mechanism for non-premixed methane air combustion |
November 10, 2015, 15:20 |
Amir
Rep Power: 11 |
Hi.
I want to validate an experimental data about methane combustion with reactingFoam. exactly I am trying to validate data given by " S. J. BROOKES and J. B. MOSS (Measurements of Soot Production and Thermal Radiation From Confined Turbulent Jet Diffusion Flames of Methane )" but I am new with openFoam and need your help. please tell me which combustion mechanism is better for a non-premixed methane and air. I searched in web and found GRI mech 3.0. but I don't know this is for premix or non-premix ? thanks. Asadi. |
November 11, 2015, 05:58 |
Amir
Rep Power: 11 |
No one can help ?
November 17, 2015, 14:32 |
Refik
Rep Power: 11 |
Well i do not know what version of openfoam you are currently using, but i suggest you start with the tutorial file, counterflowflame2d. It is located in the combustion tutorials and you can run a simulation with reactingFoam.
counterflow diffusion flame is a type of non-premixed flow and the current model in the tutorial uses CH4 as fuel and air as oxidiser. GRI 3.0 mechanism is related to the chemical steps that occurs during the combustion and i think you can somehow upload a mechanism form other sources, such as CHEMKIN, but then again it is some you'll just have search for. reactingFoam uses ideal gas relations for species and mixtures. You can inspect the geomtery and mesh and can create your own diffusion flame configuration, where you're gonna have to also change the boundary and initial conditions. |
November 18, 2015, 06:56 |
Amir
Rep Power: 11 |
Hi Refik. thanks for your reply.
I am using openFoam 2.4.0 and trying to validate an experimental data As I noted in the first post. for the beginning I used the one step reaction given in counterflowflame2d tutorial but the result was not good at all and in temperature profiles there was a difference about 400 degree. I tried to change other settings such as schemes but No significant change occurred. so I think methane one step reaction is not accurate enough for this validation. I found GRI mech 3.0 but it needs much time for convergence. because it solves 357 mechanism instead of one and yet I don't know GRI mech 3.0 is for premixed or non-premixed ?? can you tell me whether there is another mechanism with fewer reactions for non-premixed methane combustion? thanks for your attention. Asadi |
December 17, 2015, 05:26 |
Xu Huang
Rep Power: 11 |
Hi Asadi,
There is a skeletal mechanism for methane combustion, 17 species and 25 reactions. you can search for Smooke and Giovangigli (1991). success, Xu |
January 27, 2016, 04:22 |
Amir
Rep Power: 11 |
Hi.
thanks a lot huang. that was helpful. now I have another question. I found a two step reaction but I don't know how I must define it in foamChemistryFile. here is the two step mechanism : CH4 + 1.5O2→ CO + 2H2O Parameters: A = 1.59e13 , Ea = 4.78e4 , [CH4 ]0.7 , [O2]0.8 CO + 0.5O2 = CO2 Forward rate parameters: A = 3.98e14 , Ea = 4.07e4 , [CO]1.0 , [H2O]0.5 , [O2]0.25 Backward rate parameters: A = 5×e8, Ea = 4.07e4, [CO2]1.0 please help me how I must define it with considering that second reaction has different parameters for forward and backward. thanks. Asadi. |
October 14, 2016, 15:57 |
Chris Cloney
Rep Power: 10 |
Hi Asadi,
did you have any luck implementing the two-step mechanism? I would be interested in your result if you got it working. Looking at the reaction file for the counterFlowFlame tutorial of reactingFoam, the pre-exponential is higher than any I have ever seen. My guess is that it is just using "fast" chemistry as it is a diffusion limited. There is a second methane reaction file in the simplifiedSiwek tutorial for coalChemistryFoam which I am using now. I think the values are better for premixed combustion but am testing it now. |
October 14, 2016, 16:02 |
Chris Cloney
Rep Power: 10 |
Also, does anyone recognize this global mechanism from simplifiedSiwek?
reactions { methaneReaction { type irreversibleArrheniusReaction; reaction "CH4 + 2O2^1.0 = CO2 + 2H2O^1.0"; A 7e+06; beta 0; Ta 10063.8; } hydrogenReaction { type irreversibleArrheniusReaction; reaction "H2 + 0.5O2^1.0 = H2O"; A 4.74342e+12; beta 0; Ta 10063.8; } } I am just wondering if anyone knows the paper/textbook reference? Thanks! |
combustion model in premixed combustion chamber | wuyu | FLUENT | 9 | February 16, 2018 10:40 |
Augmented reduced mechanism for methane by J.-Y. Chen | Hagen | OpenFOAM Programming & Development | 2 | May 3, 2016 02:59 |
Arrhenius coefficients for methane air single step combustion | a.Asadi | OpenFOAM Pre-Processing | 0 | August 20, 2015 03:43 |
Modelling for premixed combustion using fluent | RICHARDYW | FLUENT | 0 | July 10, 2015 13:22 |
the mechanism of C3H8 combustion in air | yamu | CFX | 0 | October 16, 2003 10:33 |
