DPMFoam - Interpretation of UcEqn.H
Like Tree12Likes
  • 5 Post By kenyi89
  • 7 Post By kenyi89
Old   March 6, 2015, 10:24
Default DPMFoam - Interpretation of UcEqn.H
Jeroen Hofman
kenyi89 will become famous soon enough
Dear Foamers,
I am currently looking into the DPMFoam code and I have trouble understanding the UcEqn.H file:
1. Given the UcEqn:
fvVectorMatrix UcEqn
fvm::ddt(alphac, Uc) + fvm::div(alphaPhic, Uc)
- fvm::Sp(fvc::ddt(alphac) + fvc::div(alphaPhic), Uc)
+ continuousPhaseTurbulence->divDevRhoReff(Uc)
(1.0/rhoc)*cloudSU
Why is the interface momentum transfer term (cloudSU) already included? Also, I would guess the '==' is already solving the equation, but this doesn't make sense to me.
2. Directly under the definition of UcEqn:
UcEqn.relax();
What does it mean to 'relax' an equation? I understand the general principle of relaxation but fail to understand how an equation statement can be relaxed.
3. Regarding solving the momentum predictor:
if (pimple.momentumPredictor())
solve
UcEqn
fvc::reconstruct
phicForces/rAUcf - fvc::snGrad(p)*mesh.magSf()
If the 'cloudSU' term from question 1 would already be included, it is now included twice in the solver, as phicForces also represents interphase momentum transfer. The answer to question 1 will probably also explain the answer to this question.
Any help or reference to proper documentation regarding DPMFoam/MP-PIC would be highly appreciated.
Kind regards,
Jeroen
kenyi89 is offline   Reply With Quote
Old   March 10, 2015, 09:49
Default Answer question 2
Jeroen Hofman
Dear Foamers,
To answer my own question regarding relaxation of the momentum equation (question 2): It is described in Jasak's thesis on Finite Volume Method, equation 3.96:
In stead of relaxing the solution, which is done at a later stage in DPMFoam for the pressure, the coefficients of the momentum equation are relaxed to increase the diagonal dominance and hence the convergence rate. As far as I understood this is particularly important for steady state solutions, where the temporal derivative does not contribute to the diagonal.
Hope this helps anyone struggling as well
Ebrahim, vonboett, jylee4 and 2 others like this.
Old   March 20, 2015, 07:12
Default answer question 1/3
Jeroen Hofman
Again to answer my own question:
DPMFoam adds a semi-implicit treatment for the Uc term, meaning that cloudSU contains:
- drag (explicitly calculated, so handled as source term): drag_coefficient * (U_P - Uc_P)
- pressure gradient force (if added, also a source term)
- extra implicit part of the drag (drag_coefficient * Uc)
- extra MINUS explicit part of the drag (drag_coefficient * Uc)
The latter two sum to zero but is included to increase stability, as the drag itself is fully explicit. Notice the difference between the drag, which is calculated with the interpolated Uc value to the particle location, whereas the extra terms added contain simply the cell-mid Uc value. Any further explanation on why this is so would be helpful .
cloudSU has its source term part set to zero in the DPMFoam code, so eventually it only contains the third bullet from above (drag_coefficient * Uc, implicitly), this explains why it's included in the Uc equation, as it is an implicit term with Uc. cloudSUSu then contains the source part, which is drag + pressure gradient force - explicit drag part. cloudSUSu is included in the phicforces and ends up in solving the pEqn.
Hope this clarifies things a bit.
Jeroen
Ebrahim, vonboett, jylee4 and 4 others like this.
Old   March 24, 2015, 04:18
Default Thanks!
xue
d849c8 is on a distinguished road
your clarification is very helpful to me
d849c8 is offline   Reply With Quote
Old   January 19, 2016, 05:37
Albrecht vBoetticher
vonboett is on a distinguished road
Hi Jeroen,
I am not so familiar with DPMFoam and my modified version is not stable yet, but
I think the extra terms account for the numerical oscillations you may get in the pressure equation when simply adding source terms in the cell center. The PISO algorithm goes for solving U at the faces to avoid the pressure-velocity coupling problem on collocated meshes (Ferziger & Peric 2002). But as I saw you already took a look at the checkerboarding at http://www.cfd-online.com/Forums/ope...tml#post547057
vonboett is offline   Reply With Quote
Old   January 14, 2021, 14:28
Mingze Gao
mgao1 is on a distinguished road
Hi Jeroen,
I am also interested in how to calculate the source term. I know it is related to UTrans, but I could not find where the OpenFOAM defines the UTrans, could you please give me any clue. Thanks.
Ming
mgao1 is offline   Reply With Quote
dpmfoam
Collision spring stiffness value in DPMFoam maysmech OpenFOAM Programming & Development 11 March 25, 2022 23:53
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
Unrealistic results using DPMFoam Mojtaba.a OpenFOAM Running, Solving & CFD 4 January 24, 2015 11:28
Crash when using DPMfoam for LPT of objects contacting a vibrating wall ansubru OpenFOAM Running, Solving & CFD 0 May 1, 2014 04:24
Riemann invariants....Any physical interpretation? Farouk Main CFD Forum 3 July 11, 2013 08:58
