How to Define heat generation rate that changes with the system coordinate.
Like Tree2Likes
  • 1 Post By a19910112a
  • 1 Post By hesong
Old   December 2, 2014, 07:20
Default How to Define heat generation rate that changes with the system coordinate.
zech
a19910112a is on a distinguished road
Hi Foamers,
This question was posted years ago and seems no good enough answer to it. I have the picture of the problem:
This is a very simple question similar to the planewall2D question, except the bottom air is changed by a heat generation block. I managed to do this with a constant heat generation rate and the case file is attached.
The current problem is that I want to set the heat generation rate that changes according to the system coordinate. Something like q'''=cos (x), which I think should be easily done by editing some lines in the fvOption file.
Anyone could suggest a method to do this?
I have been considering the scalarCodedSource utility, but the C++ is a little bit confusing. Anyone has an example on this? I have the officially provided example, but some illustration for the code is needed.
raj kumar saini likes this.
a19910112a is offline   Reply With Quote
Old   December 7, 2014, 06:12
Jens Höpken
jhoepken is on a distinguished road
Send a message via Skype™ to jhoepken
Hi a19910112a from England ,
what exactly is your problem with the codedSource and C++? The particular hooks used are explained in the sources quite well (on an average OpenFOAM level, to be fair).
If you just want to change the temperature on the walll, why don't you go for groovyBC or code your own?
Blog: sourceflux.de/blog
"The OpenFOAM Technology Primer": sourceflux.de/book
Twitter: @sourceflux_de
Interested in courses on OpenFOAM?
jhoepken is offline   Reply With Quote
Old   December 12, 2014, 04:22
hello
hesong is on a distinguished road
you can try this
myPatch
type codedFixedValue;
value uniform 0;
redirectType myFixedValue; // name of generated BC
code
forAll(*this, i)
scalar z = patch().Cf()[i][2];
if (z > 0 && z < 32)
(*this)[i] = 0.0075 * z -1.58;
else if (...)
else
codeInclude
#include "fvCFD.H"
codeOptions
-I$(LIB_SRC)/finiteVolume/lnInclude
hesong is offline   Reply With Quote
fvoptions, heat sources
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Heat generation Rate MARIO276 FLUENT 3 February 20, 2013 09:57
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
Inconsistent Total Heat Transfer Rate Ken Adams FLUENT 0 July 24, 2007 12:04
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
