Viscous Forces and Pressure Gradient - OpenFoam v2.3.x |
November 19, 2015, 21:00 |
Hello Every one;
I have been trying to compare some CFD results (OpenFoam vs. Fluent) for a flat plate case which I am guessing most of you are familiar with. Right! So the case is incompressible and run with Mach = 0.1 ( V =34.6 m/s)). I get the same Pressure and Velocity Field for both Sofwares. Also, I get the same results for Kinetic Energy, Turbulent Viscocity and Omega. However, my lift and drag coefficients are off. I am expecting a CD = 0.01 and Cl = -0.0094872 (fluent results) and in OpenFoam I get CD =0.000534504 and CL -0.000464995. With a lot of repetition I came to notice the pressure forces is correct and equal to fluent's results. However the viscous force is 3 times lower. I checked the wallGradU.exe utility and the gradient at the wall matches Fluent's results. However when I checked the Wall shear stress I have negative values in the same data range [ for example - 100 to -3] and in Fluent I have [+100 to +3]. Solver is SimpleFoam or PisoFoam, Turbulence is on, Model is SSTvorticity(modified SST). fvScheme Code:
ddtSchemes { default steadyState; } gradSchemes { //default Gauss linear; default leastSquares; grad(U) leastSquares; grad(p) leastSquares; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss limitedLinear 1; div(phi,omega) bounded Gauss limitedLinear 1; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; snGrad(U) corrected; } fluxRequired { default no; p ; Phi ; } Code:
solvers { p { solver GAMG; tolerance 1e-08; relTol 0.001; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; maxIter 1000; } pFinal { solver GAMG; tolerance 1e-10; relTol 0.001; smoother GaussSeidel; } Phi { $p; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 1; tolerance 1e-10; relTol 0.1; maxIter 1000; } k { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; maxIter 1000; } omega { solver smoothSolver; smoother GaussSeidel; tolerance 1e-10; relTol 0.1; nSweeps 1; maxIter 1000; } } SIMPLE { nCorrectors 0; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p 1e-6; U 1e-6; } } potentialFlow { nNonOrthogonalCorrectors 10; pRefCell 0; pRefValue 0; PhiRefCell 0; PhiRefPoint 0; PhiRefValue 0; Phi 0; } relaxationFactors { fields { p 0.3; } equations { U 0.5; omega 0.5; k 0.5; } } Code:
functions { forces { type forceCoeffs; functionObjectLibs ( "libforces.so" ); outputControl timeStep; outputInterval 10; patches ( CRVS ); pName p; UName U; rhoName rhoInf; rhoInf 1.2; log true; CofR (0 0 0 ); liftDir (0 1 0); dragDir (1 0 0); pitchAxis (0 0 1); magUInf 34.7; lRef 2; Aref 2; } Code:
smoothSolver: Solving for Ux, Initial residual = 1.82304e-008, Final residual = 5.40526e-010, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 6.87114e-008, Final residual = 3.0058e-009, No Iterations 1 GAMG: Solving for p, Initial residual = 2.69686e-006, Final residual = 8.28443e-009, No Iterations 29 time step continuity errors : sum local = 4.57401e-009, global = -7.21234e-010, cumulative = -6.15044e-006 smoothSolver: Solving for omega, Initial residual = 4.97458e-006, Final residual = 3.4698e-007, No Iterations 1 smoothSolver: Solving for k, Initial residual = 1.53917e-005, Final residual = 9.17097e-007, No Iterations 2 bounding k, min: 1e-018 max: 0.240867 average: 0.0297818 ExecutionTime = 116.615 s ClockTime = 117 s Since, this is a flat plat plate there max skewness of the mesh is = 0. So mesh quality issues are eliminated from this discussion I guess. So is there any thing I am doing wrong? How can I improve my drag and Lift forces for this simple case? Many thanks Shereez |
November 20, 2015, 09:45 |
Dear Fellow Users of OpenFoam;
I quote Allesenadro: http://www.cfd-online.com/Forums/ope...-cylinder.html If the solver outputs forces then your drag will be: Cd = (Force per unit span)/(1/2 * rho V^2 * chord )=(Drag/(z-depth))/(1/2 * rho * v^2 * S). I mean your S, which I assume is the diameter of your cylinder. Alternatively, you can compute CD as: CD = (Force)/(1/2 * rho V^2 * wettedArea)=(Drag)/(1/2 * rho * v^2 * (z-depth)*pi*S). By S I mean your S. I hope this helps, Alessandro More Proof: Forces.C if Turbulence Model is on: Code:
scalar pRef = pRef_/rho(p); forAllConstIter(labelHashSet, patchSet_, iter) { label patchI = iter.key(); vectorField Md ( mesh.C().boundaryField()[patchI] - coordSys_.origin() ); // pressure force vectorField fN ( rho(p)*Sfb[patchI]*(p.boundaryField()[patchI] - pRef) ); //viscous force //inner product of Surface Normal of boundary cells and devReff even though here it is devRhoReff vectorField fT(Sfb[patchI] & devRhoReffb[patchI]); vectorField fP(Md.size(), vector::zero); applyBins(Md, fN, fT, fP, mesh.C().boundaryField()[patchI]); } } and here is my new Drag Coefficient in OpenFoam: Cd = 0.019851 Many thanks to every one. Case closed. Best regards Shereez |
waves, forces and the pressure field with OpenFoam 1.6-ext | maxonline | OpenFOAM | 1 | March 9, 2017 06:37 |
Pressure and density values to compute forces | fernexda | OpenFOAM Post-Processing | 2 | March 6, 2015 03:39 |
Calculate forces without hydrostatic pressure | geir_oye | FLUENT | 4 | November 12, 2009 09:12 |
Forces viscous calculation in VWT with OpenFOAM 15x | terrybarnaby | OpenFOAM Running, Solving & CFD | 0 | November 28, 2008 08:39 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
