Negative value in scalarTransportFoam
Like Tree1Likes
  • 1 Post By chegdan
Old   June 12, 2015, 04:01
Default Negative value in scalarTransportFoam
waiter120 is on a distinguished road
Hello Foamusers.
I have made my own solver for complex electro-thermal problem with convective term.
This solver is based on scalarTransportFoam. And it use velocity filed that doesn’t change with time.
The main problem is with this convection term for temperature. If I use mesh with small element size and big time step, I get negative local value of temperature or very high temperature that is completely unphysical.
To deal with this I use small time steps and it gives a good results. But main task is to model very long period of time (200-500 hours). So calculation with time step of 1-10 seconds will be to long.
Can anyone suggest me the way other than work with mesh size or time step to break through this problem.
Thanks.
waiter120 is offline   Reply With Quote
Old   June 12, 2015, 11:00
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
This was actually one of those head scratching questions i had while in graduate school a fe years ago. Have a look at:
http://www.cfd-online.com/Forums/ope...tml#post280210
The problem I had was negative Concentrations on a tracer i was injecting to look at flow patterns
and dead zones. My tracer response curve was laughable (negative values) but this reformulation worked for me. I followed up in that post with where and why....so i hope that helps. Good luck
Bahram likes this.
chegdan is offline   Reply With Quote
Old   May 5, 2017, 07:13
Default Still geting negative values
novo
pnovo is on a distinguished road
I went through the whole (linked) thread and made the suggested modification and still get negative values in my results. I am testing the concentration profile inside a channel with two inlets, one outlet. First I find the steady-state U field using simpleFoam. Then I use the converged solution as an initial condition in scalarTransportFoam. At the inlets (equal flow rate) I inject 0 and 1 concentrations. After a few iterations ('have been decreasing the controlDict time steps systematically and now I am even doing sub-milli second steps) I can find concentration values to the power of 6 and beyond (also both and negative values). Wonder if you have additional hints to solve this issue?
Regards
pnovo is offline   Reply With Quote
Old   May 31, 2021, 13:16
hernan
tesorieri is on a distinguished road
I had a very similar problem with unbounded values using scalarTransportFoam with a fixed velocity field from a previous simpleFoam simulation.
I had two simpleFoam results from a low speed field and a high speed (5 times higher) simulations. The scalarTransportSimulation gave good results for the low speed case, but the high speed always gave unbounded results. I've tried reducing the timestep to a very small number and using diffusive schemes. Nothing worked until I recompiled scalarTransportFoam following the cited thread.
tesorieri is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
