LES problems for nozzle geometry
Like Tree1Likes
  • 1 Post By Bogdan90
Old   December 7, 2015, 07:41
Default LES problems for nozzle geometry
Bogdan Osyka
Bogdan90 is on a distinguished road
Hi foamers, I am simulating the flow in a nozzle geometry(see attached file) using the LES turbulence model. The condition for the flow is such that the Re in the throat (the connecting pipe) is 3500, which is a transient flow, however when I simulate I get a perfect laminar flow, which contradicts with benchmarks and RANS simulations for the same problem. I have experimented with different profiles and different LES models but result is pretty much the same. I am really stuck with this problem for more than a month, so I hope I can here some suggestions from you
image001.jpg)
jbliu2015 likes this.
Bogdan90 is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[DesignModeler] having problems with filling geometry magnusDux85 ANSYS Meshing & Geometry 37 July 29, 2015 05:46
[ICEM] Problems with geometry when defining boundary conditions darazsbence ANSYS Meshing & Geometry 2 February 24, 2013 10:07
LES on a scaled geomentry (Mesh and Large scales) comb Main CFD Forum 0 February 8, 2011 07:21
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
