Problem with chtMultiregionFoam radiation boundary condition
Like Tree2Likes
  • 1 Post By zfaraday
Old   August 19, 2015, 06:48
Thumbs down Problem with chtMultiregionFoam radiation boundary condition
baran
baran_foam is on a distinguished road
Greeting all!!!
I have a simple case as follows...in OF 2.4
1. Cavity with heater inside
2. Surrounding this cavity some insulation is there
So I run the radiation case(with view factor model) in chtMultiregionFoam(transient) with interface boundary condition of solid and air..
type            compressible::turbulentTemperatureCoupledBaffleMixed;
        value           uniform 300;
        Tnbr            T;
        kappa           fluidThermo;
        kappaName       none;
Fluid thermo property is tutorial one. It is run completely okay and I run it for around 360 sec then stop that one.Log file after 360 sec is like this...
Region: fluid Courant Number mean: 0.009927002 max: 0.29967996
Region: fibrothal_in Diffusion Number mean: 5.0662336e-08 max: 3.0645162e-07
Region: solid_bricks Diffusion Number mean: 3.3063735e-08 max: 1.7757998e-07
Region: unifrax_out Diffusion Number mean: 1.0011137e-07 max: 3.0843423e-07
deltaT = 0.0010946195
Time = 356.6388
Solving for fluid region fluid
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Ux, Initial residual = 0.00025637481, Final residual = 4.407068e-09, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.00027934907, Final residual = 9.510753e-09, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.0002301347, Final residual = 1.7324477e-09, No Iterations 2
DILUPBiCG:  Solving for h, Initial residual = 3.1476392e-05, Final residual = 7.3471181e-08, No Iterations 1
Min/max T:313.58391 1118
GAMG:  Solving for p_rgh, Initial residual = 8.5854497e-05, Final residual = 9.4845113e-08, No Iterations 7
GAMG:  Solving for p_rgh, Initial residual = 3.5173418e-06, Final residual = 5.4325282e-08, No Iterations 3
GAMG:  Solving for p_rgh, Initial residual = 8.6238562e-07, Final residual = 3.8513529e-08, No Iterations 2
time step continuity errors (fluid): sum local = 6.074565e-10, global = 6.3652211e-13, cumulative = -2.197283e-07
GAMG:  Solving for p_rgh, Initial residual = 1.0315776e-06, Final residual = 3.9160376e-08, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 1.669925e-07, Final residual = 2.9482081e-08, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 6.8532497e-08, Final residual = 6.8532497e-08, No Iterations 0
time step continuity errors (fluid): sum local = 1.080931e-09, global = -4.0250703e-14, cumulative = -2.1972834e-07
Solving for solid region fibrothal_in
DICPCG:  Solving for h, Initial residual = 1.2940158e-06, Final residual = 1.3251284e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.7071703e-12, Final residual = 1.7071703e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 640.55258
Solving for solid region solid_bricks
DICPCG:  Solving for h, Initial residual = 1.0267441e-06, Final residual = 4.8127074e-13, No Iterations 1
DICPCG:  Solving for h, Initial residual = 8.4350547e-13, Final residual = 8.4350547e-13, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 458.84315
Solving for solid region unifrax_out
DICPCG:  Solving for h, Initial residual = 9.9373252e-07, Final residual = 9.9373252e-07, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 303.89972
ExecutionTime = 133423.49 s  ClockTime = 136999 s
Region: fluid Courant Number mean: 0.0099269187 max: 0.29966461
Region: fibrothal_in Diffusion Number mean: 5.0662347e-08 max: 3.0645172e-07
Time = 356.6399
DILUPBiCG:  Solving for Ux, Initial residual = 0.00025636135, Final residual = 4.3780302e-09, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.00027935499, Final residual = 1.0088861e-08, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.00023013524, Final residual = 1.6871542e-09, No Iterations 2
DILUPBiCG:  Solving for h, Initial residual = 3.1473979e-05, Final residual = 7.3570805e-08, No Iterations 1
Min/max T:313.58441 1118
GAMG:  Solving for p_rgh, Initial residual = 8.5834205e-05, Final residual = 9.5254497e-08, No Iterations 7
GAMG:  Solving for p_rgh, Initial residual = 3.5163029e-06, Final residual = 5.4570072e-08, No Iterations 3
GAMG:  Solving for p_rgh, Initial residual = 8.6202952e-07, Final residual = 3.8610652e-08, No Iterations 2
time step continuity errors (fluid): sum local = 6.0899296e-10, global = 6.481879e-13, cumulative = -2.1972769e-07
GAMG:  Solving for p_rgh, Initial residual = 1.0315463e-06, Final residual = 3.9050125e-08, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 1.6693103e-07, Final residual = 2.9416253e-08, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 6.8558156e-08, Final residual = 6.8558156e-08, No Iterations 0
time step continuity errors (fluid): sum local = 1.081336e-09, global = -3.652917e-14, cumulative = -2.1972773e-07
DICPCG:  Solving for h, Initial residual = 1.2940145e-06, Final residual = 1.3250951e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.7071583e-12, Final residual = 1.7071583e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 640.55404
DICPCG:  Solving for h, Initial residual = 1.0267414e-06, Final residual = 4.812706e-13, No Iterations 1
DICPCG:  Solving for h, Initial residual = 8.4350791e-13, Final residual = 8.4350791e-13, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 458.84273
DICPCG:  Solving for h, Initial residual = 9.9373296e-07, Final residual = 9.9373296e-07, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 303.89975
ExecutionTime = 133424 s  ClockTime = 137000 s
Then i changed the boundary condition of fluid and solid interface ..
   type            	compressible::turbulentTemperatureRadCoupledMixed;
        value           uniform 300;
        Tnbr            T;
        kappa               fluidThermo;
        QrNbr           none;
        Qr              Qr;
        kappaName           none;
fvSolution of air is as follows...
