August 13, 2015, 09:57 |
Velocity at end of porous region
carsten fuetterer
Rep Power: 12 |
I am trying to solve the compressible flow through a catalyst which is model as a porous medium. The solver is rhoPorousSimpleFoam and run implicit. The porous section (cell zone ) is in the middle of the extruded mesh. In the last cells of the porous medium, the velocity suddenly drops, which you can see in the attached images. A similar behavior is also seen in the sample of open foam (compressible, implicit). Does somebody knows how to avoid this? Which further informations do you need?. with best regards Carsten |
August 13, 2015, 11:23 |
carsten fuetterer
Rep Power: 12 |
maybe the reason can be found also in the drop of the turbulent viscosity?
August 16, 2015, 01:06 |
Fatema Zandi Goharrizi
Rep Power: 17 |
hi
I think it is because of your mesh. the way of mesh generation and the mesh geometry |
August 17, 2015, 03:53 |
carsten fuetterer
Rep Power: 12 |
ok, its a structured mesh of the inlet part. This mesh is then extruded with the openfoam extruder. So I think the mesh is good. Here is the output of checkMesh:
Mesh stats points: 477594 faces: 1409320 internal faces: 1386680 cells: 466000 faces per cell: 6 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 1 Overall number of cells of each type: hexahedra: 466000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology wall 6640 6720 ok (non-closed singly connected) outlet 2000 2041 ok (non-closed singly connected) inlet 2000 2041 ok (non-closed singly connected) porosityWall 12000 12080 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.254958 -0.0725438 -0.122602) (0.0726735 0.126725 0.2) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-2.65156e-16 -2.05682e-16 6.89138e-17) OK. Max cell openness = 2.16877e-15 OK. Max aspect ratio = 32.9462 OK. Minimum face area = 2.72631e-08. Maximum face area = 7.19034e-05. Face area magnitudes OK. Min volume = 3.78169e-11. Max volume = 7.76384e-08. Total volume = 0.00481471. Cell volumes OK. Mesh non-orthogonality Max: 54.5986 average: 8.51888 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.02173 OK. Coupled point location match (average 0) OK. Mesh OK. |
September 3, 2015, 00:09 |
#5 | |
Rep Power: 17 |
I wish your problem have been solved after this long period answering!!! but if not to better understand your problem, is it the sudden failure of the velocity? in the pictures where and what is the exact problem you have seen? could you bold and highlight it? I think at the junction of two blocks, the adjacent boundary can not pass the right condition from a side to the other one. I have not ever used rhoPorousSimpleFoam but from the picture tell the statement. |
September 3, 2015, 06:03 |
carsten fuetterer
Rep Power: 12 |
thanks for your reply. Sadly I did not solved the problem, which why I skipped this project. But I have to solve it. So any help would be really nice. I could also share the project files with you if you like.
I attached an image which marks the problem cells. Yes I think its somehow a mistake in diskretising between two regions. I did not defined an extra boundary between these regions. So there must be internally a problem. best regards Carsten |
September 3, 2015, 12:54 |
#7 | |
Rep Power: 17 |
I'm afraid that don't have a solution or even misunderstand the problem but do not worry at last you will do it. 2 question does the velocity drops in the mentioned cell and then go up again?(as seen in picture if it is velocity contour) can't you neglect or ignore it in results or it affects the results? |
September 3, 2015, 12:58 |
carsten fuetterer
Rep Power: 12 |
yes, the weird thing is, that the velocity goes up again. But I don't know if it effects the solution. I can not neglect this, since it is not just a visualization problem
cheers |
September 3, 2015, 15:42 |
#9 |
Rep Power: 16 |
I am faceing the same artefacts. But from experience and comparisons with other commercial software, I can tell you that this artefact is not influenceing your results. So you can use the results. Kind regards Chrisi |
September 4, 2015, 02:00 |
#10 |
Rep Power: 17 |
Hey
according to picture and now Chrisi's experience I think in the same way, although wish you could fix it |
September 7, 2015, 15:17 |
#11 |
please have a look to post #7 on this I deleted pictures from my dropbox, but summarizing, I made a test case of a rectangular channel (2D) and I set the pressure drop data (experimental) to have alpha & beta. I had cfd results aligned with experimental. I performed some other test cases, alpha & beta given by a velocity-pressure drop tendency line drawn by myself and I found that fixed coeffcient model performs better than Darcy-Forcheimer model. I can't confirm at all, and I can't tell you why I had these results. Anyway, you could give a try... Cheers. |
September 7, 2015, 15:48 |
#12 |
carsten fuetterer
Rep Power: 12 |
Hi, thanks for this advice. I will try this out this week.
catalyst, compressible, outlet, porous |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
about compresive phase | James | CFX | 10 | September 12, 2006 03:16 |
