Continuity error cannot be removed by adjusting the outflow. Please check the velocit
Like Tree2Likes
  • 2 Post By Tobi
Old   January 20, 2015, 04:17
Default Continuity error cannot be removed by adjusting the outflow. Please check the velocit
Warning
range_rover is on a distinguished road
Hey guys
I am very new to openfoam, when i am using icofoam solver i have been facing this continuity error ,i am having an inflow in horizontal and outflow in vertical. i tried my ways to get over it , i am not able to can any body help me on this.
Error:
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 376.432
Specified mass inflow : 20
Specified mass outflow : 7220
Adjustable mass outflow : 0
From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
in file cfdTools/general/adjustPhi/adjustPhi.C at line 118.
FOAM exiting
P-file
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
walls
type zeroGradient;
U-file
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (10 0 0);
outlet
type fixedValue;
value uniform (0 0 20);
walls
type fixedValue;
value uniform (0 0 0);
range_rover is offline   Reply With Quote
Old   January 20, 2015, 04:36
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
It looks like area of the outlet is around 180 time greater than area of the inlet. Can you post screenshot of your mesh?
alexeym is offline   Reply With Quote
Old   January 20, 2015, 04:41
Warning
Yeah, you are true
I just figured it out, i adjusted my boundary conditions and it worked fine
thanks for your reply
Old   August 13, 2016, 08:50
alex
crusen mind is on a distinguished road
hi when i run simulation i am getting this error
PHP Code:
FOAM FATAL ERROR
5Continuity error cannot be removed by adjusting the outflow.
Total flux              11.8087
1.42626
0.0135246
1.56994e-21
crusen mind is offline   Reply With Quote
Old   August 13, 2016, 09:56
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
This error tells you that it is not possible to adjust your fluxes. This happens if you define your problem weakly. So check your BC and make sure that you have physical BC.
E.g. (just one of a lot of examples)
  • if you define U and p to zeroGradient everywhere, think about how many solutions would be valid that the momentum is fulfilled
  • It is like setting pressure and velocity at the inlet, the outlet can now get a lot of valid results based on velocity / pressure (just for incompressible / low Mach)
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   August 16, 2016, 03:42
alex
now i have increased my domain size, and i will use the boundary condition given in the propeller tutorial case.
Old   August 16, 2016, 04:15
alex
I am getting this error
PHP Code:
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  4.0                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
|    \\/     M anipulation  |                                                 |
Build  4.0-665f1db4c1f1
Exec
pimpleDyMFoam -parallel
Date
Aug 16 2016
Time
12:42:08
Host
"velan-OptiPlex-9020"
PID    3993
Case   : /home/velan/prop
nProcs
8
Slaves
7
"velan-OptiPlex-9020.3994"
"velan-OptiPlex-9020.3995"
"velan-OptiPlex-9020.3996"
"velan-OptiPlex-9020.3997"
"velan-OptiPlex-9020.3998"
"velan-OptiPlex-9020.3999"
"velan-OptiPlex-9020.4000"
Pstream initialized with:
floatTransfer      0
    nProcsSimpleSum
0
    commsType
nonBlocking
    polling iterations
0
sigFpe
Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking Monitoring run-time modified files using timeStampMaster
allowSystemOperations
Allowing user-supplied system call operations
Create time
Create mesh
for time 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid
-body motion function rotatingMotion
Applying solid body motion to cellZone innersmallcyclinder
PIMPLE
no residual control data foundCalculations will employ 2 corrector loops
Reading field p
Reading field U
Reading
/calculating face flux field phi
AMI
Creating addressing and weights between 3324 source faces and 3324 target faces
AMI
Patch source sum(weightsmin/max/average 111
AMI
Patch target sum(weightsmin/max/average 111
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu             0.09;
C1              1.44;
C2              1.92;
C3              -0.33;
sigmak          1;
sigmaEps        1.3;
No MRF models present
Reading
/calculating face velocity Uf
No finite volume options present
Courant Number mean
4.99969e-06 max0.00139283
Reading surface description
zNormal
    isoQ
    propeller
forces forces
Not including porosity effects
Starting time loop
Courant Number mean
4.95019e-06 max0.00137904
deltaT
1.17647e-05
Time
1.17647e-05
AMI
AMI
Patch source sum(weightsmin/max/average 0.9994071.00220.999993
AMI
Patch target sum(weightsmin/max/average 0.9991511.002160.999983
PIMPLE
iteration 1
smoothSolver
:  Solving for UxInitial residual 1, Final residual 4.38333e-08No Iterations 1
smoothSolver
:  Solving for UyInitial residual 1, Final residual 4.70697e-08No Iterations 1
smoothSolver
:  Solving for UzInitial residual 1, Final residual 4.26061e-08No Iterations 1
[2#0  Foam::error::printStack(Foam::Ostream&)[3] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
at ??:?
