July 29, 2015, 05:02 |
buoyantSimplefoam rho explodes
Rep Power: 11 |
I'm using buoyantSimpleFoam for a simulation of trough a channel. In simplefoam the simulation works so I transfered it to buoyantSimpleFoam because the temperature has to be calculated. The simulations runs but after a view interations the maximum value of the density increases very fast and results an error. I only can run these interations by using a relaxtionfactor of 0.1 for the density. The BC for the walls, the inlet and outlet I copied from the circuitBoardCooling test case. The last 2 time steps are shown below: Code:
Time = 135.6 DILUPBiCG: Solving for Ux, Initial residual = 0.011047, Final residual = 6.65335e-05, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.0125556, Final residual = 0.000104728, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 0.0146263, Final residual = 0.00126821, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.0283624, Final residual = 0.000223, No Iterations 6 time step continuity errors : sum local = 0.00459438, global = -0.000824157, cumulative = 0.00564771 rho max/min : 12.461 0.832619 DILUPBiCG: Solving for nuTilda, Initial residual = 0.00074201, Final residual = 2.89444e-05, No Iterations 1 ExecutionTime = 255.28 s ClockTime = 259 s Time = 135.7 DILUPBiCG: Solving for Ux, Initial residual = 0.00981575, Final residual = 5.17544e-05, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.0084177, Final residual = 9.80715e-05, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 0.0165464, Final residual = 0.00143128, No Iterations 1 --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const in file /home/openfoam/OpenFOAM/OpenFOAM-2.3.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::THs(double, double, double) const at ??:? #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? #4 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? #5 at ??:? #6 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #7 at ??:? Aborted (core dumped) |
March 17, 2021, 21:00 |
Same here!
Diego
Rep Power: 7 |
Hi everyone,
I've also come across this issue a couple of times, and managed to fix it by underrelaxing rho to quite low levels (<0.05). This seems like the incorrect solution though, and I'm wondering if I've missed anything in terms of the calculation which may explain why my density explodes? It seems to interplay with the calculation for hydrostatic pressure p_rgh, just from my messing about. My process to solving these is now turning off any update in density by setting the relaxation to 0, then slowly opening the floodgates once the solution stabilises. I have not been able to run this case buoyantPimpleFoam. For reference, my case is simple 2D incompressible air flowing between two parallel plates under forced convection, where the bottom wall is "cold" and the top wall is adiabatic. If anyone out there knowledgeable in the inner workings of OpenFoam could help us out, that would be kindly appreciated! e.g. Code:
Starting time loop Time = 0.01 DILUPBiCGStab: Solving for h, Initial residual = 1, Final residual = 3.91784e-09, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 9.91787e-05, No Iterations 13 GAMG: Solving for p_rgh, Initial residual = 1.15545e-05, Final residual = 9.92366e-09, No Iterations 12 GAMG: Solving for p_rgh, Initial residual = 1.00347e-08, Final residual = 5.36769e-09, No Iterations 1 time step continuity errors : sum local = 7.43954e-11, global = -7.51005e-18, cumulative = -7.51005e-18 rho min/max : 0.607709 1.27515 DILUPBiCGStab: Solving for epsilon, Initial residual = 0.999998, Final residual = 3.12551e-09, No Iterations 1 DILUPBiCGStab: Solving for k, Initial residual = 1, Final residual = 3.65876e-10, No Iterations 1 ExecutionTime = 0.99 s ClockTime = 2 s Time = 0.02 DILUPBiCGStab: Solving for h, Initial residual = 0.482545, Final residual = 3.07279e-09, No Iterations 3 GAMG: Solving for p_rgh, Initial residual = 0.999935, Final residual = 9.74004e-05, No Iterations 62 GAMG: Solving for p_rgh, Initial residual = 4.85622e-05, Final residual = 1.66795e-06, No Iterations 100 GAMG: Solving for p_rgh, Initial residual = 1.66941e-06, Final residual = 5.74829e-07, No Iterations 100 time step continuity errors : sum local = 1.18707e-07, global = -4.26698e-17, cumulative = -5.01798e-17 rho min/max : 0.607626 1.27515 DILUPBiCGStab: Solving for epsilon, Initial residual = 0.108103, Final residual = 2.0814e-13, No Iterations 1 DILUPBiCGStab: Solving for k, Initial residual = 0.287233, Final residual = 5.50281e-09, No Iterations 2 ExecutionTime = 2.98 s ClockTime = 4 s Time = 0.03 DILUPBiCGStab: Solving for h, Initial residual = 0.0637923, Final residual = 5.56083e-10, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.814782, Final residual = 5.55235e-05, No