Kalyan Peri
Rep Power: 11 ![]() |
Hi all,
i am trying to simulate a multiphase euler-lagrangian case with assumption of incompressible flow. so i created a solver by merging pimpleFoam and icoUncoupledKinematicFoam. The solver is running fine. But my case it is running fine till certain time and is suddenly blowing up. There is sudden increase in LineaMomentum of Particles.. Any help is greatly appreciated Code:
Courant Number mean: 0.04043413 max: 0.4999354 deltaT = 4.509583e-06 Time = 0.148758 smoothSolver: Solving for Ux, Initial residual = 1.557579e-05, Final residual = 7.167363e-07, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.0001077576, Final residual = 4.33946e-06, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1.515668e-05, Final residual = 7.043948e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 0.01890968, Final residual = 0.0007671708, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0007673827, Final residual = 6.345403e-05, No Iterations 3 time step continuity errors : sum local = 2.1412e-09, global = -4.2204e-10, cumulative = -1.454082e-07 GAMG: Solving for p, Initial residual = 0.001474408, Final residual = 0.0001064657, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0001064498, Final residual = 8.128193e-07, No Iterations 8 time step continuity errors : sum local = 2.742942e-11, global = -8.07545e-12, cumulative = -1.454163e-07 smoothSolver: Solving for omega, Initial residual = 8.999363e-06, Final residual = 8.999363e-06, No Iterations 0 smoothSolver: Solving for k, Initial residual = 1.068478e-05, Final residual = 6.815941e-07, No Iterations 1 bounding k, min: 1e-20 max: 19.51322 average: 7.276739 Evolving kinematicCloud Solving 3-D cloud kinematicCloud Cloud: kinematicCloud Current number of parcels = 8184 Current mass in system = 3.82134e-05 Linear momentum = (4.013661e-05 -0.0002115916 -3.440463e-05) |Linear momentum| = 0.0002180955 Linear kinetic energy = 0.2790673 model1: number of parcels added = 12085 mass introduced = 5.646226e-05 Parcels absorbed into film = 0 New film detached parcels = 0 Parcel fate (number, mass) : patch fixedWalls - escape = 0, 0 - stick = 3191, 1.489793e-05 Parcel fate (number, mass) : patch upperWall - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch sideWalls - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch outlet - escape = 3901, 1.824887e-05 - stick = 0, 0 Parcel fate (number, mass) : patch baffleFaces_master - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch baffleFaces_slave - escape = 0, 0 - stick = 0, 0 Rotational kinetic energy = 0 ExecutionTime = 94879.29 s ClockTime = 97483 s Courant Number mean: 0.04043416 max: 0.4999354 deltaT = 4.509583e-06 Time = 0.148762 smoothSolver: Solving for Ux, Initial residual = 0.008377172, Final residual = 5.821064e-06, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.006608096, Final residual = 5.01418e-06, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.006809619, Final residual = 4.746882e-06, No Iterations 2 GAMG: Solving for p, Initial residual = 0.9900283, Final residual = 0.06366995, No Iterations 3 GAMG: Solving for p, Initial residual = 0.03142656, Final residual = 0.002906337, No Iterations 6 time step continuity errors : sum local = 1.959254e-05, global = -5.515908e-06, cumulative = -5.661324e-06 GAMG: Solving for p, Initial residual = 0.0770012, Final residual = 0.006030893, No Iterations 4 GAMG: Solving for p, Initial residual = 0.006325515, Final residual = 7.318672e-07, No Iterations 22 time step continuity errors : sum local = 4.418537e-09, global = -4.954527e-10, cumulative = -5.66182e-06 smoothSolver: Solving for omega, Initial residual = 0.01988505, Final residual = 6.423435e-06, No Iterations 10 smoothSolver: Solving for k, Initial residual = 0.006081979, Final residual = 7.021702e-06, No Iterations 3 bounding k, min: 1e-20 max: 38.73186 average: 7.280719 Evolving kinematicCloud Solving 3-D cloud kinematicCloud Cloud: kinematicCloud Current number of parcels = 8184 Current mass in system = 3.82134e-05 Linear momentum = (-1.563558e+136 -3.405907e+135 1.572105e+136) |Linear momentum| = 2.243263e+136 Linear kinetic energy = 4.816419e+280 model1: number of parcels added = 12085 mass introduced = 5.646226e-05 Parcels absorbed into film = 0 New film detached parcels = 0 Parcel fate (number, mass) : patch fixedWalls - escape = 0, 0 - stick = 3191, 1.489793e-05 Parcel fate (number, mass) : patch upperWall - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch sideWalls - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch outlet - escape = 3901, 1.824887e-05 - stick = 0, 0 Parcel fate (number, mass) : patch baffleFaces_master - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch baffleFaces_slave - escape = 0, 0 - stick = 0, 0 Rotational kinetic energy = 0 ExecutionTime = 94884.24 s ClockTime = 97489 s Courant Number mean: 0.0425952 max: 12617.33 deltaT = 1.78706e-10 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1055 Increased the timePrecision from 6 to 7 to distinguish between timeNames at time 0.1487621 Time = 0.1487621 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 2.382181e-08, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 2.382181e-08, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 2.382181e-08, No Iterations 2 [0] [1] #0 Foam::error::printStack(Foam::Ostream&)#[3] #0 Foam::error::printStack(Foam::Ostream&)0 Foam::error::printStack(Foam::Ostream&) in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigHandler(int) in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigHandler(int) in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #1 Foam::sigFpe::sigHandler(int) in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #2 in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #2 