solvers
    rho
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-7;
        relTol          0;
    rhoFinal
        $rho;
        tolerance       1e-7;
        relTol          0;
    p_rgh
        solver           GAMG;
        tolerance        1e-7;
        relTol           0;
        smoother         GaussSeidel;
        cacheAgglomeration  true;
        nCellsInCoarsestLevel 10;
        agglomerator     faceAreaPair;
        mergeLevels      1;
    p_rghFinal
        $p_rgh;
        tolerance        1e-7;
        relTol           0;
    "(U|h|k|omega|epsilon|R)"
        solver           PBiCG;
        preconditioner   DILU;
        tolerance        1e-7;
        relTol           0.1;
    "(U|h|k|omega|epsilon|R)Final"
        $U;
        tolerance        1e-7;
        relTol           0;
PIMPLE
    momentumPredictor   on;
    nCorrectors         2;
    nNonOrthogonalCorrectors 2;
relaxationFactors
    fields
        rho             0.1;
        p_rgh           0.1;
    equations
        "h.*"           0.1;
        "U.*"           0.1;
        "(k|epsilon|R)" 0.1;
        G               0.1;
        "ILambda.*"     0.1;
        Qr              0.1;
fvScheme of air air is as follows...
ddtSchemes
    default         Euler;
gradSchemes
    default         cellLimited Gauss linear 1;     //    Gauss linear;
divSchemes
    default         none;
    div(phi,U)       Gauss upwind;
    div(phi,k)       Gauss upwind;
    div(phi,K)       Gauss linear;   // Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,h)       Gauss upwind;
    div(phi,omega)   Gauss upwind;
    div(phi,R)       Gauss upwind;
    div(R)          Gauss linear;
    div(Ji,Ii_h)    Gauss linearUpwind grad(U);
    div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(rhorAUf,p_rgh) Gauss linear limited 0.333;
    laplacian(muEff,U) Gauss linear limited 0.333;
    laplacian((rho*(1|A(U))),p_rgh) Gauss linear limited 0.333;
    laplacian(alphaEff,h) Gauss linear limited 0.333;
    laplacian(DepsilonEff,epsilon) Gauss linear limited 0.333;
    laplacian(DkEff,k) Gauss linear limited 0.333;
    laplacian(DomegaEff,omega) Gauss linear limited 0.333;
    laplacian(DREff,R) Gauss linear limited 0.333;
    laplacian(gammaRad,G) Gauss linear limited 0.333;
interpolationSchemes
    default         linear;
snGradSchemes
    default        limited 0.333;
fluxRequired
    default         no;
    p_rgh;
Initially it is running well but after some iteration it is giving negative value of T in fluid zone ,then it is diverged.....showing
Maximum numbers of iterations exceeded
It is giving in practical results.....
Apart from this bc remaining thing is same for two cases...Is there is a problem with this boundary condition..??
Please suggest something...
baran_foam is offline   Reply With Quote
Old   August 20, 2015, 09:01
Alex
zfaraday will become famous soon enough
Hi baran,
You did good in providing as much information as you could. However, maybe more information might be needed in order to figure out what is going wrong in your case. For instance, you should upload the log file of the run that crashed in order to be able to start guessing things... For how long has it been runing?
In the last cases I run where radaitive heat transfer was taken into account I found out that the balance on patches was somewhat critical in the first time steps. It was due to the sudden variation of the gradients at patches when radiation was computed. However, I never faced this problem with the turbulentTemperatureRadCoupledMixed patch type, but I had some similar issue with thermalBaffle1D and externalWallHeatFluxTemperature instead. The solution to avoid getting a crashed run was to implement a relaxation factor method to prevent the already mentioned problem of gradient variation. You should take a look into the code of these BC's in order to understand what I am talking about, maybe something like that may be usefull. Nevertheless, I recall that I never had this problem with the turbulentTemperatureRadCoupledMixed patch type... Have you used any of the other mentioned patch types in your simulation?
Another advice I give you is that you should try to visualize with paraview the thermal distribution in the last time step before the run crashed. By doing that you could be able to find out what cells are causing the trouble. After that you can start guessing what is going wrong with more accuracy.
I hope my advices will come in handy to you.
Best regards,
Alex
_______________________
Quick update: I worked with chtMultiRegionSimpleFoam solver and radiation was solved with fvDOM method in my case.
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   August 20, 2015, 10:29
baran
This is the log file of that case....from where it is started diverging...
Region: fibrothal_in Diffusion Number mean: 3.7268416e-08 max: 2.2962241e-07
Region: solid_bricks Diffusion Number mean: 2.512897e-08 max: 1.3494945e-07
Region: unifrax_out Diffusion Number mean: 7.6077766e-08 max: 2.3438883e-07
deltaT = 0.00083183564
Time = 73.539995
DILUPBiCG: Solving for Ux, Initial residual = 6.7636734e-05, Final residual = 1.3441408e-08, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 4.6392292e-05, Final residual = 1.0721153e-08, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 6.0782809e-05, Final residual = 8.146975e-09, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1.4442565e-05, Final residual = 1.5485771e-09, No Iterations 1
Min/max T:302.35042 796
GAMG: Solving for p_rgh, Initial residual = 0.0056481889, Final residual = 8.1606344e-08, No Iterations 7
GAMG: Solving for p_rgh, Initial residual = 4.0515088e-06, Final residual = 4.6215754e-08, No Iterations 3
GAMG: Solving for p_rgh, Initial residual = 9.1679808e-07, Final residual = 3.0994507e-08, No Iterations 2
time step continuity errors (fluid): sum local = 1.4519277e-11, global = 7.237251e-13, cumulative = 4.4382842e-08
GAMG: Solving for p_rgh, Initial residual = 3.9095027e-07, Final residual = 4.9657638e-08, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 1.3685112e-07, Final residual = 2.4273418e-08, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 5.9664268e-08, Final residual = 5.9664268e-08, No Iterations 0
time step continuity errors (fluid): sum local = 2.7949542e-11, global = 4.6906331e-13, cumulative = 4.4383311e-08
DICPCG: Solving for h, Initial residual = 7.0222902e-06, Final residual = 4.4745359e-12, No Iterations 1
DICPCG: Solving for h, Initial residual = 4.8146941e-12, Final residual = 4.8146941e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 654.37783
DICPCG: Solving for h, Initial residual = 5.3096873e-06, Final residual = 1.9608229e-12, No Iterations 1
DICPCG: Solving for h, Initial residual = 3.6329413e-12, Final residual = 3.6329413e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 691.02751
DICPCG: Solving for h, Initial residual = 3.415013e-06, Final residual = 3.0740924e-12, No Iterations 1
DICPCG: Solving for h, Initial residual = 3.1231553e-12, Final residual = 3.1231553e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 302.19046
ExecutionTime = 25647.98 s ClockTime = 26270 s
Region: fluid Courant Number mean: 0.01846859 max: 0.29994596
Region: fibrothal_in Diffusion Number mean: 3.7268432e-08 max: 2.2962282e-07
Region: solid_bricks Diffusion Number mean: 2.5128969e-08 max: 1.3494945e-07
Time = 73.540827
DILUPBiCG: Solving for Ux, Initial residual = 6.7630737e-05, Final residual = 1.3418181e-08, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 4.6370261e-05, Final residual = 1.0742627e-08, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 6.0847475e-05, Final residual = 8.1523053e-09, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1.4442106e-05, Final residual = 1.5490886e-09, No Iterations 1
LU Back substitute C matrix..