3#1  Foam::sigFpe::sigHandler(int)[2] #1  Foam::sigFpe::sigHandler(int) at ??:?
[3#2  ? at ??:?
[2#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[2#3   in "/lib/x86_64-linux-gnu/libc.so.6"
Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Fielddouble> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const[3#3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
[3#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
[2#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
[3#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[2#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[3#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
[2#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
[3#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
[3#8   at ??:?
[2#7  ?Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
[3#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[3#10   at ??:?
[2#8  ?? at ??:?
[velan-OptiPlex-9020:03996] *** Process received signal ***
velan-OptiPlex-9020:03996SignalFloating point exception (8)
velan-OptiPlex-9020:03996Signal code:  (-6)
velan-OptiPlex-9020:03996Failing at address0x3e800000f9c
[velan-OptiPlex-9020:03996] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36cb0) [0x7fcf7703ecb0]
velan-OptiPlex-9020:03996] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x37) [0x7fcf7703ec37]
velan-OptiPlex-9020:03996] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36cb0) [0x7fcf7703ecb0]
velan-OptiPlex-9020:03996] [ 3] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xb6) [0x7fcf78211976]
velan-OptiPlex-9020:03996] [ 4] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0xe81) [0x7fcf78215ed1]
velan-OptiPlex-9020:03996] [ 5] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x48b) [0x7fcf782179ab]
velan-OptiPlex-9020:03996] [ 6] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x11e) [0x7fcf7b0e0afe]
velan-OptiPlex-9020:03996] [ 7pimpleDyMFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x108) [0x466888]
velan-OptiPlex-9020:03996] [ 8pimpleDyMFoam() [0x425ce9]
velan-OptiPlex-9020:03996] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fcf77029f45]
velan-OptiPlex-9020:03996] [10pimpleDyMFoam() [0x4273a7]
velan-OptiPlex-9020:03996] *** End of error message ***
at ??:?
2#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[2#10  ? at ??:?
[velan-OptiPlex-9020:03995] *** Process received signal ***
velan-OptiPlex-9020:03995SignalFloating point exception (8)
velan-OptiPlex-9020:03995Signal code:  (-6)
velan-OptiPlex-9020:03995Failing at address0x3e800000f9b
[velan-OptiPlex-9020:03995] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36cb0) [0x7fe0d3628cb0]
velan-OptiPlex-9020:03995] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x37) [0x7fe0d3628c37]
velan-OptiPlex-9020:03995] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36cb0) [0x7fe0d3628cb0]
velan-OptiPlex-9020:03995] [ 3] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xb6) [0x7fe0d47fb976]
velan-OptiPlex-9020:03995] [ 4] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0xe81) [0x7fe0d47ffed1]
velan-OptiPlex-9020:03995] [ 5] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x48b) [0x7fe0d48019ab]
velan-OptiPlex-9020:03995] [ 6] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x11e) [0x7fe0d76caafe]
velan-OptiPlex-9020:03995] [ 7pimpleDyMFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x108) [0x466888]
velan-OptiPlex-9020:03995] [ 8pimpleDyMFoam() [0x425ce9]
velan-OptiPlex-9020:03995] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fe0d3613f45]
velan-OptiPlex-9020:03995] [10pimpleDyMFoam() [0x4273a7]
velan-OptiPlex-9020:03995] *** End of error message ***
mpirun noticed that process rank 3 with PID 3996 on node velan-OptiPlex-9020 exited on signal 8 (Floating point exception).
Old   August 17, 2016, 02:12
alex
when i dont supply velocity at inlet my simulation is running
continuity error, openfoam 2.1
Continuity error cannot be removed by adjusting the outflow fontania OpenFOAM Running, Solving & CFD 1 October 9, 2012 11:36
simpleFoam airfoil2d Continuity error cannot be removed junkie71189 OpenFOAM Running, Solving & CFD 3 August 9, 2012 14:58
PISO nCorrectors and fatal error jdkummer OpenFOAM Running, Solving & CFD 10 May 30, 2011 17:55
MRFInterFoam: Trouble with direction of gravity / Continuity error cannot be removed bengt OpenFOAM Running, Solving & CFD 2 May 28, 2010 15:45
sloshingTank2D3DoF: "Continuity error cannot be removed by adjusting the outflow." juergenstarck OpenFOAM Running, Solving & CFD 3 May 17, 2009 05:01