in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [3] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gc in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #6 cDPOpt/lib/libOpenFOAM.so" [0] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" [0] #7 in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" [1] #7 in "/root/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" [3] #7 [3] in "/root/OpenFOAM/root-2.3.x/platforms/linux64GccDPOpt/bin/pimpleKinematicFoam" [3] #8 __libc_start_main[0] in "/root/OpenFOAM/root-2.3.x/platforms/linux64GccDPOpt/bin/pimpleKinematicFoam" [0] #8 __libc_start_main[1] in "/root/OpenFOAM/root-2.3.x/platforms/linux64GccDPOpt/bin/pimpleKinematicFoam" [1] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [3] #9 in "/lib/x86_64-linux-gnu/libc.so.6" [0] #9 in "/lib/x86_64-linux-gnu/libc.so.6" [1] #9 [3] in "/root/OpenFOAM/root-2.3.x/platforms/linux64GccDPOpt/bin/pimpleKinematicFoam" Last edited by wyldckat; August 30, 2015 at 17:47. Reason: Added [CODE][/CODE] markers |
Kalyan Peri
I have also attached the importatn case files.. please refer to it. caseFIles.tar.gz
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Greetings kalyan,
I'm answering you here because you sent me a PM asking to look into this. Sorry, but I don't have the time to test the case, specially if the case takes 95000 seconds to run before it crashes. You will have to diagnose this on your side. My guess is that perhaps you're using "cyclicAMI" for the baffles, which has issues in OpenFOAM, up to and including 2.4. The other possibility seems related to a problem in preserving the stability of the flow... did you try to run the case without particles? Because the error is related to this: Code:
Courant Number mean: 0.04043416 max: 0.4999354 deltaT = 4.509583e-06 Time = 0.148762 smoothSolver: Solving for Ux, Initial residual = 0.008377172, Final residual = 5.821064e-06, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.006608096, Final residual = 5.01418e-06, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.006809619, Final residual = 4.746882e-06, No Iterations 2 GAMG: Solving for p, Initial residual = 0.9900283, Final residual = 0.06366995, No Iterations 3 Best regards, Bruno
Kalyan Peri
Greetings Bruno,
Thank you for the reply. The simulation is running fine when the case is simulated without particles. The simulation crashes only when particles are added. I dont know what the error is. Regards, kalyan |
Albrecht vBoetticher
Rep Power: 16 ![]() |
could you try with coupled false; in your kinematciCloudProperties? Did you merge the two solvers using kinematicCloud or kinematicCollidingCloud? I am asking because I guess that your particle-particle or particle-wall contact force goes to infinity. Maybe you could increase the diameter or vary e to make the contact softer.
Kalyan Peri
Hello albrecht,
Thank you for the reply. I merged both the solvers using basicKinematicCollidingCloud. Does the coupled true; in the kinematicCloudProperties mean coupling between particles and continuous phase(2-way coupling)? or particle-particle interaction (4-way coupling)? I would try simulating with couple false; and will update the result. Thank you. Regards, Kalyan |
Hi Kalyan,
As the name says icoUncoupledKinematicFoam is not coupling between the phase flow and the particle, it is for simulating tracers that yust follow the flow. The velocity field of your pimple calculation is yust mapped onto the particles. However, particle-wall and particle-particle interaction is possible. If you want to do the 4-way coupling it gets more complex: Especially if you have more particles, you need to account for the volume fraction of your fluid in the navier-stokes equation. But as long as your particle concentration is less that some 80% you may get a stable solver (although not really correct) with neglecting the volume fraction. But still you need to implement the drag that particles put on your fluid in the UEqn.H with something like tmp<fvVectorMatrix> UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) == fvOptions(U) +invrhoInf*kinematicCloud.SU(U) ); see:http://www.tfd.chalmers.se/~hani/kur...ing_report.pdf or solve ( UEqn == fvc::reconstruct ( ( fvc::interpolate(interface.sigmaK())*fvc::snGrad(a lpha1) //surface tension - ghf*fvc::snGrad(rho) - fvc::snGrad(p_rgh) ) * mesh.magSf() ) + particles.momentumSource() ); see http://www.tfd.chalmers.se/~hani/kur...LPT_120911.pdf or even more sophisticated but for two phase flow: HPDCInterFoam |
Kalyan Peri
Hi Albrecht,
The simulation ran well with out error when i changed coupled false; in the kinematicCloudProperties. I Have used the below code for UEqn to merge pimple and icoUnCoupledKinematicParcelFoam tmp<fvVectorMatrix> UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) == fvOptions(U) +invrhoInf*kinematicCloud.SU(U) ); will recompile the solver using kinematicCloud instead of kinematicCollingCloud, and will check the simulation with coupled ture, in kinematicCloud. Regards, kalyan |
#9 |
siavash
Rep Power: 6 ![]() |
I am new to using openfoam lagrangian models. I was wondering how could I switch injection model from 2D to 3D? Thank you |
coupled solver, kinematic cloud, lagrangian |
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 20:47 |
icoUncoupledKinematicParcelFoam - strange thing | Tobi | OpenFOAM Running, Solving & CFD | 5 | October 5, 2017 08:20 |
inject particles of different densities - kinematiccloud | benz25 | OpenFOAM Pre-Processing | 24 | June 19, 2017 03:49 |
kinematicCloud initialization | alberto | OpenFOAM Running, Solving & CFD | 1 | October 15, 2013 09:56 |
Difference in settings between icoFoam and icoLagrangianFoam | Alexvader | OpenFOAM | 1 | October 4, 2011 19:21 |
