interDyMFoam: 0 split points out of a possible 0
Like Tree1Likes
  • 1 Post By nimasam
Old   October 16, 2015, 01:24
Default interDyMFoam: 0 split points out of a possible 0
Elham
Elham is on a distinguished road
I run interDyMFoam in parallel and the speed of the simulation is too low. I have got the following commands in Terminal:
Selected 0 split points out of a possible 0.
MULES: Solving for alpha.water
Phase-1 volume fraction = 2.111971e-05 Min(alpha1) = -9.115508e-11 Max(alpha1) = 0.9973917
GAMG: Solving for p_rgh, Initial residual = 0.1724118, Final residual = 0.0001625687, No Iterations 14
time step continuity errors : sum local = 8.833984e-08, global = -9.787229e-13, cumulative = -6.119188e-09
GAMG: Solving for p_rgh, Initial residual = 0.0005972664, Final residual = 9.553637e-07, No Iterations 152
time step continuity errors : sum local = 5.05861e-10, global = -3.284247e-14, cumulative = -6.119221e-09
ExecutionTime = 71870.98 s ClockTime = 72155 s
I am a bit suspicious about the sentence :"Selected 0 split points out of a possible 0."
Is there any comment for it?
Thanks
Elham is offline   Reply With Quote
Old   October 18, 2015, 07:16
Nima Samkhaniani
nimasam is on a distinguished road
dont worry, it says no cell is selected for refinement
Elham likes this.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   October 29, 2019, 06:11
krishna kant
kk415 is on a distinguished road
Hello Foamers
I am solving a static bubble problem as the interface is stationary I am getting the following oscillation of grid refinement in my problem.
Courant Number mean: 0.000412997 max: 0.00743201
Interface Courant Number mean: 0.00014211 max: 0.00743201
deltaT = 0.0075
Selected 8 cells for refinement out of 1640.
Refined from 1640 to 1696 cells.
Selected 0 split points out of a possible 96.
Execution time for Level Set Mesh Update = 0.01 s
Defining the group of the cells
Time = 0.9
PIMPLE: iteration 1
Phase-1 volume fraction = 0.121094 Min(alpha.water) = 6.04327e-97 Max(alpha.water) = 1
solve the reinitialization equation
Interpolation of psi from coarser to finer mesh
Solve the modified reinitialization equation in finer mesh
Interpolation from finer to coarser mesh
DICPCG: Solving for p_rgh, Initial residual = 0.0625893, Final residual = 9.72881e-09, No Iterations 43
time step continuity errors : sum local = 1.38529e-12, global = -9.95595e-22, cumulative = -3.9015e-21
ExecutionTime = 1.76 s ClockTime = 1 s
Courant Number mean: 0.00040352 max: 0.00737728
Interface Courant Number mean: 0.000140431 max: 0.00737728
deltaT = 0.0075
Selected 0 cells for refinement out of 1696.
Selected 8 split points out of a possible 96.
Unrefined from 1696 to 1640 cells.
Time = 0.9075
how can I resolve this issue ?
kk415 is offline   Reply With Quote
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 04:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? ANT ANSYS Meshing & Geometry 2 July 23, 2012 16:25
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