Min/max T:302.35057 796
GAMG: Solving for p_rgh, Initial residual = 0.0056481019, Final residual = 7.6797676e-08, No Iterations 7
GAMG: Solving for p_rgh, Initial residual = 3.857246e-06, Final residual = 9.7154467e-08, No Iterations 2
GAMG: Solving for p_rgh, Initial residual = 8.8653178e-07, Final residual = 3.3270662e-08, No Iterations 2
time step continuity errors (fluid): sum local = 1.5585688e-11, global = -4.472e-13, cumulative = 4.4382864e-08
GAMG: Solving for p_rgh, Initial residual = 3.7940167e-07, Final residual = 4.9666952e-08, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 1.3330598e-07, Final residual = 2.477867e-08, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 5.9175294e-08, Final residual = 5.9175294e-08, No Iterations 0
time step continuity errors (fluid): sum local = 2.7720599e-11, global = -2.3320649e-13, cumulative = 4.4382631e-08
DICPCG: Solving for h, Initial residual = 7.0243905e-06, Final residual = 4.4725576e-12, No Iterations 1
DICPCG: Solving for h, Initial residual = 2.4377613e-11, Final residual = 2.4377613e-11, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 654.37063
DICPCG: Solving for h, Initial residual = 5.2875841e-06, Final residual = 1.9709967e-12, No Iterations 1
DICPCG: Solving for h, Initial residual = 2.8414773e-09, Final residual = 2.8414773e-09, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 295.48786 max(T) [0 0 0 1 0 0 0] 741.78106
DICPCG: Solving for h, Initial residual = 3.4149741e-06, Final residual = 3.0740581e-12, No Iterations 1
DICPCG: Solving for h, Initial residual = 3.1189356e-12, Final residual = 3.1189356e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 302.19047
ExecutionTime = 25648.68 s ClockTime = 26271 s
Region: fluid Courant Number mean: 0.018468399 max: 0.29995557
Region: fibrothal_in Diffusion Number mean: 3.7268448e-08 max: 2.2962323e-07
Time = 73.541659
DILUPBiCG: Solving for Ux, Initial residual = 6.7625913e-05, Final residual = 1.3402331e-08, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 4.6344566e-05, Final residual = 1.0754375e-08, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 6.0932861e-05, Final residual = 8.1687571e-09, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1.4447945e-05, Final residual = 1.5504852e-09, No Iterations 1
Min/max T:292.46006 796
GAMG: Solving for p_rgh, Initial residual = 0.0056581752, Final residual = 7.6764428e-08, No Iterations 12
GAMG: Solving for p_rgh, Initial residual = 2.2938121e-05, Final residual = 5.568475e-08, No Iterations 5
GAMG: Solving for p_rgh, Initial residual = 4.8180826e-06, Final residual = 4.5585251e-08, No Iterations 3
time step continuity errors (fluid): sum local = 2.1354346e-11, global = -1.0446098e-12, cumulative = 4.4381586e-08
GAMG: Solving for p_rgh, Initial residual = 1.7763567e-06, Final residual = 4.7846782e-08, No Iterations 2
GAMG: Solving for p_rgh, Initial residual = 5.9132237e-07, Final residual = 5.9130769e-08, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 2.4540226e-07, Final residual = 3.1298447e-08, No Iterations 1
time step continuity errors (fluid): sum local = 1.4662065e-11, global = -6.7971007e-14, cumulative = 4.4381518e-08
DICPCG: Solving for h, Initial residual = 7.0245586e-06, Final residual = 4.4724421e-12, No Iterations 1
DICPCG: Solving for h, Initial residual = 9.1267502e-12, Final residual = 9.1267502e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 654.37584
DICPCG: Solving for h, Initial residual = 5.2888596e-06, Final residual = 1.9709382e-12, No Iterations 1
DICPCG: Solving for h, Initial residual = 8.289224e-11, Final residual = 8.289224e-11, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 292.46034 max(T) [0 0 0 1 0 0 0] 661.85799
DICPCG: Solving for h, Initial residual = 3.4149352e-06, Final residual = 3.0740239e-12, No Iterations 1
DICPCG: Solving for h, Initial residual = 3.127232e-12, Final residual = 3.127232e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 302.19048
ExecutionTime = 25649.12 s ClockTime = 26271 s
Region: fluid Courant Number mean: 0.018468212 max: 0.29996512
Region: fibrothal_in Diffusion Number mean: 3.7268464e-08 max: 2.2962363e-07
Time = 73.54249
DILUPBiCG: Solving for Ux, Initial residual = 6.7947711e-05, Final residual = 1.4502077e-08, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 4.6627109e-05, Final residual = 1.1456384e-08, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 6.1359507e-05, Final residual = 7.2212648e-09, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1.4447972e-05, Final residual = 1.5510617e-09, No Iterations 1
Min/max T:292.4726 796
GAMG: Solving for p_rgh, Initial residual = 0.0056490789, Final residual = 8.349077e-08, No Iterations 10
GAMG: Solving for p_rgh, Initial residual = 1.4609603e-05, Final residual = 6.3234719e-08, No Iterations 4
GAMG: Solving for p_rgh, Initial residual = 3.3731476e-06, Final residual = 8.6407996e-08, No Iterations 2
time step continuity errors (fluid): sum local = 4.0477576e-11, global = 2.3788157e-14, cumulative = 4.4381542e-08
GAMG: Solving for p_rgh, Initial residual = 1.3010508e-06, Final residual = 4.1176202e-08, No Iterations 2
Old   August 20, 2015, 15:30
Retired Super Moderator
Bruno Santos
Greetings to all!
