DPMFoam / particle paramagnetic force
Like Tree1Likes
  • 1 Post By vonboett
Old   March 12, 2015, 11:48
Default DPMFoam / particle paramagnetic force
matin
matin is on a distinguished road
Dear Foamers,
I'm currently using DPMFoam and MagneticFoam to simulate flow containing particles in a magnetic field. To do this I have to first create the volVectorField HdotGradH, which I already did. I also have the particles in the channel. In order to apply the magnetic field I need to add the paramagnetic force to the kinematicCloudProperties directory, which Includes magneticSusceptibility & volvectorField HdotGradH.
I created my submodel as follow:
particleForces
WenYuDrag
alphac alpha.water;
gravity;
paramagnetic
magneticSusceptibility 6e-4; //m^3/kg
HdotGradH HdotGradH; //magnetic force
when I run the case, it gives the following error:
request for volVectorField HdotGradH from objectRegistry region0 failed
available objects of type volVectorField are
1(U.water)
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198.
FOAM aborting
#0 Foam::error:: srintStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const& Foam:: objectRegistry::lookupObject<Foam::GeometricField< Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#3 Foam::ParamagneticForce<Foam::KinematicCloud<Foam: :Cloud<Foam::CollidingParcel<Foam::KinematicParcel <Foam:: particle> > > > >::cacheFields(bool) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/liblagrangianIntermediate.so"
in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/DPMFoam"
My problem is that Openfoam does not recognize the HdotGradH file in the Zero directory and only sees the U.water as the volvectorfield !!
I tried every possible format, like the following:
HdotGradH HdotGradH.force;
HdotGradHName HdotGradH;
but the only case that program could run is:
HdotGradH U.water;
but it's not correct, cause I need to have magnetic field, not velocity field !
I would really appreciate if anyone could help me with this problem to see why OpenFoam does not see the HdotGradH file in the Zero directory.
Any help or reference regarding DPMFoam/MPPICFoam would be highly appreciated.
Best regards,
Matin
matin is offline   Reply With Quote
Old   May 20, 2016, 05:07
Albrecht vBoetticher
vonboett is on a distinguished road
although a late reply I'd like to note that it is helpful to look into createFields.H of the solver to see how fields are added to the object registry...
matin likes this.
vonboett is offline   Reply With Quote
dpmfoam, hdotgradh, magnetic field, mppicfoam, paramagnetic force
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Force can not converge colopolo CFX 13 October 4, 2011 23:03
how to perform temperature gradient on a particle (Thermophoretic Force) wwt650420 FLUENT 3 March 23, 2011 03:10
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
