Initialization
Like Tree3Likes
  • 2 Post By RodriguezFatz
  • 1 Post By RodriguezFatz
Old   October 27, 2014, 12:14
Default Initialization
SinaJ
sina_mech is on a distinguished road
I'd like to redo a simulation that I've already done on Fluent 14.5, with OpenFoam.
In fluent, there is an option for initialization : Hybrid Initialization
I was wondering if I could use the same thing in OpenFoam.
Thank you :-)
sina_mech is offline   Reply With Quote
Old   October 28, 2014, 04:58
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
I think this is more or less the same as the "potentialFoam" solver in openFoam. It will run for a certain amount of iterations an then overwrite the files in the "zero" directory of your case, as the new initial settings.
Put this
potentialFlow
    nNonOrthogonalCorrectors 10;
into your fvSolution and just run "potentialFoam" in your terminal.
If you have stability problems with your main case, just write again in this thread. OpenFoam is not as easy as Fluent...
sina_mech and Mehdi Rami like this.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   November 3, 2014, 12:55
SinaJ
Thank you for your help.
But the answer of potential flow in openfoam is far from what hybrid initialization gives you in Fluent.
Old   November 4, 2014, 05:11
Thumbs up
Philipp
Alright, good to know. I just read "laplace" and thought this will probably be the same
Old   November 4, 2014, 05:21
Philipp
After reading the equations, yes, you are right. But by means of getting some smooth initial guess depending on the boundary conditions for p and U they (potentialFoam and hybrid init.) are quite comparable.
sina_mech likes this.
FMG initialization query Mohsin FLUENT 6 November 2, 2016 03:02
CFX temperature initialization jp_ CFX 3 August 28, 2014 10:06
Initialization method for open channel rkmittal1108@gmail.com FLUENT 0 November 8, 2012 02:48
Initialization a student Siemens 2 May 19, 2006 13:55
compressor initialization paglia FLUENT 0 February 1, 2006 16:14
