March 11, 2015, 04:56 |
TwoPhaseEulerFoam high courant number
Hello Everyone
I am using OF 2.1.1 to simulate fluidized bed (twoPhaseEulerPoam). My geometry is 3D cylinder. My simulation works fine upto 0.6 sec and courant number remains well below 1 e.g. Courant Number mean: 0.0015972 max: 0.102484 Max Ur Courant Number = 0.0864022 But after 0.6 sec, it stats diverging and suddenly increases up to 1000. see the log file. What could be the possible problem. Thank you [QUOTE][/Courant Number mean: 0.00200133 max: 0.0987868 Max Ur Courant Number = 0.0853136 deltaT = 1.21324e-05 Time = 0.636997 DILUPBiCG: Solving for alpha, Initial residual = 6.99627e-05, Final residual = 4.09665e-12, No Iterations 2 Dispersed phase volume fraction = 0.243807 Min(alpha) = -2.1287e-05 Max(alpha) = 0.655422 DILUPBiCG: Solving for alpha, Initial residual = 1.04443e-07, Final residual = 1.24033e-11, No Iterations 1 Dispersed phase volume fraction = 0.243807 Min(alpha) = -4.54623e-07 Max(alpha) = 0.655422 kinTheory: max(Theta) = 1000 kinTheory: min(nua) = 9.16968e-11, max(nua) = 0.04 kinTheory: min(pa) = -1.92433e-08, max(pa) = 271622 GAMG: Solving for p, Initial residual = 0.0387725, Final residual = 0.00108617, No Iterations 1 time step continuity errors : sum local = 1.63039e-07, global = -3.89795e-08, cumulative = -1.47341e-06 GAMG: Solving for p, Initial residual = 0.00473594, Final residual = 6.99331e-09, No Iterations 15 time step continuity errors : sum local = 1.05671e-12, global = -3.54838e-13, cumulative = -1.47341e-06 DILUPBiCG: Solving for epsilon, Initial residual = 0.126719, Final residual = 3.52361e-08, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.0635536, Final residual = 1.17844e-08, No Iterations 3 ExecutionTime = 1456.39 s ClockTime = 1460 s Courant Number mean: 0.00202643 max: 0.099791 Max Ur Courant Number = 0.0877428 deltaT = 1.21558e-05 Time = 0.637009 DILUPBiCG: Solving for alpha, Initial residual = 7.00857e-05, Final residual = 3.30245e-12, No Iterations 2 Dispersed phase volume fraction = 0.243807 Min(alpha) = -1.94546e-05 Max(alpha) = 0.655419 DILUPBiCG: Solving for alpha, Initial residual = 9.28193e-08, Final residual = 1.58776e-11, No Iterations 1 Dispersed phase volume fraction = 0.243807 Min(alpha) = -7.98219e-07 Max(alpha) = 0.655419 kinTheory: max(Theta) = 1000 kinTheory: min(nua) = 9.18938e-11, max(nua) = 0.04 kinTheory: min(pa) = -3.40219e-08, max(pa) = 262061 GAMG: Solving for p, Initial residual = 0.0629067, Final residual = 0.00327559, No Iterations 1 time step continuity errors : sum local = 5.09797e-07, global = 3.84477e-07, cumulative = -1.08893e-06 GAMG: Solving for p, Initial residual = 0.522737, Final residual = 6.48233e-09, No Iterations 22 time step continuity errors : sum local = 6.07518e-12, global = -2.00598e-12, cumulative = -1.08894e-06 DILUPBiCG: Solving for epsilon, Initial residual = 0.774542, Final residual = 2.43972e-13, No Iterations 3 DILUPBiCG: Solving for k, Initial residual = 0.999999, Final residual = 1.83465e-08, No Iterations 11 ExecutionTime = 1458.38 s ClockTime = 1462 s Courant Number mean: 0.00243195 max: 2.85304 Max Ur Courant Number = 2.90461 deltaT = 4.18497e-07 --> FOAM Warning : From function Time:perator++() in file db/Time/Time.C at line 1010 Increased