Mass conserving velocity boundary condition between two regions |
January 9, 2015, 06:22 |
Nils
I am working on a solver similar to chtMultiRegionFoam. However, my case deals with the heat transfer from one fluid to another (non-newtonian) fluid. The newtonian and non-newtonian regions are separated by a stationary membrane. Because none of the regions is solid, I also need to couple the velocities at both sides of the interface between both regions. To start with, the chtMultiRegionFoam uses the compressible::turbulentTemperatureCoupledBaffleMix ed BC to map the temperature T from one region (solid) to another region (fluid). I need a similar BC to map as well the velocity U from one fluid region to another fluid region, such that rho1*U1=rho2*U2. Does such a BC exist? If not, which existing BC should I study and extend to develop the required BC? Thanks Nils |
November 7, 2016, 08:13 |
Default Mass conserving velocity boundary condition between two regions
Max
Rep Power: 9 |
Hello Nils,
I am currently working on a very similar problem and was curious to know if you ever figured out how to solve a mass conserving boundary condition between two fluid regions. Cheers |
June 28, 2021, 06:37 |
yasmin
Hiya Nils and Max,
I am working on a similar case too and I was just wondering, have you figure out the problem???? Last edited by yasmin; June 28, 2021 at 07:45. |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 04:13 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
mass transfer coefficient for boundary condition | niek | Main CFD Forum | 0 | March 29, 2011 05:33 |