@baran_foam: Since you sent me a PM and I spent some time trying to imagine/diagnose this issue, my best guess is that there is no heat being released by the region "solid_bricks", which is why it ends up overheating and crashing the simulation, because the temperature range falls out of the working range of the polynomials for the material properties.
Beyond that, you should follow Alex's suggestion, specially the one about looking at the results in ParaView.
Best regards,
Bruno
Old   August 24, 2015, 02:17
baran
Greeting All!!!
@bruno ....thanks for your reply....and I will check that issue...
@Alex... thanks for your valuable suggestion...
1. for bc in heating element surface I have used uniformFixedValue
2. for outer wall I have used
        type            externalWallHeatFluxTemperature;
        kappa               solidThermo;
        Ta              uniform 303;
        h               uniform 10;
        kappaName           none;
        value           uniform 300;
...the same thing I have used for my previous case also...
can you kindly explain what kind of problem you faced with externalWallHeatFluxTemperature bc?
I have to check other things as you told and let you know wheather any other issue is there or not...
Regards,
Baran
Old   August 24, 2015, 09:54
Alex
Hi baran,
You can check youself the problem I faced here. What OF version are you using? If you use 2.3.x or 2.4.x you can fix it by downloading the fixes via github and recompile it. The fix consists of a relaxation factor implemented for the Qr field so that you only need to specify a couple of fields more in the BC specification. By the way, in the BC specification you attached you din't have Qr defined and you need to define it in order to take radiation into account in the boundaries...
Hope it helps!
Alex
wyldckat likes this.
Old   August 26, 2015, 08:21
baran
Dear Alex,
my OF version is 2.4.x
This same case I have run in fluent to compare the two result . As thermal conductivity is very low of this solid zone. Wheather I add radiation at the outer wall does not have any effect.
Thermal conductivity of bricks is 0.15 .
I want to ask another question..that..if I am applying viewfactor model but wall bc is like convection case then viewfactor effect is come into consideration?
Regards,
baran
Old   August 31, 2015, 07:02
baran
Greeting all!!!
This is mesh quality of my geometry...I hope this is not made any problem...
Create polyMesh for time = 0
Enabling all (cell, face, edge, point) topology checks.
Enabling all geometry checks.
Time = 0
Mesh stats
    faces:            3270406
    internal faces:   3191462
    cells:            1076978
    faces per cell:   6
    boundary patches: 10
    point zones:      0
    face zones:       13
    cell zones:       4
Overall number of cells of each type:
    hexahedra:     1076978
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Topological cell zip-up check OK.
    Face-face connectivity OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology                   Bounding box
    he_surface          13720    13736    ok (closed singly connected)       (0.247 0.251 0.272) (0.917 0.941 1.202)
    w_right_side_ref    5952     6111     ok (non-closed singly connected)   (2.6999174e-24 0.15 0.212) (5.2351103e-16 1.036 1.352)
    w_left_side_ref     5952     6111     ok (non-closed singly connected)   (1.164 0.15 0.212) (1.164 1.036 1.352)
    w_back_ref          12288    12513    ok (non-closed singly connected)   (0 0.15 1.352) (1.164 1.036 1.502)
    w_brick_bot         3256     3500     ok (non-closed singly connected)   (0.217 -9.5154073e-16 0.212) (0.947 9.5707519e-16 1.352)
    w_bot_ref           7104     7499     ok (non-closed singly connected)   (0 -1.1571817e-15 0.212) (1.164 0.15 1.502)
    w_door1             2588     2676     ok (non-closed singly connected)   (0.332 0.356 -0.1) (0.832 0.85600003 -0.05)
    w_door2             696      870      ok (non-closed singly connected)   (0.332 0.356 -0.05) (0.832 0.85600003 0)
    w_bricks            17028    17343    ok (non-closed singly connected)   (0 -1.1571817e-15 0) (1.164 1.186 0.212)
    w_top_ref           10360    10553    ok (non-closed singly connected)   (0 1.036 0.212) (1.164 1.186 1.502)
Checking geometry...
    Overall domain bounding box (0 -1.1571817e-15 -0.1) (1.164 1.186 1.502)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (3.2928793e-15 2.2620737e-15 7.0567305e-15) OK.
    Max cell openness = 3.3154974e-16 OK.
    Max aspect ratio = 13.162501 OK.
    Minimum face area = 6.5776377e-06. Maximum face area = 0.00064648215.  Face area magnitudes OK.
    Min volume = 8.3282847e-08. Max volume = 7.9145335e-06.  Total volume = 2.0928022.  Cell volumes OK.
    Mesh non-orthogonality Max: 69.14912 average: 8.4597446
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.66268921 OK.
    Coupled point location match (average 0) OK.
    Face tets OK.
    Min/max edge length = 0.0016666666 0.032313618 OK.
    All angles in faces OK.
    Face flatness (1 = flat, 0 = butterfly) : min = 0.99388226  average = 0.99999605
    All face flatness OK.
    Cell determinant (wellposedness) : minimum: 0.028461416 average: 4.6877314
    Cell determinant check OK.
    Concave cell check OK.
    Face interpolation weight : minimum: 0.10005566 average: 0.49007212
    Face interpolation weight check OK.
    Face volume ratio : minimum: 0.11131699 average: 0.9662018
    Face volume ratio check OK.
Mesh OK.
Using the convection bc I have get my solution right though using radiation bc case is diverging as I told in my first place..Apart from this temperature variation with time is coming random with radiation bc....I have attached two point is air for this two case.. in picture(in total four...)
Can you suggest what might be the reason??
From the discussion of our previous case it is observed that case is diverging for radiation case...in bricks zone(thermal conductivity-0.15 J/kg K)
So I change the thermal conductivity of bricks from 0.15 to 10. Then run the same case with radiation bc....
Then case is diverging in other zone..fibrothal(thermal conductivity is around 0.15 J/kg K)...So is there is any problem with this radiation bc or radiation to handle high T with small thermal conductivity of insulation..
Please suggest something...mostly this problem is not involve with any mesh issue...??? I have attached the log file for the later case below...
