foamers,
I am running some OpenFOAM cases on a cluster for the first time and they keep stopping. The log files just end mid-time step so I am trying to guess at the problem... I think the cluster may be running out of memory. Is there a way to tell an OpenFOAM case to just save the latest time step, or overwrite the previous time step as it writes the new ones? I only need the latest time step, but I do not want to wait to save a step until it has converged, in case it crashes again. I am trying to run 10 different cases simultaneously that take 4-5 days each to converge properly. I hope someone can help!! ![]() |
Rep Power: 12 ![]() |
in controlDict, there is an entry called purgeWrite. Set this to 5 for example, and only the latest 5 time steps are being kept. If this is set to zero, the function is turned off and all steps are kept.
Nicole Andrew
You just totally saved my day!! Thanks so much
Andrew O. Winter
Same here! You've saved me a huge amount of time and worrying about filling up my research group's storage drives.
cluster, controldict, memory, time step, write control |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Problems about compiling OF1.5.x on Bluegene/P | ywang | OpenFOAM | 1 | August 25, 2011 05:22 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
