y+ selection with epsilonWallFunction and omegaWallFunction
Like Tree8Likes
  • 1 Post By gregjunqua
  • 7 Post By wc34071209
Old   November 6, 2014, 10:24
Default y+ selection with epsilonWallFunction and omegaWallFunction
Yuehan
wc34071209 is on a distinguished road
Hi all,
For omegaWallFunction, OpenFOAM employs the strategy as follows
omega = sqrt(omega_vis^2 + omega_log^2)
which seems to be able to automatically take care of first layer thickness no matter it falls in viscous sublayer (y+ < 5) or log-law region ( y+ > 30 ) or even in the buffer layer ( 5 < y+ < 30 ).
However, for epsilonWallFunction, OpenFOAM seems to apply the following formula:
epsilon = Cmu^0.75 * k^ 1.5 / (kappa *y);
which is reported to be valid only when the first layer thickness falls into log-law region.
So my question is what will happen if I use epsilonWallFunction (k-epsilon model) with a grid where y+ < 5.
wc34071209 is offline   Reply With Quote
Old   November 6, 2014, 20:39
Gregoire Junqua
gregjunqua is on a distinguished road
You answered by yourself, you will use an invalid boundary condition since some wall function are only valid for the logarithmic layer position and when y+<5 you are in the linear sublayer.
For low Reynolds model I personally use for the wall condition :
k fixed value 10e-12
omega fixed value 10e9
nut nutUSpaldingWallFunction
U fixed value 0
If you need more information i suggest you to read : On the wall Boundary condition for turbulence models
from Jonas Bredberg
You would find many answer in it in all your questions about wall condition
Yanagi likes this.
Gregoire Junqua
Ocean University of China
PhD Oceanography/ABL turbulence
gregjunqua is offline   Reply With Quote
Old   November 6, 2014, 21:00
Yuehan
U fixed value 0
from Jonas Bredberg
Thanks. Actually I am also wondering why kqRWallFunction treats k just as zeroGradient. Apparently at the wall k should be zero.
By specifying k to a very small number and omega a very big number, I think you have to use very fine grid inside the boundary layer, e.g. y+ ~ 1 or even smaller.
nutUSpaldingWallFunction, as far as I know, is kind of continuous wall function which can work for both y+ < 5 and > 30. However, nutLowReWallFunction sounds, by its name, to be more suitable if you resolve the boundary layer.
Could I conclude as follows:
For y+ > 30,
k: kqRWallFunction
omega: omegaWallFunction or epsilon: epsilonWallFunction
nut: nutkWallFunction
For 1 < y+ < 5,
k: kqRWallFunction
omega: omegaWallFunction (k-epsilon is not suitable)
nut: not so sure
For y+ < 1,
k: very small number
omega: very big number (k-epsilon is not suitable)
nut: nutLowReWallFunction
For non-uniform y+ (between 1 and 100), however, is it better to use the following?
k: kqRWallFunction
nut: nutUSpaldingWallFunction
Old   March 13, 2018, 10:20
kaaja is on a distinguished road
k: kqRWallFunction
Does anybody know if the above is correct?
kaaja is offline   Reply With Quote