the timePrecision from 6 to 7 to distinguish between timeNames at time 0.637009 Time = 0.6370091 DILUPBiCG: Solving for alpha, Initial residual = 2.85712e-06, Final residual = 6.15549e-12, No Iterations 2 Dispersed phase volume fraction = 0.243807 Min(alpha) = -7.47147e-07 Max(alpha) = 0.655419 DILUPBiCG: Solving for alpha, Initial residual = 4.58626e-09, Final residual = 1.00269e-11, No Iterations 1 Dispersed phase volume fraction = 0.243807 Min(alpha) = -7.47147e-07 Max(alpha) = 0.655419 kinTheory: max(Theta) = 1000 kinTheory: min(nua) = 9.25553e-11, max(nua) = 0.04 kinTheory: min(pa) = -3.18112e-08, max(pa) = 255560 GAMG: Solving for p, Initial residual = 0.949397, Final residual = 0.0728741, No Iterations 1 time step continuity errors : sum local = 1.14736e-06, global = 8.30162e-07, cumulative = -2.58774e-07 GAMG: Solving for p, Initial residual = 0.00102808, Final residual = 7.87398e-09, No Iterations 16 time step continuity errors : sum local = 8.82252e-10, global = 2.98332e-10, cumulative = -2.58476e-07 DILUPBiCG: Solving for epsilon, Initial residual = 0.233328, Final residual = 1.09165e-13, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.964855, Final residual = 7.86549e-13, No Iterations 1 ExecutionTime = 1459.32 s ClockTime = 1463 s Courant Number mean: 0.000215521 max: 0.289072 Max Ur Courant Number = 26.6629 deltaT = 1.56958e-09 --> FOAM Warning : From function Time:perator++() in file db/Time/Time.C at line 1010 Increased the timePrecision from 7 to 8 to distinguish between timeNames at time 0.637009 Time = 0.63700909 DILUPBiCG: Solving for alpha, Initial residual = 2.49435e-07, Final residual = 2.05948e-11, No Iterations 1 Dispersed phase volume fraction = 0.243807 Min(alpha) = -7.47016e-07 Max(alpha) = 0.655419 DILUPBiCG: Solving for alpha, Initial residual = 5.46278e-10, Final residual = 1.11052e-13, No Iterations 1 Dispersed phase volume fraction = 0.243807 Min(alpha) = -7.47016e-07 Max(alpha) = 0.655419 kinTheory: max(Theta) = 1000 kinTheory: min(nua) = 9.24831e-11, max(nua) = 0.04 kinTheory: min(pa) = -3.18415e-08, max(pa) = 1.18596e+06 GAMG: Solving for p, Initial residual = 0.999857, Final residual = 0.0729551, No Iterations 1 time step continuity errors : sum local = 0.0181995, global = -0.00461067, cumulative = -0.00461093 GAMG: Solving for p, Initial residual = 0.0615916, Final residual = 8.77243e-09, No Iterations 24 time step continuity errors : sum local = 9.23584e-09, global = -3.17977e-09, cumulative = -0.00461094 DILUPBiCG: Solving for epsilon, Initial residual = 0.87258, Final residual = 6.82741e-06, No Iterations 10 DILUPBiCG: Solving for k, Initial residual = 0.917014, Final residual = 41215.3, No Iterations 1001 ExecutionTime = 1465.41 s ClockTime = 1469 s Courant Number mean: 0.572073 max: 260.204 Max Ur Courant Number = 13409.9 deltaT = 1.17047e-14 --> FOAM Warning : From function Time:perator++() in file db/Time/Time.C at line 1010 Increased the timePrecision from 8 to 9 to distinguish between timeNames at time 0.637009 Time = 0.637009086 DILUPBiCG: Solving for alpha, Initial residual = 1.13753e-07, Final residual = 3.97845e-12, No Iterations 1 Dispersed phase volume fraction = 0.243807 Min(alpha) = -7.29461e-07 Max(alpha) = 0.655419 DILUPBiCG: Solving for alpha, Initial