janaf warning and printstack error simulating coal gasification by coalchemistryfoam |
June 21, 2015, 09:16 |
ahmad
Rep Power: 11 |
Hi
I am simulating coal gasification process in fluidized bed with coalchemistryfoam solver in OF 2.3.0. First I start with running it’s tutorial (simplified siwek). When i increase the internal field temperature from 400 to 1400, I meet the JANAF warning and printstack error so running had stopped. I changed the tutorial to my case conditions ( 1 inlet for coal and 1 inlet for air with an outlet at top of gasifier ) I have the same problems. I do the following procedures to solve it but it didn’t work:
I want to know it is solver’s problem (which it’s tutorial has error) or I am doing something wrong? Please help me and give a solution; my project had stopped for 3 month because of this error The boundary condition is attached. |
June 22, 2015, 02:34 |
out of temprature range(janaf warning) in coalchemistryfoam
ahmad
Rep Power: 11 |
Hi freinds
I want to simulate coal gasification process in fluidized bed with coalchemistryfoam solver in OF 2.3.0. use it’s tutorial (simplified siwek) for this purpose but just by increasing the internal field temperature from 400 to 1400, I meet the JANAF warning and printstack error so running had stopped. I do the following procedures to solve it but it didn’t work:
June 28, 2015, 16:13 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer:
June 29, 2015, 16:23 |
ahmad
Rep Power: 11 |
Dear Bruno Santos
thanks for your answer. I used OF 2.0.1 - 2.1.0 and 2.3.0 and this error apeare in all of them but i will try in OF 2.4.0 too. This error occurred after the internal temperature arrive at 900 kelvin, but before and after that any notable thing happened!! I read in other forums that this solver use for gasification that the range of temperature is between 800 to 1500, but i 'm not sure about it. |
August 20, 2015, 17:20 |
Bruno Santos
Rep Power: 128 |
Greetings akia,
So I finally managed to take a look into this and it's a bit disconcerting. I tested the tutorial "lagrangian/coalChemistryFoam/simplifiedSiwek" with OpenFOAM 2.4.x and the modification you stated, namely of changing the internal temperature from 400 to 1400 K and I ran the case with the Allrun script. There was no crash nor problems with Janaf. The only issue that occurred were several situations where this output was given: Code:
--> FOAM Warning : From function seulex::solve(scalar& x, scalarField& y, stepState& in file ODESolvers/seulex/seulex.C at line 255 step size underflow :2.710505431e-20 I have not tested with 2.3.0 no 2.4.0, so either the issue you mentioned is already fixed in 2.4.x, or you omitted important details for reproducing the error. Best regards, Bruno
January 12, 2016, 16:10 |
Howar
Rep Power: 11 |
Hello,akia
I would like to ask where is the tutorial of this coalchemistryfoam solver in OpenFOAM. I can't find it. Moreover, have you solved the problem? I also meet this kind of problem. Thank you |
January 31, 2016, 11:56 |
#7 | |
Bruno Santos
Rep Power: 128 |
tut cd lagrangian/coalChemistryFoam/simplifiedSiwek/ pwd
