Automatically write Mach number field during runtime
Like Tree1Likes
  • 1 Post By MikeC
Old   November 5, 2015, 12:14
Default Automatically write Mach number field during runtime
daharn is on a distinguished road
Hey,
I am using sonicFoam on OF 2.1 and when I would like to calculate the Mach number in my domain I simply run
Mach
However, this is tedious and also problematic when I examine a running case via paraview, because I would have to run
Mach -latestTime
whenever a new time folder is written.
Is it possible to tell OF to calculate the Mach field at every write interval during runtime?
I have already tried to add a
systemCall
writeCalls 1( "Mach -latestTime");
to
controlDict
This should work for composed cases but won't work very well when running in parallel, since I would have to hardcode the root directories for each instance.
Am I missing something? Is there a better way?
daharn is offline   Reply With Quote
Old   August 17, 2019, 21:55
Dumbledore
hemanthgrylls is on a distinguished road
I am also looking for the same
please kindly let me know if you know the solution
hemanthgrylls is offline   Reply With Quote
Old   August 23, 2019, 01:43
Mike
MikeC is on a distinguished road
Functional objects can be added to the controlDict, such as:
functions
    MachNumber
        type                       MachNo;
        libs                        ("libfieldFunctionObjects.so");
        executeControl     timeStep;
        writeControl          writeTime;
TommyGun likes this.
MikeC is offline   Reply With Quote
Old   August 23, 2019, 04:11
Carlo_P
Carlo_P is on a distinguished road
Hey All,
if you need the MachNumber only for last iteration, (or for old simulations) you can also create a new controldict file (such as postDict), with all the standard entry and the functionObjects and run "application -postProcessing"
Cheers,
Carlo
Carlo_P is offline   Reply With Quote
mach, post processing, sonicfoam, systemcall
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