Region: fluid Courant Number mean: 0.0198761 max: 0.29878319
Region: fibrothal_in Diffusion Number mean: 5.3692836e-08 max: 3.868369e-07
Region: solid_bricks Diffusion Number mean: 2.453461e-06 max: 1.317393e-05
Region: unifrax_out Diffusion Number mean: 1.0442085e-07 max: 3.2171136e-07
deltaT = 0.0011417394
Time = 132.83673
DILUPBiCG:  Solving for Ux, Initial residual = 7.8428474e-05, Final residual = 2.3160953e-08, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 5.9872307e-05, Final residual = 2.1848024e-08, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 8.1347697e-05, Final residual = 1.7257565e-08, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 1.3754107e-05, Final residual = 1.8032295e-09, No Iterations 1
Min/max T:306.56532 939
GAMG:  Solving for p_rgh, Initial residual = 0.004153507, Final residual = 8.7413984e-08, No Iterations 10
GAMG:  Solving for p_rgh, Initial residual = 8.9189776e-06, Final residual = 8.0399224e-08, No Iterations 4
GAMG:  Solving for p_rgh, Initial residual = 2.1315608e-06, Final residual = 7.7674832e-08, No Iterations 2
time step continuity errors (fluid): sum local = 6.4079763e-11, global = 8.4405831e-13, cumulative = 1.0816831e-07
GAMG:  Solving for p_rgh, Initial residual = 7.9826171e-07, Final residual = 3.8468735e-08, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 2.8369056e-07, Final residual = 4.4607049e-08, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 1.209402e-07, Final residual = 2.6745305e-08, No Iterations 1
time step continuity errors (fluid): sum local = 2.2064599e-11, global = 8.3155456e-15, cumulative = 1.0816832e-07
DICPCG:  Solving for h, Initial residual = 4.8433956e-06, Final residual = 5.6555918e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 5.846885e-12, Final residual = 5.846885e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 823.55181
DICPCG:  Solving for h, Initial residual = 5.3780627e-06, Final residual = 1.8628724e-10, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.9739328e-10, Final residual = 1.9739328e-10, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300.00584 max(T) [0 0 0 1 0 0 0] 390.0248
DICPCG:  Solving for h, Initial residual = 3.1120483e-06, Final residual = 3.4748384e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 3.5734963e-12, Final residual = 3.5734963e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 317.42316
ExecutionTime = 48515.92 s  ClockTime = 49698 s
Region: fluid Courant Number mean: 0.019876 max: 0.29877615
Region: fibrothal_in Diffusion Number mean: 5.3692908e-08 max: 3.8683897e-07
Time = 132.83787
DILUPBiCG:  Solving for Ux, Initial residual = 7.8490734e-05, Final residual = 2.314818e-08, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 5.9735226e-05, Final residual = 2.1923582e-08, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 8.1540717e-05, Final residual = 1.7182041e-08, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 1.3757046e-05, Final residual = 1.804325e-09, No Iterations 1
Min/max T:306.56544 939
GAMG:  Solving for p_rgh, Initial residual = 0.0041498473, Final residual = 9.054912e-08, No Iterations 9
GAMG:  Solving for p_rgh, Initial residual = 8.3165628e-06, Final residual = 7.0594986e-08, No Iterations 4
GAMG:  Solving for p_rgh, Initial residual = 2.032543e-06, Final residual = 6.9336629e-08, No Iterations 2
time step continuity errors (fluid): sum local = 5.7201248e-11, global = -9.3147623e-13, cumulative = 1.0816739e-07
GAMG:  Solving for p_rgh, Initial residual = 7.6577489e-07, Final residual = 9.7339006e-08, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 2.8026848e-07, Final residual = 5.1413822e-08, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 1.298081e-07, Final residual = 2.9943948e-08, No Iterations 1
time step continuity errors (fluid): sum local = 2.4703296e-11, global = -6.8827074e-13, cumulative = 1.081667e-07
DICPCG:  Solving for h, Initial residual = 4.8426671e-06, Final residual = 5.6623743e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 4.4247984e-11, Final residual = 4.4247984e-11, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 168.02419 max(T) [0 0 0 1 0 0 0] 823.54449
DICPCG:  Solving for h, Initial residual = 5.3882983e-06, Final residual = 1.8640842e-10, No Iterations 1
DICPCG:  Solving for h, Initial residual = 3.0063655e-10, Final residual = 3.0063655e-10, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300.00584 max(T) [0 0 0 1 0 0 0] 390.07683
DICPCG:  Solving for h, Initial residual = 3.1120344e-06, Final residual = 3.4748206e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 3.5760929e-12, Final residual = 3.5760929e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 317.42353
ExecutionTime = 48516.76 s  ClockTime = 49698 s
Region: fluid Courant Number mean: 0.019875904 max: 0.29876907
Region: fibrothal_in Diffusion Number mean: 5.369298e-08 max: 3.8684106e-07
Time = 132.83901
DILUPBiCG:  Solving for Ux, Initial residual = 7.8363917e-05, Final residual = 2.3111003e-08, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 5.9808245e-05, Final residual = 2.181205e-08, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 8.1303226e-05, Final residual = 1.7190079e-08, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 1.3769818e-05, Final residual = 1.8025345e-09, No Iterations 1
Min/max T:-34.638404 939
GAMG:  Solving for p_rgh, Initial residual = 0.0041635193, Final residual = 8.7220279e-08, No Iterations 18
GAMG:  Solving for p_rgh, Initial residual = 3.0025266e-05, Final residual = 8.3696645e-08, No Iterations 7
GAMG:  Solving for p_rgh, Initial residual = 6.9780425e-06, Final residual = 9.4629866e-08, No Iterations 3
time step continuity errors (fluid): sum local = 7.8066502e-11, global = -1.0715968e-11, cumulative = 1.0815598e-07
GAMG:  Solving for p_rgh, Initial residual = 2.6392854e-06, Final residual = 8.7769725e-08, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 9.0381004e-07, Final residual = 4.9359257e-08, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 3.9857535e-07, Final residual = 5.3627197e-08, No Iterations 1
