Particle tracking in and after MRF
Like Tree1Likes
  • 1 Post By andreas0209@hotmail.com
Old   July 3, 2015, 07:27
Default Particle tracking in and after MRF
Andreas V.
andreas0209@hotmail.com is on a distinguished road
Hi
I am trying to simulate a particle laden air flow in a turbomachinery setup. The setup is a rectangular tunnel with a rotor and a nacelle in the middle. To simulate the rotation of the rotor I am using a multiple reference frame (MRF) approach (in defined in snappyHexmMesh and fvOptions). The solver is simpleReactingParcleFoam.
snappyHexMesh:
geometry
    Dynamic6.stl {type triSurfaceMesh; name Dynamic;}
    Nacelle.stl {type triSurfaceMesh; name Nacelle;}
    MRFcylinder
        type searchableCylinder;
        point1 (7.9 0 0);
        point2 (9.1 0 0);
    radius 1.27;
    name MRFcylinder;
    cylinder {type searchableCylinder; point1 (9.1 0 0); point2 (11.8 0 0); radius 1.27;}
castellatedMeshControls
    // Refinement parameters
    maxLocalCells 10000000;
    maxGlobalCells 20000000;
    minRefinementCells 10;
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 3;
    // Explicit feature edge refinement
    features
//          {file "Dynamic_advanced.eMesh"; level 4;}
        {file "Dynamic6.eMesh"; level 2;}
        {file "Nacelle.eMesh"; level 2;}
    // Surface based refinement
    refinementSurfaces
    Dynamic {level (5 6); patchInfo {type wall;}}
    Nacelle {level (5 6); patchInfo {type wall;}}
    MRFcylinder
        level (5 6); patchInfo {type patch;}
        faceZone MRF;  //name of faceZone
        cellZone MRF;  // name of cellZone
        cellZoneInside inside;  // to include all cells inside enclosed cyl.
fvOptions:
MRF1
    type        MRFSource;
    active         true;
    selectionMode   cellZone;
    cellZone        MRF;
    MRFSourceCoeffs
        nonRotatingPatches
       inlet
       outlet
       walls
       Nacelle
        // Fixed patches (by default they 'move' with the MRF zone)
       origin    (10 0 0); //1.2
    axis      (1 0 0);
       omega     constant 260;//=1900rpm (V=d*pi*n; v=omega*r)
reactingCloud1Properties
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      reactingCloud1Properties;
solution
    active          true;
    coupled         true;
    transient       no;//no;
    calcFrequency   10;
    maxTrackTime    5;
    maxCo           0.3;
    cellValueSourceCorrection on;
    sourceTerms
        resetOnStartup  false;
        schemes
            rho             semiImplicit 1;
            U               semiImplicit 1;
            Yi              semiImplicit 1;
            h               semiImplicit 1;
            radiation       semiImplicit 1;
    interpolationSchemes
        rho             cell;
        U               cellPoint;
        thermo:mu       cell;
    T               cell;
        Cp              cell;
        kappa           cell;
        p               cell;
    integrationSchemes
        U               Euler;
        T               analytical;
constantProperties
    rho0            1000;
    T0              350;
    Cp0             4100;
    constantVolume  false;
subModels
    particleForces
        sphereDrag;
        gravity;
    injectionModels
        model1
            type            patchInjection;
            massFlowRate    0.8e-05;
            parcelBasisType mass;
            patchName       inlet;
            parcelsPerSecond 500;
            duration        1; // NOTE: set to 1 for steady state
            U0              (300 0 0);
            position        (0 0 0);
            direction       (1 0 0);
            flowRateProfile constant 1;
            sizeDistribution
                type         general; //fixedValue;
                generalDistribution //fixedValueDistribution
                    distribution
                        (10e-07     0.0025)
                        (15e-07    0.0528)
                        (20e-07     0.2795)
                        (25e-07     1.0918)
                        (30e-07     2.3988)
                        (35e-07     4.4227)
                        (40e-07     6.3888)
                        (45e-07     8.6721)
                        (50e-07     10.3153)
                        (55e-07     11.6259)
                        (60e-07     12.0030)
                        (65e-07     10.4175)
                        (70e-07     10.8427)
                        (75e-07     8.0016)
                        (80e-07     6.1333)
                        (85e-07     3.8827)
                        (90e-07     3.4688)
    dispersionModel stochasticDispersionRAS;
    patchInteractionModel none;//standardWallInteraction;
    heatTransferModel none;//RanzMarshall;
    compositionModel singleMixtureFraction;
    phaseChangeModel none; //liquidEvaporation;
    devolatilisationModel none;
    surfaceReactionModel none;
    stochasticCollisionModel none;
    surfaceFilmModel none;
    radiation       off;
    standardWallInteractionCoeffs
        type            rebound;
    /*RanzMarshallCoeffs
        BirdCorrection  off;
    singleMixtureFractionCoeffs
        phases
            gas
            liquid
            solid
        ash 1;
        YGasTot0        0;
        YLiquidTot0     0;
        YSolidTot0     1;
    /*liquidEvaporationCoeffs
        enthalpyTransfer enthalpyDifference;
        activeLiquids   ( H2O );
cloudFunctions
    patchPostProcessing1
        type            patchPostProcessing;
        maxStoredParcels 200; //100
        patches         ( inlet ); //( outlet );
    particleTracks1
        type            particleTracks;
        trackInterval   5; //5;
        maxSamples      100000;
        resetOnWrite    yes;
The aim of this study is to simulate the particle flow around and though the rotor to see if there is a size dependent change in the flow behaviour of these particles.
My problem is that the flow profile and the streamlines look quite ok, but the particle "stuck" somehow at the dynamic part. Also there is a small discontinuity in the the streamline at the dynamic part.
I checked nearly every single setting option (variation in rotational speed, size of the particles, different inlet velocities, k and epsilon values etc.) without success.
I would be more than grateful if someone of you experienced openFoam experts could take a look into my settings or if someone has a hint how to get rid of this effect.
Thank you!
Andreas
sourav90 likes this.
andreas0209@hotmail.com is offline   Reply With Quote
Old   July 6, 2015, 09:36
Andreas V.
Does nobody has a suggestion or idea??
I would be very much thankful..
