Diffusion number in chtMultiRegionFoam
Like Tree3Likes
  • 3 Post By Heyheymymy
Old   October 20, 2015, 11:30
Default Diffusion number in chtMultiRegionFoam
Adrien
Heyheymymy is on a distinguished road
Hello OpenFoam Community,
I am using the chtMultiRegionFoam solver to simulate the heat transfer between two solid layers with different materials properties (no fluid).
I have a question concerning the Diffusion number definition and its use to control the time step adjustment in the chtMultiRegionSolver.
Looking at the source file, I found that unlike the Courant number, the Diffusion Number has dimension. It has a length dimension and is defined as DiNum = thermal diffusivity * timeStep / Length
As a consequence, I am a bit confused when trying to give a target value for this number for the adjustTimeStep option.
In the tutorials the maximum value (maxDi) is set to 10. Is this valid for any case ? Does it depends on the mesh size?
Thank you very much for your help regarding this matter,
Adrien
Artur.Ant, Kummi and Bobby02 like this.
Heyheymymy is offline   Reply With Quote
Old   April 17, 2020, 09:37
Arthur
Artur.Ant is on a distinguished road
I think it depends on the case.
In laminar simulation (of a small heat sink), considering natural convection I didn't notice any difference in using maxDi=10 or maxDi=60 with maxCo =0.3.
After the same number of iterations the solution in both cases converged to the same result.
Artur.Ant is offline   Reply With Quote
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
What is the influence of Courant number, the diffusion number and the Péclet number.. bilal8700 Main CFD Forum 1 May 4, 2014 04:37
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