time step continuity errors (fluid): sum local = 4.4241536e-11, global = 2.0258428e-12, cumulative = 1.0815801e-07
DICPCG:  Solving for h, Initial residual = 4.8427064e-06, Final residual = 5.6629409e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.9117983e-11, Final residual = 1.9117983e-11, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] -34.64088 max(T) [0 0 0 1 0 0 0] 823.55061
DICPCG:  Solving for h, Initial residual = 5.3881957e-06, Final residual = 1.8640995e-10, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.9768437e-10, Final residual = 1.9768437e-10, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300.00584 max(T) [0 0 0 1 0 0 0] 390.07814
DICPCG:  Solving for h, Initial residual = 3.1120205e-06, Final residual = 3.4748029e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 3.5713957e-12, Final residual = 3.5713957e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 317.42391
ExecutionTime = 48517.36 s  ClockTime = 49699 s
Region: fluid Courant Number mean: 0.019875807 max: 0.29875958
Region: fibrothal_in Diffusion Number mean: 5.3693051e-08 max: 3.8684315e-07
Time = 132.84016
DILUPBiCG:  Solving for Ux, Initial residual = 8.1108496e-05, Final residual = 2.5818077e-08, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 6.134127e-05, Final residual = 2.4355749e-08, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 8.5046122e-05, Final residual = 1.9803553e-08, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 1.3767232e-05, Final residual = 1.8025597e-09, No Iterations 1
Min/max T:168.04889 939
GAMG:  Solving for p_rgh, Initial residual = 0.0041488398, Final residual = 9.7922006e-08, No Iterations 16
GAMG:  Solving for p_rgh, Initial residual = 2.5548778e-05, Final residual = 8.2376033e-08, No Iterations 7
GAMG:  Solving for p_rgh, Initial residual = 6.7243635e-06, Final residual = 5.251697e-08, No Iterations 4
time step continuity errors (fluid): sum local = 4.3325191e-11, global = 5.3072732e-12, cumulative = 1.0816332e-07
GAMG:  Solving for p_rgh, Initial residual = 1.8993958e-06, Final residual = 6.9772195e-08, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 6.1908036e-07, Final residual = 8.0077444e-08, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 2.4772369e-07, Final residual = 4.5438216e-08, No Iterations 1
time step continuity errors (fluid): sum local = 3.7486014e-11, global = 1.2021921e-12, cumulative = 1.0816452e-07
DICPCG:  Solving for h, Initial residual = 3.1120066e-06, Final residual = 3.4747852e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 3.5740577e-12, Final residual = 3.5740577e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 317.42429
ExecutionTime = 48517.93 s  ClockTime = 49700 s
Region: fluid Courant Number mean: 0.019875723 max: 0.29875153
Region: fibrothal_in Diffusion Number mean: 5.3693123e-08 max: 3.8684525e-07
Time = 132.8413
DILUPBiCG:  Solving for Ux, Initial residual = 7.8970139e-05, Final residual = 2.3571827e-08, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 6.0058436e-05, Final residual = 2.2336877e-08, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 8.2795778e-05, Final residual = 1.7421106e-08, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 1.3770425e-05, Final residual = 1.8043668e-09, No Iterations 1
Min/max T:-35.535871 939
GAMG:  Solving for p_rgh, Initial residual = 0.0041525003, Final residual = 8.3978618e-08, No Iterations 16
GAMG:  Solving for p_rgh, Initial residual = 2.0716891e-05, Final residual = 8.414588e-08, No Iterations 6
GAMG:  Solving for p_rgh, Initial residual = 5.9691193e-06, Final residual = 6.361722e-08, No Iterations 4
time step continuity errors (fluid): sum local = 5.2482977e-11, global = -1.8655448e-12, cumulative = 1.0816265e-07
GAMG:  Solving for p_rgh, Initial residual = 1.6250719e-06, Final residual = 7.813847e-08, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 4.7865432e-07, Final residual = 6.8283963e-08, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 1.8631846e-07, Final residual = 3.5284387e-08, No Iterations 1
time step continuity errors (fluid): sum local = 2.9109187e-11, global = -2.3103795e-13, cumulative = 1.0816242e-07
DICPCG:  Solving for h, Initial residual = 4.8424178e-06, Final residual = 5.6627448e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 7.5644313e-12, Final residual = 7.5644313e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] -35.538367 max(T) [0 0 0 1 0 0 0] 823.55579
DICPCG:  Solving for h, Initial residual = 5.3879905e-06, Final residual = 1.864035e-10, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.9767345e-10, Final residual = 1.9767345e-10, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300.00584 max(T) [0 0 0 1 0 0 0] 390.08076
DICPCG:  Solving for h, Initial residual = 3.1119927e-06, Final residual = 3.4747675e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 3.5731187e-12, Final residual = 3.5731187e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 317.42467
ExecutionTime = 48518.51 s  ClockTime = 49700 s
Region: fluid Courant Number mean: 0.019875633 max: 0.29874413
Region: fibrothal_in Diffusion Number mean: 5.3693195e-08 max: 3.8684734e-07
Regards,
Baran
Old   September 1, 2015, 19:37
Alex
Ok baran,
I guess that you are still using externalWallHeatFluxTemperature BC... If so, update your source code with the latest patches and corrections (in case you haven't done it for the last 3 months or so... If you installed OF 2.4.x less than 3 months ago it shouldn't be necessary...). Once you have uploaded it and recompiled it try using a similar specification for external boundaries to this one:
    myPatch
        kappa           fluidThermo;
        q               uniform 1000;
        Ta              uniform 300.0;
        h               uniform 10.0;
        thicknessLayers (0.1 0.2 0.3 0.4);
        kappaLayers     (1 2 3 4);
        value           uniform 300.0;
        kappaName       none;
        Qr              Qr;
        relaxation      1;    // try with lower values, using 1 will make no difference. Maybe 0.1 would do the trick...
This piece of code I have taken it from here.
Hope it helps.
Best regards,
Alex
wht likes this.
