which edition of the solver does it choose to run? |
November 24, 2014, 07:17 |
Dongyue Li
Rep Power: 18 |
Hi guys,
I make a solver called "icoFoam" into FOAM_USER_APPBIN, however, there is also the original one called icoFoam in FOAM_APPBIN, the question is when I run icoFoam, which one is launched? This is just a example, because I have my own solver which's name is the same with the original(it should not be actually,). the problem is when I delete this solver in FOAM_USER_APPBIN, the original solver in FOAM_APPBIN can not be launched either!! I dont know why. I mean, shouldn't it be launched either with the solver in FOAM_USER_APPBIN or in FOAM_APPBIN? Thanks. |
November 24, 2014, 07:51 |
you can ask your shell with Code:
$ which icoFoam |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
Error message after solver finished the run | mejahan | CFX | 0 | November 20, 2013 16:46 |
Problem with parallel run of my solver based on pimpleDyMFoam | o.kotsur | OpenFOAM Running, Solving & CFD | 0 | October 6, 2013 04:44 |
Why run the solver twice ("cavity" tutorial section 2.1.8.2)? | a330 | OpenFOAM Running, Solving & CFD | 0 | February 27, 2012 12:15 |
Help, can't stop solver run...Windows OS | ben akih | CFX | 2 | November 13, 2006 11:05 |
