enthalpie error
Like Tree1Likes
  • 1 Post By alexeym
Old   February 3, 2015, 11:00
Default enthalpie error
P_P
P_P is on a distinguished road
currently I am trying to calculate the heat transfer in a bubble column with two phases. In order to do so I have to solve a couple of enthalpie equations.
Unfortunately the calculation stops at the very beginning with the following report:
fehler 8
#0 Foam::error:rintStack(Foam::Ostream&) in "/software/openfoam/2.2.2/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/software/openfoam/2.2.2/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
at sigaction.c:0
#3 Foam:ICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) in "/software/openfoam/2.2.2/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam:ICSmoother:ICSmoother(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) in "/software/openfoam/2.2.2/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::lduMatrix::smoother::addsymMatrixConstructor ToTable<Foam:ICSmoother>::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) in "/software/openfoam/2.2.2/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam::lduMatrix::smoother::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) in "/software/openfoam/2.2.2/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#7 Foam::GAMGSolver::initVcycle(Foam::PtrList<Foam::F ield<double> >&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::lduMatrix::smoother>&) const in "/software/openfoam/2.2.2/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#8 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/software/openfoam/2.2.2/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#9 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) in "/software/openfoam/2.2.2/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#10 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/rafii/OpenFOAM/rafii-2.2.2/platforms/linux64GccDPOpt/bin/multiphaseTempEulerFoam_CTM_enthalpy_zeroModel"
#11 Foam::fvMatrix<double>::solve() in "/home/rafii/OpenFOAM/rafii-2.2.2/platforms/linux64GccDPOpt/bin/multiphaseTempEulerFoam_CTM_enthalpy_zeroModel"
#12
#13 __libc_start_main in "/lib64/libc.so.6"
#14
Floating point exception
The first line saying "fehler 8" gives me the possibility to track the exact position of the problem.
The piece of code which causes this problem is as follows:
Info<< "fehler 7 " << nl << endl;
volScalarField mut1 = nut*rho1;
dimensionedScalar null("null",dimensionSet(1,-1,-3,0,0,0,0), scalar(0.0));
Qint1 = min((heatTransferCoeff*(T1-T2)),null);//änderung
Info<< "fehler 8 " << nl << endl;
solve
fvm::laplacian((alpha1*mut1), he1_turb)
Since there exists no possibility that a division by 0 occurs, I wonder where this problem may come from. Can you help me out ?
Greatz P_P
P_P is offline   Reply With Quote
Old   February 3, 2015, 11:18
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
I won't be so sure, as the error occurs here:
void Foam::DICPreconditioner::calcReciprocalD
    scalarField& rD,
    const lduMatrix& matrix
    scalar* __restrict__ rDPtr = rD.begin();
    // Calculate the DIC diagonal
    register const label nFaces = matrix.upper().size();
    for (register label face=0; face<nFaces; face++)
        rDPtr[uPtr[face]] -= upperPtr[face]*upperPtr[face]/rDPtr[lPtr[face]];
    // Calculate the reciprocal of the preconditioned diagonal
    register const label nCells = rD.size();
    for (register label cell=0; cell<nCells; cell++)
        rDPtr[cell] = 1.0/rDPtr[cell];
where rD is "The reciprocal preconditioned diagonal". If you've got infinity on the diagonal, then reciprocal is zero.
P_P likes this.
alexeym is offline   Reply With Quote
Old   February 3, 2015, 11:36
P_P
Thank you very much for your reply,
do you have an idea how to solve this problem? How can i prevent infinity on the diagonal? If this is not possible would another preconditioner be the best solution?
Old   February 3, 2015, 11:47
Alexey Matveichev
In general the error means diverging solution. Surely you can try to use GAMG (you can find syntax for it in tutorial cases) as preconditioner but the change in precoditioner will not remove inconsistency of initial and boundary conditions, will not correct the model etc.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
