reactingFoam error - modified counterFlowFlame2D tutorial
Like Tree1Likes
  • 1 Post By Lisandro Maders
Old   July 29, 2015, 21:35
Default reactingFoam error - modified counterFlowFlame2D tutorial
Lisandro Maders
Lisandro Maders is on a distinguished road
I am trying to run the counterFlowFlame2D tutorial with a different mesh and domain (now I am running a 2D axisymmetric mesh) but I got the following error:
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
Creating reaction model
Selecting combustion model laminar<psiChemistryCombustion>
Selecting chemistry type
    chemistrySolver EulerImplicit;
    chemistryThermo psi;
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         reactingMixture;
    transport       sutherland;
    thermo          janaf;
    energy          sensibleEnthalpy;
    equationOfState perfectGas;
    specie          specie;
Selecting chemistryReader foamChemistryReader
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::fvPatchField<double>::operator/=(Foam::fvPatchField<double> const&) at ??:?
#4  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::operator/=(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5  Foam::multiComponentMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::correctMassFractions() at ??:?
#6  Foam::multiComponentMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::multiComponentMixture(Foam::dictionary const&, Foam::List<Foam::word> const&, Foam::HashPtrTable<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> >, Foam::word, Foam::string::hash> const&, Foam::fvMesh const&) at ??:?
#7  Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::reactingMixture(Foam::dictionary const&, Foam::fvMesh const&) at ??:?
#8  Foam::heThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:?
#9  Foam::psiReactionThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#10  Foam::autoPtr<Foam::psiReactionThermo> Foam::basicThermo::New<Foam::psiReactionThermo>(Foam::fvMesh const&, Foam::word const&) at ??:?
#11  Foam::psiReactionThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#12  Foam::psiChemistryModel::psiChemistryModel(Foam::fvMesh const&) at ??:?
#13  Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::chemistryModel(Foam::fvMesh const&) at ??:?
#14  Foam::EulerImplicit<Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::EulerImplicit(Foam::fvMesh const&) at ??:?
#15  Foam::psiChemistryModel::addfvMeshConstructorToTable<Foam::EulerImplicit<Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&) at ??:?
#16  Foam::autoPtr<Foam::psiChemistryModel> Foam::basicChemistryModel::New<Foam::psiChemistryModel>(Foam::fvMesh const&) at ??:?
#17  Foam::psiChemistryModel::New(Foam::fvMesh const&) at ??:?
#18  Foam::combustionModels::psiChemistryCombustion::psiChemistryCombustion(Foam::word const&, Foam::fvMesh const&) at ??:?
#19  Foam::combustionModels::laminar<Foam::combustionModels::psiChemistryCombustion>::laminar(Foam::word const&, Foam::fvMesh const&) at ??:?
#20  Foam::combustionModels::psiCombustionModel::adddictionaryConstructorToTable<Foam::combustionModels::laminar<Foam::combustionModels::psiChemistryCombustion> >::New(Foam::word const&, Foam::fvMesh const&) at ??:?
#21  Foam::combustionModels::psiCombustionModel::New(Foam::fvMesh const&) at ??:?
#22
 at ??:?
#23  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#24
 at ??:?
Floating point exception (core dumped)
The main thing I want from someone is: how to deal with OpenFOAM errors that area not so obvious. I mean, apart from errors like writing EulerEmplicit insteaad of EulerImplicit, whose error OpenFOAM clearly tells you what you have done, how to proceed with the type of error above mentioned?
And I don't mind if you say "go to the source code and look for it", but I don't know from where to start looking in the source code!
The case files are attached in the case somebody wants to take a look..
Best,
Lisandro
Lisandro Maders is offline   Reply With Quote
Old   July 29, 2015, 21:38
Default continuation..
Lisandro Maders
I found the error, I was using as Boundary Condition at OUTLET for N2 specie the type calculated.. When I changed it to inletOutlet with a uniform value it worked. However, I don't understand why, since I don't want to specify a value for the N2 mass fraction at OUTLET. It will depend on the burned gases mass fractions.
Anyway, my question is not sorted, since I want to know how could I realize the error was at the N2 boundary condition by looking at the error message?? ..
Best,
Lisandro
Tscar likes this.
counterflowflame, error, modified mesh, reactingfoam
How to switch off combustion and reaction in reactingFoam shenzhou1987 OpenFOAM Running, Solving & CFD 16 October 26, 2017 16:31
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 06:34
reactingFoam tutorial for OpenFOAM 2.1.0 ToTh OpenFOAM Running, Solving & CFD 1 September 3, 2012 05:43
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 17:01
reactingFoam - turbulent reacting flow hamburgFoam OpenFOAM 0 December 7, 2009 13:57
