May 6, 2015, 22:57 |
maxCo in VOF interFoam
Rep Power: 15 |
Hi All,
I'm not sure if anyone is experiencing this in interFoam, that reducing the maxCo and alphaMaxCo from the default 1 will change the result quite a lot. Does this simply mean that a smaller Courant number is required? From some quick runs the results seems to not change much when the Courant number is 0.1. |
May 7, 2015, 10:43 |
#2 | |
Hao Chen
InterFoam uses a explicit time scheme, so I suppose the time step will affect the accuracy of the result. I always use Co < 0.35 - 0.5. However this is case sensitive. Best regards Hao Quote:
May 11, 2015, 05:09 |
Rep Power: 15 |
Thanks Hao, I assume that's just for the alpha equations? Is there a way to run them using an implicit time scheme?
September 7, 2015, 20:56 |
Santiago Marquez Damian
Rep Power: 24 |
Hi, you can go up in Co increasing nAlphaSubCycles accordingly.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
September 8, 2015, 09:56 |
Rep Power: 15 |
Just an update on this, in version 2.4.0 alpha is now solved semi-implicitly, and I no longer have this issue. Solution converged better with larger Courant numbers.
May 3, 2016, 04:40 |
#6 | |
Juan Fran
Rep Power: 10 |
I have been researching in the maxCo number in interFOAM. I checked that in the tutorial (OpenFoam 3.0) inteFoam/ras/waterChannel, maxCo and maxAlpha are given a value of 6. Same configuration is working for the problem that I'm studding (flow over a sloped channel with a control structure (a wall with a small notch on it)), obtaining a good result when comparing to the experimental results (turbulence and velocity profiles). However, when I try to justify the value and when I check for Co numbers, all references seem to agree that Co must be less than 1, and other tutorial and post seems to confirm this, with reasonable justifications. Can anyone provide me some light into this? Now, I’m simulating the same scenario with a maxCo and a maxAlpha equal to 1 to see the possible consequences of decreasing the values and, in turn, the max time step. best |
May 5, 2016, 02:32 |
Juan Fran
Rep Power: 10 |
Hi again,
So, the results obtained using maxCo=1 are similar to the ones obtained with maxCo=6 for the case that I'm studding, of course, the time steps are smaller. Thus, seems a good alternative the use high maxCo first until you reach to equilibrium and after simulate with smaller maxCos. A good explanation of why is possible to use higher maxCo can be found in: http://www.openfoam.org/version2.3.0/multiphase.php best |
Problem modeling hydraulic jump in an open channel with interFoam (VoF) | arnau1985 | OpenFOAM Running, Solving & CFD | 12 | December 26, 2022 06:54 |
Modelling falling solid sphere using interFoam VOF model | eelcovv | OpenFOAM Running, Solving & CFD | 6 | August 7, 2021 22:52 |
Vof method in interFoam | Andrea_85 | OpenFOAM | 10 | February 17, 2011 05:41 |
VOF - interFoam - strafitied Flow - bug in shear stress continuity at interface | AnjaMiehe | OpenFOAM Bugs | 0 | December 17, 2009 06:46 |
Are the VOF results of interFoam grid independent | asaha | OpenFOAM Running, Solving & CFD | 1 | June 26, 2009 05:27 |