residual = 3.31384e-10, Final residual = 4.6151e-14, No Iterations 1 Dispersed phase volume fraction = 0.243807 Min(alpha) = -7.2946e-07 Max(alpha) = 0.655419 kinTheory: max(Theta) = 1000 kinTheory: min(nua) = 9.1779e-11, max(nua) = 0.04 kinTheory: min(pa) = -1.82365, max(pa) = 1.89181e+08 GAMG: Solving for p, Initial residual = 0.961636, Final residual = 0.0531763, No Iterations 1 time step continuity errors : sum local = 1.45859e-07, global = -8.9757e-09, cumulative = -0.00461094 GAMG: Solving for p, Initial residual = 0.144315, Final residual = 1.49241e-07, No Iterations 1000 time step continuity errors : sum local = 2.90486e-06, global = 1.28668e-07, cumulative = -0.00461082] Regards |
March 11, 2015, 09:42 |
Dongyue Li
Rep Power: 18 |
Hello dude,
From my experience, this solver is mesh sensitive, So I suspect this might be the problem. could u pls tell us which kind of mesh do u use? tet or hex? Best, |
March 11, 2015, 10:16 |
Hello sharonyue
Thank you for your reply. I am using hexa mesh generated by using SHM (snappyHexMesh). Here is the my checkMesh result. Mesh stats points: 42241 faces: 122452 internal faces: 116332 cells: 40144 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 38064 prisms: 2080 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology allBoundary 0 0 ok (empty) inlet_inlet 772 797 ok (non-closed singly connected) outlet_outlet 772 797 ok (non-closed singly connected) wall_wall 4576 4664 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.11499987 -0.1148842 0) (0.11499986 0.1148842 0.38) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (3.4623065e-17 7.0086455e-16 -1.2106427e-16) OK. Max cell openness = 3.0660809e-16 OK. Max aspect ratio = 3.499081 OK. Minumum face area = 1.5619455e-05. Maximum face area = 8.1890858e-05. Face area magnitudes OK. Min volume = 9.1210546e-08. Max volume = 5.4318036e-07. Total volume = 0.015750168. Cell volumes OK. Mesh non-orthogonality Max: 24.633834 average: 3.0930508 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.7049643 OK. Coupled point location match (average 0) OK. Mesh OK. Regards |
March 11, 2015, 15:42 |
Dongyue Li
Rep Power: 18 |
From your log, looks like this is caused of your k and epsilon fields. have u ever tried with running it in laminar? Or maybe u can modify fvscheme of k and epsilon. Also u can check your latest result in paraview to see if epsilon is very big. and see if this thing happens in some bad cells. Best, Dongyue |
March 18, 2015, 15:04 |
#5 | |
Hello Dongyue
I also tried with laminar flow, the result is almost same. With laminar flow simulation didn't crash but delta t (time step) has decreased up to 10*e-11 after 0.4 sec of simulation. Initially it was taken 0.00001 and courant number was well below 0.1. Secondly I also tried with 2D mesh (simple rectangular geometry), all cells are of same size and no bad cell is present. Again my simulation crashed after 0.4 sec PS: for low velocity my simulation result is fine and it didn't crash but at higher velocity it crashes (even at high velocity courant number is smaller than 0.1 till 0.4 sec) my fvScheme is as follows. can you give some suggestions please about it Quote:
November 20, 2015, 12:02 |
Rep Power: 14 |
Hi, did u manage to stabalize your simulation?
