Unsteady field advected by steady velocity field
Like Tree1Likes
  • 1 Post By akidess
Old   November 15, 2015, 20:07
Default Unsteady field advected by steady velocity field
Thomas Oliveira
t.oliveira is on a distinguished road
Dear all,
I want to solve the time-dependent advection-diffusion equation of a concentration that is advected by a velocity field which is the steady-state solution of a creeping flow problem. I need to solve both for the steady-state velocity field and the time-dependent concentration field, but I am not sure what is the best strategy to do that using OpenFOAM.
One approach would be to solve a single time-dependent problem involving both fields, as if both were unsteady. However, I guess that solving first for the velocity and then for the concentration would be computationally more efficient that recomputing the steady-state velocity field at every timestep.
Could you please share you thoughts on it?
Thank you for your attention.
t.oliveira is offline   Reply With Quote
Old   November 16, 2015, 02:53
akidess's Avatar
Anton Kidess
Compute velocity field with simpleFoam, concentration transport with scalarTransportFoam.
t.oliveira likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   December 28, 2015, 14:42
Thomas Oliveira
Thank you, Anton. It worked.
advection-diffusion, steady and unsteady state
Reading Velocity field every time step alib022 OpenFOAM Programming & Development 19 December 23, 2019 19:42
conservative form twoPhaseEulerFoam23x gives an unsatisfactory velocity result. sharonyue OpenFOAM Running, Solving & CFD 12 April 10, 2016 00:30
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY everest20 FLUENT 1 July 13, 2015 09:35
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 19:44
Steady needs unsteady. nico Main CFD Forum 0 September 21, 2007 05:50
