OpenFoam Pressure Inlet Oulet
Like Tree10Likes
  • 3 Post By tomf
  • 1 Post By al_th
  • 1 Post By tomf
  • 5 Post By al_th
Old   June 16, 2015, 07:51
Question OpenFoam Pressure Inlet Oulet
Jorge Lobera
jlobera is on a distinguished road
Hi all,
I'm new in CFD world; I have been working for three months with OpenFoam doing tutorials and some simple cases.
Now I´m working in my first real case. I´m trying to simulate flow and temperatura in the interior of a wind turbine using buoyantSimpleFoam solver.
The problem is that we have one outlet where we know the pressure but we don't know if the flow is going to enter or to go out. We have tried several BC but we don't find the correct one.
There are some InletOutlet Bc where you have to specify the velocity in the case of the flow entering; and we don´t know this value.
Anyone knows any solution or suggest to my problem? There are any BC where you shouldn´t specify the velocity value?
Thank you so much
jlobera is offline   Reply With Quote
Old   June 17, 2015, 05:56
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
It would probably be best ot use a combination of totalPressure for the pressure (equal to your environment pressure) and a pressureInletOutletVelocity boundary condition on the velocity.
Regards,
Tom
tomf is offline   Reply With Quote
Old   June 17, 2015, 08:02
Jorge Lobera
Thanks Tom,
pressureInletOutletVelocity is one of the BC that i have already tested, but I have used it with fixedFluxPressure for 0/p_rgh.
The problem with pressureInletOutletVelocity is that you should specify the value for the velocity if the flow is entering:
myPatch
type pressureInletOutletVelocity;
phi phi;
tangentialVelocity uniform (0 0 0);
value uniform 0;
When i have used this BC with this values, the flow is not able to enter. I know that there are zones in my surface where the flow should enter and other zones where the flow should go out.
Thanks
Old   June 17, 2015, 09:04
Al_th
al_th is on a distinguished road
Hi jlobera,
I am currently doing a simulation where I have an outlet that can let flow in or out.
If I remember correctly I am using the following BC at inlet and outlet (I specify fixed pressure at inlet/outlet)
Inlet
type pressureInletVelocity;
value uniform (0 0 0);
Outlet
I do not have any problem so far and flow looks physically correct.
You could also look at the BC "pressureInletOutletVelocityFvPatchVectorField " :
https://github.com/OpenFOAM/OpenFOAM...hVectorField.H
Velocity inlet/outlet boundary condition patches for where the pressure is
specified. zero-gradient is applied for outflow (as defined by the flux)
and for inflow the velocity is obtained from the patch-face normal
component of the internal-cell value.
kaifu likes this.
al_th is offline   Reply With Quote
Old   June 17, 2015, 09:12
Tom Fahner
Hi jlobera,
You do not have to specify the tangential velocity part and the "value" entry is just a placeholder for the first time-step. I agree with al_th, it should work. I do believe the fixedFluxPressure would mess things up since that one would need the flux over your patch, which you do not know.
Regards,
Tom
EFC likes this.
Old   June 17, 2015, 10:48
Jorge Lobera
Thank you so much tomf and al_th,
You are right, the problem was the fixedFluxPressure BC. I have tried using inletOutlet BC for velocity and fixedValue for pressure and it works well.
Can you explain me what's the difference between inletOutlet and pressureInletOutlet? And what is more correct to use in this case?
Regards
Old   June 17, 2015, 10:55
Al_th
As far as I can tell with my (poor) understanding of Openfoam :
- inletOutlet BC : You either have zero-gradient (when flow goes out) or a user specified velocity value (when flow goes in)
- pressureInletOutlet BC : You either have zero-gradient (when flow goes out) or a value that depends on the user specified pressure
If you want to set the pressure at the boundary, then using pressureInletOutlet can let you have a velocity vectorfield that is well defined according to the specified pressure.
Edit : This link can maybe give you additional insight into the pressureInletOutlet BC : http://www.cfd-online.com/Forums/ope...tvelocity.html
Old   March 10, 2019, 05:16
Jianrui Zeng
calf.Z is on a distinguished road
I am now using these boundary conditions for velocity/pressure:
velocity:
inlet: fixedValue
outlet: pressureInletOutletVelocity
pressurep_rgh)
inlet: fixedFluxPressure
outlet: fixedValue
Should this setting be suitable?I am now using buoyantSimpleFoam. Should we combine totalPressure and pressureInletOutletVelocity?
Thank you.
calf.Z is offline   Reply With Quote
Old   March 20, 2019, 11:25
Lukas Fischer
lukasf is on a distinguished road
I think that you can combine
totalPressure for p and pressureInletOutletVelocity for U at the outlet. I think it is a good approach for low compressible or incompressible flows.
lukasf is offline   Reply With Quote
Old   March 21, 2019, 00:02
Jianrui Zeng
Thank you, I will have a try.
Should totalPressure be used at outlet to match with pressureInletOutletVelocity which is used at outlet?
Old   June 6, 2020, 19:08
niewiemnic
spalartallmaras is on a distinguished road
For me this setting works really well,
Pressure:
inlet
    type zeroGradient;
outlet
    type totalPressure;
    rho none;
    p0 uniform 0;
    value uniform 0;
Velocity:
inlet
    type turbulentInlet;
    referenceField uniform (38 0 0);
    fluctuationScale (0.01 0.01 0.01);
    value uniform (38 0 0);
outlet
spalartallmaras is offline   Reply With Quote
air flow simulation, outlet bc, pressure bc, pressure boundary
Assign static pressure at inlet Tanjina FLUENT 0 November 3, 2013 12:34
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 13:41
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 23:46
Question about pressure inlet boundary condition. Alina FLUENT 1 November 30, 2007 08:39
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