I'm also experiencing crashes with twoPhaseEulerFoam and i am not sure what the cause could be. I'm running in laminar also. Do you have some experience with this solver u can share? Thanks! |
November 20, 2015, 12:19 |
Dongyue Li
Rep Power: 18 |
Hi guys,
I just found that in his Checkmesh log, there are prisms. I dont think twoPhaseEulerFoam can handle prisms. From my experience it can only paly with hex. Best,
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html |
November 20, 2015, 15:43 |
Rep Power: 14 |
Hi sharonyue,
this is a very interesting comment! I have indeed various types of cells in my geometry. I'm importing the mesh form ccm+ and actually i am confused i have all these types of cells, i thougth i would only have polyhedras. So i make from your post i should switch to 100% hexahedras. I will try it! Thanks // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 2062262 faces: 2403400 internal faces: 2350866 cells: 336222 faces per cell: 14.1403 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 317 prisms: 531 wedges: 3 pyramids: 1 tet wedges: 3 tetrahedra: 0 polyhedra: 335367 Breakdown of polyhedra by number of faces: faces number of cells 5 4 6 22 7 513 8 2349 9 7081 10 16375 11 22209 12 29420 13 44478 14 57475 15 57773 16 45517 17 28370 18 14311 19 6169 20 2235 21 753 22 239 23 60 24 10 25 4 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. <<Found 93 neighbouring cells with multiple inbetween faces. Upper triangular ordering OK. <<Writing 186 unordered faces to set upperTriangularFace Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Body2.Wall 43291 84241 ok (non-closed singly connected) Body2.Outlet 1705 3416 ok (non-closed singly connected) Body2.Edges 2645 5290 ok (non-closed singly connected) Body2.Inlet 4893 9786 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 0 -1.04157e-015) (1.34 0.31 0.5) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-1.6881e-016 3.15279e-017 3.68234e-016) OK. Max cell openness = 2.53791e-016 OK. Max aspect ratio = 8.16626 OK. Minimum face area = 4.03175e-010. Maximum face area = 0.000356587. Face area magnitudes OK. Min volume = 3.27702e-012. Max volume = 1.14262e-005. Total volume = 0.159208. Cell volumes OK. Mesh non-orthogonality Max: 73.5329 average: 14.3827 *Number of severely non-orthogonal (> 70 degrees) faces: 4. Non-orthogonality check OK. <<Writing 4 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 5.75398, 1 highly skew faces detected which may impair the quality of the results <<Writing 1 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End |
November 26, 2015, 18:22 |
#9 |
Rep Power: 14 |
Hi sharonyue,
its me again. I'm having a hard time getting rid of the prism cells in my geometry. I thought if i use snappyhex mesh it would only create hexadra cells but i also get these prism cells u said don't go well with twophaseeulerfoam. Since u worked with this solver can u give me a hint how i can avoid these bad cell types? is there any way around the solver crashes? thanks a lot for ur suggestions! |
November 27, 2015, 03:58 |
#10 | |
Dongyue Li
Rep Power: 18 |
Yeah, I use this solver to simulate stirred tanks. From my experience and the bug reports, twoPhaseEulerFoam and compressibleTwoPhaseEulerFoam need a perfect mesh, especially in turbulent situation. Here are a bug reports: http://www.openfoam.org/mantisbt/view.php?id=1379 Heney address this problem in OpenFOAM-dev. I did not try it, but I tried it with OpenFOAM 22x and 23x. Did not work. Another example for me is this: For this kind of irregular geometry, at first I tried with snappyHexMesh as of its simplicity. But it will diverge when running in turbulent simulation. It will tell you the epsilon (or k) field is quite large, then you will see the deltaT will be below of 1e-7 like that. So for me a absolutely perfect mesh is the only way. Even for the hex mesh above, I need to pay lots of time to make it better near the stick region. So I think at first you can try OpenFOAM-dev to try the new algorithm. In the mean time, you can write the bad fields in some time step then check it in paraview. I guess the velocity is quite large. Check if this quite large velocity locates in the bad mesh cells. Why dont u upload your geometry? Lets see if its possible for a hex mesh.
May 27, 2016, 09:32 |
#11 |
Rep Power: 11 |
Hi Dongyue
I see the errrors you me mentions: "It will tell you the epsilon (or k) field is quite large, then you will see the deltaT will be below of 1e-7 like that. So for me a absolutely perfect mesh is the only way." Do you solve it? Best Regards Masoud |
July 11, 2017, 15:19 |
#12 |
Hooman
Rep Power: 15 |
Hello BlnPhoenix and Dongyue,
Hope all is well with you. I am trying to use twoPhaseEulerFoam and reactingTwoPhaseEulerFoam. I tried reactingTwoPhaseEulerFoam because I read that it is more stable that the twoPhaseEulerFoam. But unfortunately both blow up. My temperatures go to huge number even though I do not solve for h/e equations (i simply put minIter and maxIter to zero). I used SHM to mesh my geometry and I do have prims mesh elements. I also consider a turbulent flow (k-E). Can you please let me know how you solved your problem? I am using OF 4.1! Thank you, |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 13:01 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 09:14 |
decomposePar pointfield | flying | OpenFOAM Running, Solving & CFD | 28 | December 30, 2013 16:05 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 11:37 |
