volumetricFlowRate tableFile
Like Tree1Likes
  • 1 Post By fengjq
Old   November 5, 2015, 19:53
Default volumetricFlowRate tableFile
James Feng
fengjq is on a distinguished road
I was using OpenFOAM 2.3.0 with U bc for inlet as
type flowRateInletVelocity;
volumetricFlowRate tableFile;
tableFileCoeffs
fileName"$FOAM_CASE/inlet-time";
outOfBounds repeat;
value uniform (0 0 0);
which worked well. But when I installed newer OpenFOAM 2.4.x, it stopped running with a message of "keyword volumetricFlowRateCoeffs is undefined in dictionary .../U.boundaryField.inlet"
Does anybody know what went wrong in the newer versions of OpenFOAM? I would expect some kind of settings or keywords have changed in OF24x to cause this problem. Any suggestions are welcome.
Thanks a lot.
fengjq is offline   Reply With Quote
Old   November 6, 2015, 05:52
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi
Not 100% sure but the error message would suggest you would have to rename tableFileCoeffs to volumetricFlowRateCoeffs and it should work.
Regards,
Tom
tomf is offline   Reply With Quote
Old   November 6, 2015, 10:08
James Feng
Originally Posted by tomf View Post
Hi
Regards,
Tom
That was it! Thanks a lot, Tom. I certainly need to learn how to read the error message. So far, I've been assuming the message to be too hard to understand and never bothered to look carefully. Your answer taught me otherwise. Thank you.
Yage likes this.
import tableFile to OF kpax OpenFOAM Programming & Development 2 October 8, 2012 07:49
