September 29, 2015, 05:48 |
twoPhaseEulerFoam fvOptions for alpha
Laurien Vandewalle
Rep Power: 13 |
Hi everybody!
I am looking for a way to introduce particles via the fvOptions semiImplicitSource option. However, this doesn't work directly because fvOptions is not available in the alphaEqn (found in the file twoPhaseSystem.C). There is however the following piece of code in twoPhaseEulerFoam.C: Code:
volScalarField contErr1 ( fvc::ddt(alpha1, rho1) + fvc::div(alphaRhoPhi1) - (fvOptions(alpha1, rho1)&rho1) ); volScalarField contErr2 ( fvc::ddt(alpha2, rho2) + fvc::div(alphaRhoPhi2) - (fvOptions(alpha2, rho2)&rho2) ); Kind regards, Laurien |
September 30, 2015, 04:41 |
#2 | |
Gerhard Holzinger
Rep Power: 28 |
What fvOptions offers is a mass source to introduce the dispersed phase into the domain. Have a look on the injection tutorial case of the twoPhaseEulerFoam tutorials. |
October 1, 2015, 17:34 |
Laurien Vandewalle
Rep Power: 13 |
That was what I meant, I did know that there are no actual particles in the Eulerian models but I was looking for a way to introduce the dispersed phase, as in the tutorial Thanks for the tip!
In the tutorial the mass source is added in the rhoEqn, at least that is what I understand from the following piece of code in the fvOptions file. Code:
massSource1 { type scalarSemiImplicitSource; $injector1; scalarSemiImplicitSourceCoeffs { volumeMode absolute; injectionRateSuSp { thermo:rho.air (1e-3 0); // kg/s } } } |
October 2, 2015, 04:32 |
Gerhard Holzinger
Rep Power: 28 |
I get your point. However, in twoPhaseEulerFoam, there is no transport equation solved for rho. There is the alpha equation to compute the volume fraction, the momentum equation to compute the velocities, the pressure equation to resolve the pressure-velocity coupling and the energy equation to solve for the internal energy/enthalpy which in turn determines the temperature.
The density rho is computed from your selected equation of state, e.g. rho = rho(p,T). Somehow, specifying a source for thermo:rho.air ends up being a source for the phase air. I frequenty run simulations which are based on the injection tutorial of twoPhaseEulerFoam. |
October 16, 2015, 04:36 |
Laurien Vandewalle
Rep Power: 13 |
Thanks for your explanation, I understand now
However, I still have some troubles with the simulations. When I introduce my dispersed phase using the mass source (injection of thermo::rho.particles) in fvOptions, the solver calculates negative temperatures already from the first time step. I want to add my dispersed phase with zero momentum so I don't have to add a momentum source in fvOptions. But how do I tell my solver that the dispersed phase is introduced at a certain temperature? I tried with an injection of thermo::T.particles, or thermo::h.particles, but this doesn't seem to work... Any help? |
October 16, 2015, 07:00 |
Gerhard Holzinger
Rep Power: 28 |
The injection tutorial of twoPhaseEulerFoam has a source for the internal energy. Depending whether you solve for the internal energy or the enthalpy, you need to specify an appropriate source.
October 19, 2015, 10:26 |
Laurien Vandewalle
Rep Power: 13 |
Hi!
Thanks for the answer. I still have some problems. In order to speed up the calculation, I am not solving the energy equation because temperatures are not really important for my simulation. The case is running but the values for alpha are not bounded between 0 and 1, meaning that unphysical results are produced. Below is a small part of my log-file. Code:
Create time Create mesh for time = 0.1 Reading g Creating twoPhaseSystem Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading face flux field phi.air Selecting diameterModel for phase air: constant Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleInternalEnergy; } Reading face flux field phi.particles Selecting diameterModel for phase particles: constant Selecting turbulence model type RAS Selecting RAS turbulence model kineticTheory Selecting viscosityModel Gidaspow Selecting conductivityModel Gidaspow Selecting radialModel SinclairJackson Selecting granularPressureModel Lun Selecting frictionalStressModel JohnsonJackson kineticTheoryCoeffs { equilibrium off; e 0.9; alphaMax 0.63; alphaMinFriction 0.5; residualAlpha 0.0001; viscosityModel Gidaspow; conductivityModel Gidaspow; granularPressureModel Lun; frictionalStressModel JohnsonJackson; radialModel SinclairJackson; JohnsonJacksonCoeffs { Fr 0.05; eta 2; p 5; phi 30; } } Selecting default blending method: none Selecting dragModel for (particles in air): GidaspowErgunWenYu Selecting swarmCorrection for (particles in air): none Selecting swarmCorrection for (particles in air): none Selecting swarmCorrection for (particles in air): none Selecting heatTransferModel for (particles in air): RanzMarshall Calculating field DDtU1 and DDtU2 