wave pattern problem running LTSInterFoam
Like Tree1Likes
  • 1 Post By kebsiali
Old   April 16, 2015, 11:53
Default wave pattern problem running LTSInterFoam
song sung jin
Alex song is on a distinguished road
hi dear all~!
I am a openfoam beginner.
I'm interested in calculating the flow around ships incl. the
free surface. I am using openFoam 2.3.0 to model the waves generated by a ship for a steady state. I want to get the wave pattern and also the pressure distribution along the hull.
When I run the calculation with LTSInterFoam (using a k-omegaSST turbulence model) and see the wave pattern on the surface of the hull, it appears some strange waves. I think the global wave pattern is fine. but when I see the wave pattern on the surface of the hull in parafoam, the wave problem occur at some point.
Does anyone use LTSInterFoam to model a free surface and know where my problem may come from?
and I've attached some picture
Thank you very much for any one could give me a little guideline
Alex song is offline   Reply With Quote
Old   April 16, 2015, 12:31
ali alkebsi
kebsiali is on a distinguished road
I would check the mesh at that location as first step.
try to change the nonOrthognalcorrection and nOutercorrection to force the solver to put more precision when solving the alpha equation.
try with different solvers in fvSolution.
at last check the turbulence parameters.
but mostly the local problems are mesh/solver related
Alex song likes this.
kebsiali is offline   Reply With Quote
Old   May 10, 2015, 04:14
song sung jin
Hi ali~!
Thanks for your reply. and I'm sorry this reply is too late.
I tried to change the nonOrthognalcorrection and nOutercorrection.
first, the nonOrthognalcorrection didn't solve my problem. so I changed the
nOutercorrection value from 1 to 3. my problem was solved at the value 2.
but I don't know why wave pattern clearly show only at the value 2.
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Problem running LTSInterFoam timothee OpenFOAM Running, Solving & CFD 7 June 26, 2014 17:49
Problem in running ansys fluent13 mamadou zein FLUENT 0 February 13, 2012 04:17
Problem with a leapfrog scheme for wave equation Shiranui Main CFD Forum 0 June 22, 2010 10:19
Suse10 FoamX problem frank178 OpenFOAM Installation 6 January 14, 2010 05:18
