fsiFoam. 3dTube. boundary conditions
Like Tree1Likes
  • 1 Post By GLinaker
Old   September 10, 2015, 17:31
Default fsiFoam. 3dTube. boundary conditions
Svensen is on a distinguished road
Hi, with default boundary conditions for fluid:
U:
inlet - zeroGradient
outlet - zeroGradient;
p:
inlet - timeVaryingUniformFixedValue
outlet - fixedValue
simulation of 3dTube tutorials works well.
But when I try to make a velocity driven BC's for this tutorial like:
U:
inlet - fixedValue
p:
outlet - fixedValue
my simulation crashes. Maybe someone faced with this problem. I really don't know why it's happens. There is no problem with Courant number. It seems to me that I need to correct some BC's but I don't know what to do... Any suggestions ?
Thanks.
Svensen is offline   Reply With Quote
Old   November 3, 2015, 11:27
Case file is here https://yadi.sk/d/D7JeTvf3kD9x4
Old   November 13, 2015, 11:52
ok
Maimouna is on a distinguished road
Dear Svensen,
did you solve your problem? I wouldn't be able to open your file case.
Maimouna is offline   Reply With Quote
Old   November 24, 2015, 05:59
I have not solved this problem yet. What is a problem with opening my case files ?
Old   November 26, 2015, 07:03
ok
Hi Sevense,
what type of error you got when you changed the original case boundary conditions to your case.
I tried your case to see what type of error, but the case blown up with the error shown in fsi log file, screenshot attached. What's your error? and what is mine mistake to get that error?
Maimouna
File Type: jpg Screenshot from 2015-11-26 10:54:51.jpg (81.1 KB, 79 views)
Old   December 1, 2015, 16:35
Maybe there is some difference in foam-extend versions. When I download this case and run it on my computer there is no error with inner-wall-zone
Old   July 4, 2018, 08:46
dhanesh mourya
dhaneshmourya is on a distinguished road
you have to add setBatch file in solid and fluid folder.
In fluid add,
faceSet wall-zone new patchToFace wall,
and for solid
faceSet innerwall-zone new patchToFace innerwall
dhaneshmourya is offline   Reply With Quote
Old   January 29, 2019, 06:25
George Linaker
GLinaker is on a distinguished road
U:
p:
outlet - fixedValue
U:
inlet - fixedValue
p:
outlet - fixedValue
Thanks.
I’ve got a similar issue to the Svenson post, the fsiFoam 3dTube tutorial case crashes when changing the inlet to be prescribed in terms of velocity rather than pressure. It’s a floating point exception error, was a solution found to this problem?
Gunther_123 likes this.
GLinaker is offline   Reply With Quote
boundary conditions, foam-extend-3.1, fsi
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