Old   September 4, 2015, 08:31
Unhappy
baran
Dear Alex,
I have changed the outer wall bc of externalWallHeatFluxTemperature as it is already available in of2.4 ...
        kappa           solidThermo;
        //q               uniform 1000;
        Ta              uniform 300.0;
        h               uniform 10.0;
        //thicknessLayers (0.1 0.2 0.3 0.4);
        //kappaLayers     (1 2 3 4);
        kappaName       none;
        Qr              Qr;
        relaxation      1;
Still I get the same problem.......and it is started diverging due to some low temperature in solid_bricks which have constant property of k= 0.15 j/kg K and other value also....
fvSolution...
solvers
    h
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.1;
    hFinal
        $h;
        tolerance        1e-06;
        relTol           0;
PIMPLE
fvScheme...
ddtSchemes
    default Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
laplacianSchemes
    default         none;
    laplacian(alpha,h) Gauss linear limited 0.333;
    default         linear;
snGradSchemes
fluxRequired
    default         no;
this is log file of diverging section...
Region: fluid Courant Number mean: 0.011803868 max: 0.29978066
Region: fibrothal_in Diffusion Number mean: 5.984852e-08 max: 3.6395751e-07
Region: solid_bricks Diffusion Number mean: 4.325115e-08 max: 2.3223831e-07
Region: unifrax_out Diffusion Number mean: 1.2271976e-07 max: 3.7808866e-07
deltaT = 0.00134182
Time = 61.349217
DILUPBiCG:  Solving for Ux, Initial residual = 0.00020252946, Final residual = 1.0480067e-08, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.00022700634, Final residual = 4.9277215e-09, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.00021673457, Final residual = 8.2935081e-09, No Iterations 2
DILUPBiCG:  Solving for h, Initial residual = 7.0113698e-05, Final residual = 5.4885426e-10, No Iterations 2
Min/max T:314.12367 753
GAMG:  Solving for p_rgh, Initial residual = 0.0011703758, Final residual = 8.8669323e-08, No Iterations 6
GAMG:  Solving for p_rgh, Initial residual = 4.657791e-06, Final residual = 5.7582968e-08, No Iterations 3
GAMG:  Solving for p_rgh, Initial residual = 1.1551078e-06, Final residual = 4.3470744e-08, No Iterations 2
time step continuity errors (fluid): sum local = 3.9981212e-10, global = -2.0513208e-11, cumulative = -1.7388678e-08
GAMG:  Solving for p_rgh, Initial residual = 1.3509646e-06, Final residual = 7.2930855e-08, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 2.5230028e-07, Final residual = 5.9736719e-08, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 1.1260898e-07, Final residual = 4.3606164e-08, No Iterations 1
time step continuity errors (fluid): sum local = 4.0105979e-10, global = -3.4002934e-11, cumulative = -1.7422681e-08
DICPCG:  Solving for h, Initial residual = 1.3847821e-05, Final residual = 1.3047331e-11, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.3725991e-11, Final residual = 1.3725991e-11, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 611.48428
DICPCG:  Solving for h, Initial residual = 1.0430615e-05, Final residual = 6.5189609e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 9.8068229e-12, Final residual = 9.8068229e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 666.81513
DICPCG:  Solving for h, Initial residual = 2.4035529e-05, Final residual = 1.605035e-11, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.544039e-09, Final residual = 1.544039e-09, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 300.03595
ExecutionTime = 16126.77 s  ClockTime = 16559 s
Region: fluid Courant Number mean: 0.011803874 max: 0.29977296
Region: fibrothal_in Diffusion Number mean: 5.9848554e-08 max: 3.6395834e-07
deltaT = 0.00134182
Time = 61.350559
DILUPBiCG:  Solving for Ux, Initial residual = 0.0002025609, Final residual = 1.1910169e-08, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.00022700465, Final residual = 4.884998e-09, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.00021670343, Final residual = 8.4535848e-09, No Iterations 2
DILUPBiCG:  Solving for h, Initial residual = 7.0106796e-05, Final residual = 5.5296829e-10, No Iterations 2
Min/max T:314.12101 753
GAMG:  Solving for p_rgh, Initial residual = 0.0011700388, Final residual = 7.9481395e-08, No Iterations 6
GAMG:  Solving for p_rgh, Initial residual = 4.6523857e-06, Final residual = 5.1471481e-08, No Iterations 3
GAMG:  Solving for p_rgh, Initial residual = 1.1486924e-06, Final residual = 4.0637e-08, No Iterations 2
time step continuity errors (fluid): sum local = 3.7375369e-10, global = -4.3799329e-12, cumulative = -1.7427061e-08
GAMG:  Solving for p_rgh, Initial residual = 1.3509856e-06, Final residual = 6.9778436e-08, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 2.5777917e-07, Final residual = 5.2959357e-08, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 1.065836e-07, Final residual = 3.6159249e-08, No Iterations 1
time step continuity errors (fluid): sum local = 3.3257513e-10, global = -3.1279595e-11, cumulative = -1.745834e-08
DICPCG:  Solving for h, Initial residual = 1.3848359e-05, Final residual = 1.3046006e-11, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.5699743e-11, Final residual = 1.5699743e-11, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 611.4786
DICPCG:  Solving for h, Initial residual = 1.0418483e-05, Final residual = 6.5202524e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 2.4807543e-09, Final residual = 2.4807543e-09, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 289.72511 max(T) [0 0 0 1 0 0 0] 649.88563
DICPCG:  Solving for h, Initial residual = 2.4034686e-05, Final residual = 1.6049802e-11, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.6219618e-09, Final residual = 1.6219618e-09, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 300.03596
ExecutionTime = 16127.5 s  ClockTime = 16560 s
Region: fluid Courant Number mean: 0.011803878 max: 0.29976523
Region: fibrothal_in Diffusion Number mean: 5.9848588e-08 max: 3.6395917e-07
deltaT = 0.00134182
Time = 61.351901
DILUPBiCG:  Solving for Ux, Initial residual = 0.000202575, Final residual = 1.1953834e-08, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.00022699901, Final residual = 4.9589681e-09, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.00021670665, Final residual = 8.6043666e-09, No Iterations 2
DILUPBiCG:  Solving for h, Initial residual = 7.0163301e-05, Final residual = 5.5663264e-10, No Iterations 2
Min/max T:289.72512 753
GAMG:  Solving for p_rgh, Initial residual = 0.0011745932, Final residual = 9.461503e-08, No Iterations 23
GAMG:  Solving for p_rgh, Initial residual = 1.3703751e-05, Final residual = 9.2266387e-08, No Iterations 5
GAMG:  Solving for p_rgh, Initial residual = 3.2030153e-06, Final residual = 7.2234752e-08, No Iterations 3
time step continuity errors (fluid): sum local = 6.6436148e-10, global = -1.1345981e-10, cumulative = -1.75718e-08
GAMG:  Solving for p_rgh, Initial residual = 2.1936572e-06, Final residual = 7.8329574e-08, No Iterations 3
GAMG:  Solving for p_rgh, Initial residual = 5.4352731e-07, Final residual = 9.250977e-08, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 2.3308027e-07, Final residual = 5.8853582e-08, No Iterations 1
time step continuity errors (fluid): sum local = 5.4130436e-10, global = 5.585416e-11, cumulative = -1.7515946e-08
DICPCG:  Solving for h, Initial residual = 1.3847885e-05, Final residual = 1.3045515e-11, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.3991418e-11, Final residual = 1.3991418e-11, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 300 max(T) [0 0 0 1 0 0 0] 611.48274
DICPCG:  Solving for h, Initial residual = 1.0418394e-05, Final residual = 6.519972e-12, No Iterations 1
DICPCG:  Solving for h, Initial residual = 9.8457579e-12, Final residual = 9.8457579e-12, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 289.71756 max(T) [0 0 0 1 0 0 0] 649.89343
DICPCG:  Solving for h, Initial residual = 2.4034443e-05, Final residual = 1.6049873e-11, No Iterations 1
DICPCG:  Solving for h, Initial residual = 1.6956056e-09, Final residual = 1.6956056e-09, No Iterations 0
ExecutionTime = 16127.98 s  ClockTime = 16561 s
I can't understand why suddenly there is low temperature in solid_bricks....please suggest something...
