Local mesh refinement introduces virtual vorticity in |
Yu Cheng
Rep Power: 12 ![]() |
Dear all,
I have compiled SOWFA(https://nwtc.nrel.gov/SOWFA) in OpenFOAM-2.1.0. Following the guide of Matt Churchfield and Sang Lee, precursor simulation using LES is performed for atmospheric boundary layer flow and a plane has been sliced as the inflow boundary condition for the simulation of a single NREL 5MW wind turbine in the plant. During mesh generation, local refinement is adopted around the turbine. Unfortunately virtual numerical vorticity appears after the mesh interface of different density,see the attached figure. Does anybody have suggestions for removing the virtual vorticity? Thank you for any comment. |
Yu Cheng
Hi all,
Since nobody has replied to this and I finally manage to solve the problem, I list my method here for the one who occurs the same problem.
At last, I attach the final result solved the problem. PS: it seems there is still some error downstream which I think is due to less weight of upwind scheme, I use 10% of upwind. |
Brian Connolly
Rep Power: 11 ![]() |
Thank you!!!!!
interpolation, les, openfoam, sowfa, vorticity |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 05:39 |
[mesh manipulation] local mesh refinement at channel geometries | Kr_kim | OpenFOAM Meshing & Mesh Conversion | 6 | February 9, 2010 14:25 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
