simpleFoam error: "Cannot find patchField entry for cyclic"
Like Tree1Likes
  • 1 Post By AnasCFD
Old   June 26, 2015, 05:49
Default simpleFoam error: "Cannot find patchField entry for cyclic"
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hello Foamers,
I am learning OpenFOAM for my PhD. I will be doing wake effect analysis of the shrouded wind turbine by using actuator disc model. I just found a good paper that explains the implementations of an actuator disk in OpenFoam (See the links below).
http://www.tfd.chalmers.se/~hani/kur...ningReport.pdf
Furthermore, I found the actuator disk example (attached below) by the same author Erik Svenning posted in upper link, and it was made in version 1.5. I am currently using version 2.3.2. Moreover, I have been able to run blockMesh successfully, however, I can't view the mesh in paraFoam. And I get errors when trying to run simpleFoam of the example.
I am asking if anybody of you could find some time to explain what is exactly wrong with version 2.3.2.
Here is "the error"what I got when I ran blockMesh and simpleFoam:
"--> FOAM FATAL IO ERROR:
Cannot find patchField entry for cyclic fan_half0
Is your field uptodate with split cyclics?
Run foamUpgradeCyclics to convert mesh and fields to split cyclics.
file: /home/tariq/windturbine/project3/erikSvenningFiles/fan/0/p.boundaryField from line 34 to line 59.
From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&)
in file /home/tariq/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 192.
FOAM exiting
Thank in advance
fan.zip
tareqkh is offline   Reply With Quote
Old   June 26, 2015, 09:21
eruwaedhiel is on a distinguished road
This might not be much help, but I was trying to get that code working a few weeks ago for my own project, and came across this: http://www.cfd-online.com/Forums/ope...f2-1-help.html, which basically says not to try using that code.
What I wound up doing in the end was making a pressure jump baffle for the actuator disk following these tutorial: https://www.youtube.com/watch?v=7Ex1RHDQqIc and https://www.youtube.com/watch?v=qTYAr8jgViM
I'm currently trying to get it to converge with a helicopter fuselage mesh in simpleFoam, but the actuator disk portion at least seems to be doing what I expect it to.
eruwaedhiel is offline   Reply With Quote
Old   June 27, 2015, 02:45
tareqkh's Avatar
CFD
Hello eruwaedhiel.
Thank you for your response. Is there any way to start the same example from scratch? I feel that it would be perfect.
Thanks in advance.
Old   June 30, 2015, 18:46
Hi tareqkh,
Sorry for the delay, my computer died last week and I just got it back running yesterday. The two tutorials I posted actually provide all input files associated with them in the descriptions, so you can probably start from that (that's what I did).
Old   July 1, 2015, 03:22
anas
AnasCFD is on a distinguished road
In your case you are dealing with "cyclic" boundary conditions. This means that you have, after running the blockMesh, two faces named as "fan_half0" and "fan_half1". So you should define them in the 0 directory. If the two faces have the same boundary condition you can set, for example, in the 0/p file "fan.+" instead of "fan".
Enjoy
lincui likes this.
AnasCFD is offline   Reply With Quote
Old   July 3, 2015, 03:59
Default Adding the thrust and swirl
tareqkh's Avatar
CFD
Hello Anas and Eruwaedhiel,
Thank you for your time clarifying my confusion in the first part of the problem. I have tried to follow the steps about creating the solver in order to solve both thrust forces and swirl in the same project. I have successfully implemented the solver, however, for some reason I am not getting any velocities in Ux, Uy, and Uz. How can I make sure that the implementations are made correctly. I am really stuck at this solver.
Regards,
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 01:52
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 07:30
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
