running cylinder tutorial of reactingParcelFilmFoam in parallel
Like Tree1Likes
  • 1 Post By neilk
Old   February 9, 2015, 06:39
Default running cylinder tutorial of reactingParcelFilmFoam in parallel
Bernhard Peters
BPeters is on a distinguished road
Dear all,
I have taken the cylinder tutorial of reactingParcelFilmFoam and ran it sequentially and no problems. Then I did decomposePar for running it on 2 processors. Parallel run started and stopped then with the following error message from each procesor:
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] Cannot find file "points" in directory "wallFilmRegion/polyMesh" in times 0 down to constant
[0]
[0] From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
[0] in file db/Time/findInstance.C at line 188.
[0]
FOAM parallel run exiting
I cannot make any sense out of this message and the usual tricks do not work. Anybody having a similar experience and better a solution.
Thanks.
BPeters is offline   Reply With Quote
Old   March 26, 2016, 21:07
Default reactingParcelFilmFoam in parallel
aee
Andrew Eisenhawer
aee is on a distinguished road
This solver uses two meshes: one for the (single phase) bulk flow regime and one for the wall film. The mesh for the air space is what is decomposed with decomposePar. To decompose the mesh for the wall region as well, you first need to run
decomposePar -region wallFilmRegion
See the Allrun-parallel script in the HotBox tutorial. The "wallFilmRegion" mesh is extruded from the original mesh.
aee is offline   Reply With Quote
Old   May 7, 2018, 14:34
Nilay Kulkarni
neilk is on a distinguished road
I want to run a simulation for a complex geometry with a very thin film on the surface. Is there a way to introduce the thin film over a custom surface and solve it as a 3D problem? If so, can we increase the number of elements in the thin film region?
The OpenFoam version I'm using is 17.10
Thank you.
Ladan.s likes this.
neilk is offline   Reply With Quote
Old   March 11, 2020, 02:26
openfoamerdodo is on a distinguished road
the wall film mesh means that there is another set of equations for the film?
if so ,how can i modify it to fit in my case?
ps: i want to modify a new mass transfer model with the film model
openfoamerdodo is offline   Reply With Quote
SU2 Tutorial 2 Parallel Computation CrashLaker SU2 7 April 5, 2014 17:14
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 05:59
parallel running openFoam-1.5-dev lulo OpenFOAM 3 October 3, 2011 12:42
Running PimpleDyMFoam in parallel paul b OpenFOAM Running, Solving & CFD 8 April 20, 2011 06:21
Drag on non-infinite cylinder between parallel walls deltaquattro Main CFD Forum 0 September 10, 2009 14:01
