rhoSimpleFoam - strange behaviour of the residuals |
December 12, 2014, 10:20 |
Rep Power: 13 |
Hey,
I'm getting some strange results for the residuals of my simulation. For the first 2000 iterations it looks ads if the simulation will converge. However, afterwards I'm getting strange "jumps" in the values of the residuals, as you can see in the attached plot. I didn't change any files or values during the simulation. Does anybody know what could be source of this behaviour? I'm using rhoSimpleFoam with the following fvSchemes and fvSolution files: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default bounded Gauss upwind; div(phi,U) bounded Gauss upwind; div((muEff*dev2(T(grad(U))))) Gauss linear; div(phi,e) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,Ekp) bounded Gauss upwind; } laplacianSchemes { default Gauss linear corrected; laplacian(muEff,U) Gauss linear corrected; laplacian(alphaEff,e) Gauss linear corrected; laplacian((rho*(1|A(U))),p) Gauss linear corrected; laplacian(DomegaEff,omega) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-08; relTol 0.05; smoother GaussSeidel; cacheAgglomeration off; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.1; } e { solver PBiCG; preconditioner DILU; tolerance 1e-08; relTol 0.1; } "(k|omega)" { $U; tolerance 1e-09; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 2; rhoMin rhoMin [ 1 -3 0 0 0 ] 0.5; rhoMax rhoMax [ 1 -3 0 0 0 ] 10; residualControl { p 1e-8; U 1e-8; e 1e-8; // possibly check turbulence fields "(k|epsilon|omega)" 1e-8; } } relaxationFactors { fields { p 0.1; //0.1 rho 0.05; //0.05 } equations { U 0.7; //0.7 k 0.7; //0.7 omega 0.7; //0.7 e 0.7; //0.7 } } |
December 12, 2014, 15:17 |
Joachim Herb
Rep Power: 22 |
This is probably caused because the solution of the omega/U equation reaches (is lower than) the absolute limit of the solver set in system/fvSolution, something like
tolerance 1e-09; |
December 16, 2014, 05:27 |
Rep Power: 13 |
Thank you, decreasing the tolerance solved my problem!
edit: No, it didn't, it just delayed it a bit. Although I decreased the tolerance to 1e-9 it still happened. Last edited by Werne; December 17, 2014 at 06:32. |
strange pressure behaviour with symmetricPlane boudary condition - interFoam | duongquaphim | OpenFOAM Running, Solving & CFD | 10 | August 20, 2013 15:00 |
Strange residuals behaviour | xxxx | Main CFD Forum | 1 | July 13, 2013 15:40 |
Strange residuals of the Density Based Solver | Pat84 | FLUENT | 0 | October 22, 2012 16:59 |
kOmegaSST omega residuals strange behaviour | zordiack | OpenFOAM Running, Solving & CFD | 0 | August 8, 2012 17:23 |
Strange Residuals in CCM+ | PeterGG | Siemens | 3 | July 27, 2007 13:52 |