Creating field dpdt Creating field kinetic energy K No MRF models present Creating finite volume options from "system/fvOptions" Selecting finite volume options model type scalarSemiImplicitSource Source: massSource1 - applying source at time 0.1 for duration 0.15 - selecting cells using cellSet c0 - selected 27825 cell(s) with volume 9.04545e-05 Selecting finite volume options model type scalarSemiImplicitSource Source: energySource1 - applying source at time 0.1 for duration 0.15 - selecting cells using cellSet c0 - selected 27825 cell(s) with volume 9.04545e-05 Courant Number mean: 0.894556 max: 10.2645 Max Ur Courant Number = 10.2644 PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Starting time loop Courant Number mean: 0.894556 max: 10.2645 Max Ur Courant Number = 10.2644 Time = 0.10002 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0, Final residual = 0, No Iterations 1 alpha.air volume fraction = 1 Min(alpha.air) = 1 Max(alpha.air) = 1 smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.particles, Initial residual = 1, Final residual = 1, No Iterations 0 min T.air 300 min T.particles 300 GAMG: Solving for p, Initial residual = 0.00212471, Final residual = 4.74626e-06, No Iterations 2 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0.000914294, Final residual = 3.41217e-11, No Iterations 3 alpha.air volume fraction = 0.999982 Min(alpha.air) = 0.999166 Max(alpha.air) = 1 smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.particles, Initial residual = 1, Final residual = 1, No Iterations 0 min T.air 300 min T.particles 300 GAMG: Solving for p, Initial residual = 0.00176224, Final residual = 7.87692e-09, No Iterations 8 smoothSolver: Solving for epsilon.air, Initial residual = 0.0013402, Final residual = 3.68387e-06, No Iterations 4 bounding epsilon.air, min: -1.71626e+06 max: 5.58129e+07 average: 418414 smoothSolver: Solving for k.air, Initial residual = 0.000176795, Final residual = 4.68494e-06, No Iterations 3 smoothSolver: Solving for Theta.particles, Initial residual = 0.98061, Final residual = 0.915433, No Iterations 50 ExecutionTime = 9.1 s Courant Number mean: 0.894554 max: 10.1871 Max Ur Courant Number = 10.187 Time = 0.10004 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0.0517544, Final residual = 7.89374e-10, No Iterations 24 alpha.air volume fraction = 0.999964 Min(alpha.air) = 0.998058 Max(alpha.air) = 1 smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.particles, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 0 min T.air 300 min T.particles 300 GAMG: Solving for p, Initial residual = 0.00209044, Final residual = 3.44639e-06, No Iterations 2 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0.00804932, Final residual = 2.84439e-10, No Iterations 6 alpha.air volume fraction = 0.999964 Min(alpha.air) = 0.998016 Max(alpha.air) = 1.00002 smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.particles, Initial residual = 1, Final residual = 1, No Iterations 0 min T.air 300 min T.particles 300 GAMG: Solving for p, Initial residual = 0.00174703, Final residual = 9.91089e-09, No Iterations 7 smoothSolver: Solving for epsilon.air, Initial residual = 0.00114242, Final residual = 3.54856e-06, No Iterations 4 smoothSolver: Solving for k.air, Initial residual = 0.000172632, Final residual = 5.04051e-06, No Iterations 3 smoothSolver: Solving for Theta.particles, Initial residual = 0.136171, Final residual = 0.0133347, No Iterations 50 ExecutionTime = 14.52 s Courant Number mean: 0.894521 max: 10.1377 Max Ur Courant Number = 10.1377 Time = 0.10006 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0.00836022, Final residual = 8.33284e-10, No Iterations 6 alpha.air volume fraction = 0.999946 Min(alpha.air) = 0.996837 Max(alpha.air) = 1 smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.particles, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 0 min T.air 300 min T.particles 300 GAMG: Solving for p, Initial residual = 0.00211449, Final residual = 3.87352e-06, No Iterations 2 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0.0108336, Final residual = 4.31534e-10, No Iterations 6 alpha.air volume fraction = 0.999946 Min(alpha.air) = 0.997032 Max(alpha.air) = 1.00002 smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.particles, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 0 min T.air 300 min T.particles 300 GAMG: Solving for p, Initial residual = 0.00179842, Final residual = 6.10722e-09, No Iterations 8 smoothSolver: Solving for epsilon.air, Initial residual = 0.00182793, Final residual = 9.80215e-06, No Iterations 6 bounding epsilon.air, min: -762705 max: 4.41792e+07 average: 418205 smoothSolver: Solving for k.air, Initial residual = 0.000195834, Final residual = 8.3906e-06, No Iterations 3 smoothSolver: Solving for Theta.particles, Initial residual = 0.0373695, Final residual = 0.006441, No Iterations 50 ExecutionTime = 19.92 s Courant Number mean: 0.894453 max: 10.275 Max Ur Courant Number = 10.2749 Time = 0.10008 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0.0107024, Final residual = 3.82048e-10, No Iterations 6 alpha.air volume fraction = 0.999929 Min(alpha.air) = 0.995972 Max(alpha.air) = 1 smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.particles, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 0 min T.air 300 min T.particles 300 GAMG: Solving for p, Initial residual = 0.00216317, Final residual = 3.32473e-06, No Iterations 2 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0.0122464, Final residual = 3.83729e-10, No Iterations 6 alpha.air volume fraction = 0.999929 Min(alpha.air) = 0.99613 Max(alpha.air) = 1.00024 smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.particles, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 0 min T.air 300 min T.particles 300 GAMG: Solving for p, Initial residual = 0.00184023, Final residual = 5.20187e-09, No Iterations 8 smoothSolver: Solving for epsilon.air, Initial residual = 0.0012377, Final residual = 4.01932e-06, No Iterations 4 bounding epsilon.air, min: -1.93643e+06 max: 7.05816e+07 average: 417772 smoothSolver: Solving for k.air, Initial residual = 0.000181734, Final residual = 5.3518e-06, No Iterations 3 smoothSolver: Solving for Theta.particles, Initial residual = 0.0203782, Final residual = 0.00309259, No Iterations 50 ExecutionTime = 25.41 s Courant Number mean: 0.894361 max: 10.2392 Max Ur Courant Number = 10.2392 Time = 0.1001 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0.011217, Final residual = 2.80122e-10, No Iterations 6 alpha.air volume fraction = 0.999911 Min(alpha.air) = 0.995283 Max(alpha.air) = 1 smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.particles, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 0 min T.air 300 min T.particles 300 GAMG: Solving for p, Initial residual = 0.00221309, Final residual = 3.29251e-06, No Iterations 2 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0.0130764, Final residual = 3.23792e-10, No Iterations 6 alpha.air volume fraction = 0.999911 Min(alpha.air) = 0.995308 Max(alpha.air) = 1.00058 smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.particles, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 0 min T.air 300 min T.particles 300 GAMG: Solving for p, Initial residual = 0.00189597, Final residual = 6.3676e-09, No Iterations 8 smoothSolver: Solving for epsilon.air, Initial residual = 0.00165239, Final residual = 8.80676e-06, No Iterations 6 bounding epsilon.air, min: -557530 max: 4.30925e+07 average: 417572 smoothSolver: Solving for k.air, Initial residual = 0.000191587, Final residual = 8.49417e-06, No Iterations 3 smoothSolver: Solving for Theta.particles, Initial residual = 0.0137528, Final residual = 0.0016478, No Iterations 50 ExecutionTime = 31.1 s Courant Number mean: 0.894234 max: 10.2039 Max Ur Courant Number = 10.2038 Time = 0.10012 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0.0117368, Final residual = 2.3449e-10, No Iterations 6 alpha.air volume fraction = 0.999893 Min(alpha.air) = 0.994339 Max(alpha.air) = 1 smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.particles, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 0 min T.air 300 min T.particles 300 GAMG: Solving for p, Initial residual = 0.00227574, Final residual = 3.40033e-06, No Iterations 2 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air smoothSolver: Solving for alpha.air, Initial residual = 0.0137336, Final residual = 2.894e-10, No Iterations 6 alpha.air volume fraction = 0.999893 Min(alpha.air) = 0.994004 Max(alpha.air) = 1.00123 Have you already encountered this issue? |
October 19, 2015, 10:55 |
Gerhard Holzinger
Rep Power: 28 |
Do you intend to have a Courant number of 10?
Try a smaller time step, to reach a Courant number smaller than one half, or one. Also solver output like the following indicates that something unpleasant is going on: bounding epsilon.air, min: -1.71626e+06 max: 5.58129e+07 average: 418414 |
October 19, 2015, 10:57 |
#9 |
Laurien Vandewalle
Rep Power: 13 |
I tried that already, but the same thing happens: alpha.air becomes larger than one already after a few time steps...
Can I use fvOptions to couple a solid region and a fluid region? | titanchao | OpenFOAM Running, Solving & CFD | 4 | January 14, 2022 08:55 |
twoPhaseEulerFoam and complex geometry | bsoubelet | OpenFOAM Running, Solving & CFD | 7 | July 2, 2015 11:50 |
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? | ThomasV | OpenFOAM | 0 | November 11, 2013 09:10 |
[swak4Foam] Setting BC for a passive scalar (groovy vs fvOptions) | Tobi | OpenFOAM Community Contributions | 0 | May 23, 2013 15:53 |
twoPhaseEulerFoam | freemankofi | OpenFOAM | 0 | May 23, 2011 17:24 |
