LTSInterFoam BC problem
Like Tree1Likes
  • 1 Post By Tobi
Old   June 16, 2015, 11:38
Default LTSInterFoam BC problem
xu cong
xucong1228 is on a distinguished road
Hello Foamers
I am new to Openfoam and I am doing a simulation about drainage,you can see model I use from the attachment
length=5.5m
width=3m
depth=0.1m
The left side is inlet (Q=20 L/s)
The right side is outlet and there is a gully on the bottom.(we can assume the gully is the second outlet)
The top floor is atmosphere.
I used the LTSInterFoam for simulation because I heard this Foam is faster than interFoam.However, I found some very strange result after simulation:
1.As you can see in the attachment, the water cannot get into the gully.
2.The flow rate of inlet is not equal to the flow rate of two outlets.
I think it should be the problem of boundary condition, but I don't know which one it is.
So I listed my files U/P_pgh/alpha, I hope someone could help me.
P_pgh
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type           buoyantPressure;
        value          uniform 0;
    outlet
        type           zeroGradient;
    outlet2
        type           zeroGradient;
    sides
        value          uniform 0;
    atmosphere
        type           totalPressure;
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
    lowerwall
        value          uniform 0;
U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            flowRateInletVelocity;
        volumetricFlowRate  constant 20e-3;
        rhoInlet            1000;
    outlet
        type            zeroGradient;
    outlet2
        type            zeroGradient;
    sides
        type            fixedValue;
        value           uniform (0 0 0);
    atmosphere
        type            pressureInletOutletVelocity;
    lowerwall
        type            fixedValue;
alpha
dimensions      [0 0 0 0 0 0 0];
boundaryField
    inlet
        type            inletOutlet;
        inletValue     uniform 1;
        value           uniform 1;
    outlet
        type            zeroGradient;
    sides
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        inletValue     uniform 0;
        value           uniform 0;
    lowerwall
        type            zeroGradient;
    outlet2
       type            zeroGradient;
Lastly,can anyone tell me how to calculate the flow rate of water in this multiphase flow.I used the 'calculator' and 'integrate variable' from paraview.However i don't think it is precise.
Any help would be great, thank you so much!
xucong1228 is offline   Reply With Quote
Old   June 24, 2015, 10:02
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Boundary Condition for U
  • for the outlet you can use inletOutlet and set inletValue to zero to provide no backflow
  • the rest is okay
Boundary Condition for alpha
  • all boundary conditions are okay. Due to U you can set different BC for alpha.
  • here for example you can use zeroGradient for outlets, if you have determined that there is no backflow
Boundary Condition for p_rgh
  • the old game (: p_rgh is some imaginary pressure
  • maybe my small description will help you (it's not 100% correct, too lazy to make a new one )
inlet :: fixedFluxPressure
all walls :: fixedFluxPressure
outlet :: zeroGradient
atmosphere :: depend what you want, I always prefer to set the prghPressureBC
sharonyue likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   June 26, 2015, 05:20
xu cong
Thank you so much for your kind reply, my model seems better now, but there is still a problem about the velocity in the vertical exit.
The exit is just some fast air flow, the velocity is more than 1000m/s which is obviously wrong, and the pressure is very low.
Old   June 26, 2015, 05:35
Default velocity problem
xu cong
The simulation is better
but there is a problem with the vertical exit
The air speed is super high with a low pressure.
Why is that? is it because of the pressure of atmosphere?
Old   June 29, 2015, 08:48
Tobi's Avatar
Tobias Holzmann
normally you should not ask "why this happens" (:
Check your results, and then think about it. For me it seems that you choose a BC configuration that allows you to create a pressure gradient. This gradient will not be compensated with flux, so that a small gradient will always accelerate your flow till infinity or till your solver blow up.
Can you share you case?
Keep foaming,
Tobias Holzmann
Old   June 29, 2015, 09:51
Default case
xu cong
Here is my case.
Thank you for your reply and sorry about my way of asking.
It has been over two weeks and I can't solve it so I was a little bit frustrated, sorry about that.
boundary condition, flow rate, multiphase flow
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