Regards,
Baran
Old   December 17, 2019, 18:36
Dániel Bakonyi
Daniel Bakonyi is on a distinguished road
Dear all,
I am currenlty facing what seems to be the same problem.
I am using OF 7 and chtMultiRegionFoam and I am trying to simulate the inside of a furnace where a bunch of solid pans are stacked on each other. My setup is steadyState and it runs just fine without radiation. My settings are based mostly on the OF6 MultiRegionHeaterRadiation tutorial.
However, as soon as I introduce radiation to the model it crashes in a few iterations with the a negative initial temperature error, or because the max number of iterations is exceeded by the h solver (if I try to constarin T with limitTemperature in the solid).
fluid region thermal and radiation properties:
thermoType
    type              heRhoThermo;
    mixture         pureMixture;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState icoPolynomial;
    specie           specie;
    energy          sensibleEnthalpy;
radiation  on;
riadaitionModel P1;
solverFreq 1;
absorptionEmissionModel constant;
constantCoeffs
    absorptivity    0.07;
    emissivity      0.037;
    E               0;
scatterModel    none;
sootModel       none;
and for the solid regions:
thermoType
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
mixture
    specie
        molWeight       28;
    equationOfState
        rho             1380;
    transport
        kappa          1;
    thermodynamics
        Hf              0;
        Cp              900;
radiation       on;
radiationModel  opaqueSolid;
constantCoeffs
    absorptivity    0;
    emissivity      0.9;
    E               0;
the numerical settings I am using for the fluid region:
ddtSchemes
    default         steadyState;
gradSchemes
divSchemes
    default             none;
    div(phi,U)          bounded Gauss upwind;
    div(phi,h)          bounded Gauss upwind;
    div(phi,epsilon)    bounded Gauss upwind;
    div(phi,k)          bounded Gauss upwind;
    div(phi,K)          bounded Gauss linear;
    div(phiv,p)         Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear uncorrected;
    default         linear;
snGradSchemes
    default             uncorrected;
solvers
"G.*"
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-5;
        relTol           0.1;
relaxationFactors
    fields
        "rho.*"         1.0;
        "p_rgh.*"       0.7;
    equations
        "U.*"           0.3;
        "h.*"           0.7;
        "k.*"           0.7;
        "epsilon.*"     0.7;
        "G"             0.7;
And for the solid regions:
ddtSchemes
gradSchemes
divSchemes
    default         none;
laplacianSchemes
    default         none;
    laplacian(alpha,h) Gauss linear uncorrected;
    default         linear;
snGradSchemes
The radiation related boundary conditions for the fluid:
//T BC for the extrenal walls of the furnace
        mode            coefficient;
        h               uniform 8;
        Ta              constant  1000;
        value           $internalField;
        kappaLayers     (0.5);
        thicknessLayers (0.25);
        kappaMethod     fluidThermo;
        qr              qr;
//T BC for the faces of the solid regions in the middle of the fluid
        Tnbr            T;
        qrNbr           none;
        qr              qr;
//G for the external walls
	type            MarshakRadiation;
	emissivityMode  lookup;
	emissivity      uniform 0.9;
//G for the internal walls
	emissivityMode  solidRadiation;
And for the solid:
    Tnbr            T;
   kappaMethod     solidThermo;
   qrNbr           qr;
   qr              none;
I checked the results with ParaView as suggested earlier in this thred. Everything is fine before the radiation is added and then the problem is with the solid region not with the extrenal walls.
When I plot the temperature for the surface_to_fluid patches they start to diverge in the negative direction from the temperature in the fluid_to_solid patches at the same place. the r field plotted on the same surafces is negative where this happens.
https://app.box.com/s/bhz1wlgcgt3iobxfnnuu35z5poibi0hk
https://app.box.com/s/rqgmuf541vw8ta88fnqftcipjquwfxdg
and finally the temprature gets negative in the edges of the solid region before everything goes to hell:
https://app.box.com/s/8mwikreoznywcdtnnayjrh3175lttehs
The solid regions is loosing thermal energy and I dont know why.
I have read several of zfaraday's posts about radiation modeling but there is no relaxation option for the turbuelntTemepratureRadCoupledMixed bc that I can find.
Is there something obviously wrong in my setup?
I am completely stuck, so any help would be greatly appreciated!
Dear Baran,
I know it has been quite a while, but have you found asolution for your problem?
Daniel Bakonyi is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 05:58
Problem with "symmetryPlanne" boundary condition fcuevas OpenFOAM Running, Solving & CFD 1 March 14, 2012 06:07
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
a problem with Boundary condition M Rad Main CFD Forum 12 November 27, 1998 13:49