Iterations 13 GAMG: Solving for p_rgh, Initial residual = 0.187916, Final residual = 1.57453e-05, No Iterations 19 GAMG: Solving for p_rgh, Initial residual = 0.000180221, Final residual = 1.15654e-08, No Iterations 19 time step continuity errors : sum local = 2.71784e-09, global = -5.1816e-18, cumulative = -5.53614e-17 rho min/max : 0.60756 311.75 DILUPBiCGStab: Solving for epsilon, Initial residual = 1, Final residual = 2.53892e-14, No Iterations 1 DILUPBiCGStab: Solving for k, Initial residual = 0.410838, Final residual = 1.1645e-12, No Iterations 1 ExecutionTime = 3.41 s ClockTime = 5 s Time = 0.04 DILUPBiCGStab: Solving for h, Initial residual = 0.999803, Final residual = 1.13088e-09, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.999998, Final residual = 0.000159061, No Iterations 100 GAMG: Solving for p_rgh, Initial residual = 7.80899e-05, Final residual = 1.35153e-06, No Iterations 100 GAMG: Solving for p_rgh, Initial residual = 1.35242e-06, Final residual = 5.66887e-08, No Iterations 100 time step continuity errors : sum local = 0.0398109, global = 3.56945e-13, cumulative = 3.5689e-13 rho min/max : -48.388 560.131 DILUPBiCGStab: Solving for epsilon, Initial residual = 0.166943, Final residual = 4.04283e-12, No Iterations 1 DILUPBiCGStab: Solving for k, Initial residual = 0.00298645, Final residual = 1.04669e-11, No Iterations 1 ExecutionTime = 5.65 s ClockTime = 7 s Time = 0.05 DILUPBiCGStab: Solving for h, Initial residual = 0.975413, Final residual = 2.18205e-09, No Iterations 4 --> FOAM FATAL ERROR: Negative initial temperature T0: -20348.4 |
March 19, 2021, 07:12 |
Rep Power: 14 |
Interesting - I haven't played with the buoyant[S|P]impleFoam solvers, but from the brief snippet of the run log that you included it looks like the energy solver gets out of control, resulting in poor temperature predictions and therefore poor density predictions.
Strongly buoyant flows can be a real pig to solve in steady state - in other codes, I have had to resort to a pseudo-transient approach (ie LTS in OpenFOAM) ... but this should be stable since it is the lower wall that is cold, so I don't think that that is the problem. Are you underrelaxing enthalpy sufficiently? Have you tried playing with the divSchemes on h? Do the temperatures look sensible? If you stop your example simulation after t=0.03 and save, where is the solution going nuts? At the cold wall, I presume, since the densities are already too high there - but is it adjacent to the domain inlet/outlet (ie is it caused by your BCs)? This might give you a few things to check out, but is probably not much help I am afraid. You could always upload a simple test case that demonstrates the problem and someone on the forum might have time to try debug it for you. |
March 19, 2021, 17:56 |
Attached case file
#4 | |
Diego
Rep Power: 7 |
What divSchemes do you suggest I give a try? I had them all set to upwind on account of the errors. Its definitely something to do with the inlet. The pressure (p, p_rgh) seems to go mental in the first couple of iterations which then seems to affect other parameters downstream. I've tried dozens of different BC's but none seem to have any effect on the stability directly (the issue seems to source on the corners of the inlet). EDIT: Changing enthalpy relaxation all the way down to 0 had little effect on convergence. I'm in the process of writing a fvOptions correction to limit the density after each iteration, maybe this'll work... |
January 14, 2024, 13:30 |
Fixed
Diego
Rep Power: 7 |
So just thought I'd come back to close this thread off with my findings.
My pressure fields seemed quite wild and varied significantly between timesteps, and as the system initialised in the first couple of time steps, fast oscillations in the pressure value would eventually trip U, and the turbulence fields eventually causing some floating point errors in the energy equation, leading to the solver to break. My solution includes:
Even with these changes, I still have quite large oscilations in the pipe - but they settle down over time. I can see reflections occuring at the end of the pipe, I was hoping there would be some transmissible boundary condition which could help get rid of these oscillations but couldn't find anything on it. Last edited by Hip2BL7; January 16, 2024 at 04:40. |
a problem with convergence in buoyantSimpleFoam | skuznet | OpenFOAM Running, Solving & CFD | 6 | November 15, 2017 13:12 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 05:13 |
what does this verbose error mean? | immortality | OpenFOAM Running, Solving & CFD | 1 | February 6, 2013 17:47 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
rho in buoyantSimpleFoam | Akuji | OpenFOAM Running, Solving & CFD | 2 | May 22, 2012 07:08 |
